Botched Brake Job
Discussion in '2nd Gen Tundras (2007-2013)' started by Wastelander, Nov 12, 2022.
  1. Nov 12, 2022 at 7:51 PM
    Wastelander
    Wastelander [OP] New Member
    Ace
    2007 Tundra 5.7 4x4
    I replaced all the rotors and brake pads on my 07 Tundra and when I took it for a test drive I immediately noticed loud squeaking when letting off the brake and when I come to a full stop, regardless of speed, it feels like the front brakes are seizing or shaking real bad. No issues slowing down or turning, just when I come to a full stop does it make a grinding noise and shake.
    When pressing in the front calipers I didn't use that special tool, just used clamps and the old brake pads to press them back in. So not sure if I might have damaged the calipers by doing that?
    For the exception of using that caliper tool, I followed this video step for step: https://www.youtube.com/watch?v=H-x_GF9eA94
    Any ideas on what I could do to stop the squeaking and the shuddering when coming to a full stop?
  2. Nov 12, 2022 at 8:04 PM
    Rubberdown
    Take it apart and double check stuff is tight and correctly assembled. No reason for it to be doing that unless maybe there was a coating on the discs to keep them from rusting and you didn’t clean it off.
  3. Nov 12, 2022 at 8:04 PM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    I've never used a "special tool" and I've never had issues. Did you pull the wheels and look at the rotors for any signs of abrasion?
    BlueCrushSC16 and JLS in WA like this.
  4. Nov 12, 2022 at 8:08 PM
    DaBoro54
    DaBoro54 Beach Fisher
    Leveling kit, 285/70R18 EXOs
    Backing plate get bent?
  5. Nov 12, 2022 at 8:09 PM
    joseph_womack
    joseph_womack @ 4x4bound
    Joe
    Louisiana
    2007 RCLB, 4WD, 4.7L V8
    3/1 Lift, 35s, Front Bumper, etc etc
    did you put the right pads in the right spot? not all brake pads come identical for both sides of the rotor, most of the time there is one that needs to be on the piston side (doesn't quite apply to the front of the truck since they're 4 piston calipers)
  6. Nov 12, 2022 at 8:10 PM
    14CRWMX
    14CRWMX New Member
    Tampa Bay
    2014 SR5
    Name of brand for brakes and rotors?
    dsi183 likes this.
  7. Nov 12, 2022 at 8:11 PM
    joseph_womack
    Joe
    Louisiana
    And did you properly "burn in" the pads and rotors?
    JLS in WA likes this.
  8. Nov 12, 2022 at 8:18 PM
    Wastelander
    Ace
    2007 Tundra 5.7 4x4
    I did take it apart again today, looking it over. Everything is tight and in place and I did spray the rotors with brake cleaner.
    I didn't notice any abrasions on the rotors.
    The backing plate doesn't seem to be bent.
    I'll double check that the pads are on the correct sides tomorrow when I have daylight.
    The rotor and pads are Detroit Axle brand.
    And I don't think I know what "burning in" the pads and rotors means exactly. How do I do that?
  9. Nov 12, 2022 at 8:37 PM
    MisterE
    MisterE Overcompensating
    2021 Tundra CrewMax TRD OffRoad MGM
    ESP Storage, TRD Pro Grill
    Bedding in/breaking in brake pads and rotors is a process of performing a series of heavy braking but not complete stops. This leaves a thin layer of brake pad material on the rotor and creates a better stopping surface.
  10. Nov 13, 2022 at 5:14 PM
    joseph_womack
    Joe
    Louisiana
    accelerate to 30-35 mph, brake very hard, but only down to about 5 mph- accelerate up to 35 and repeat about 4-5 times
  11. Nov 13, 2022 at 5:45 PM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Find a new subdivision being built. Best place to do it.
  12. Nov 14, 2022 at 5:14 AM
    triharder
    triharder Sorry, Not Sorry
    Jake
    Southern, Maine
    2010 RWB Black
    Billstein 6112/5160's, coachbuilder spacer on driver side/ 20" rockstar wheels/ 33" nitto ridge grappers/SS Brake lines (or as most people write Break), Painted Calipers/Powercoated Tow hooks/pocket flairs/heated seats,bed leds/line-x liner/xtang trifold/tow mirrors/Stereo Work/Compustar Remote Starter/ retrofit Morimoto Minin H1 and switch back LEDs/ plenty I'm forgetting
    on my 2010 the backing plate (seam, where the backing plate makes up a seal with the rotor, was rubbing on my rear rotors and causing an awful racket.
    There are pictures on this forum to help show you were.
    That is what i'd try first. Mine made a hell of noise when i replaced my rears and this fixed it.
    (best answer is to take a angle grinder or dremel and remove the lip on the new rotors. (frustrating to have to do this i know)
    I'll try to find the link to the post for you.
    Luckster likes this.
  13. Nov 14, 2022 at 5:19 AM
    triharder
    Jake
    Southern, Maine
    2010 RWB Black
  14. Nov 14, 2022 at 8:11 AM
    Wastelander
    Ace
    2007 Tundra 5.7 4x4
    The rattling and squeaking was so bad I didn't think it would be this simple but I guess it was. Drove around yesterday to break them in and now everything seems to be right! Thanks for everyone's advice
  15. Nov 14, 2022 at 11:05 AM
    joseph_womack
    Joe
    Louisiana
    awesome! Pads hadn't been burned in yet so they might've just had some coating left on them
  16. Nov 14, 2022 at 11:17 AM
    Rubberdown
    You ought to be spraying everything down with break cleaner before you mount them up. They coat the discs so they don’t rust and you don’t want that crap on your pads.
  17. Nov 14, 2022 at 11:34 AM
    triharder
    Jake
    Southern, Maine
    2010 RWB Black
    I called the company on the coated rotors i installed on the wife's car. They said "DO NOT Spray/remove coating prior to install".
    therefore, i'd call the company that makes the rotors and ask.
    (metal un-coated rotors will come with oil to keep them rust-free, if you install withou removing the coating the pads with get oiled and they will forever squeak, so i agree with you). But i'd still call the manufacture to verify.
  18. Nov 14, 2022 at 11:52 AM
    Rubberdown
    Hey you’re right I ought to specify that. If you buy specially coated rotors don’t remove the special coating.
