both front turn signals out on 2017 tundra
Discussion in '2.5 Gen Tundras (2014-2021)' started by dananderstein, Jun 6, 2021.
  1. Jun 6, 2021 at 4:56 PM
    dananderstein
    dananderstein [OP] New Member
    17tundra
    A couple weeks ago my right turn signal bulb went out. So I replaced both bulbs. Now today the front turn signals do not work and the hazard button does not work. does anyone know what is wrong with this?
  2. Jun 6, 2021 at 4:57 PM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    Have you checked the fuse?
  3. Jun 6, 2021 at 5:08 PM
    dananderstein
    17tundra
    i swaped the fuse out with the spare, i am starting to think it is the switch on the steering wheel but don't want to jump the gun get
  4. Jun 6, 2021 at 5:14 PM
    Danman34
    Danman34 New Member
    Danny
    The blinkers go through the ecu via the stalk on the steering wheel. The hazards do not. They are run through a simple on/off switch. This leads me to believe there is a power delivery issue.
  5. Jun 8, 2021 at 3:55 PM
    dananderstein
    17tundra
    Problem kind of solved. Months ago I had the right turn signal go out. So I replaced it with an LED one on both sides. I didn't like the hyperflash so on removal one of the lights fell inside my light fixtures. I put normal turn signal lights in and it worked fine until the other day. So I bought some new long life bulbs and I noticed how it was easy to remove the new lights. So I pressed the turn signal bulb in the pressed on it another harder and it went in even further. When I was removing the right side the old newer light fell into the light fixture now I have 2 bulbs floating around in their. So they work fine now. I am starting to wonder if the socket was designed incorrectly and it expands when it gets hot or I just didn't put enough man into it.
