Boss 3/1 lift
Discussion in 'Suspension' started by whoisbambam, Nov 3, 2019.
  1. Nov 3, 2019 at 4:39 PM
    whoisbambam
    whoisbambam [OP] New Member
    2017 Toyota Tundra CrewMax TRD Off Road (not pro)
    I apologize for my ignorance, but I have been reading thru the threads.... it seems the 'boss 3/1' lift kits are the best? i mean better than readlift, rough country, etc in regard to ride comfort and perhaps safety (no spacers, blocks, etc).
    I read this by csuviper:
    "I still highly recommend the Toytec Boss kit. For the price it really is the best offering that I have had. Onroad and off-road performance was great.
    Street only and want to stay low cost go with the split Toytec spacer lift.
    Mainly road with some off-road the Boss is great."
    I am assuming this is the one csuviper and others seconded and thirded etc....
    this one?: and then use the shackles as they are superior for 'ride' comfort?:
    SKLTUN-2247 - Toytec 1-1.5" Adjustable Shackles with new lower bushings
    All I am trying to do is accomodate these rims and I am not sure if the 3/1 toytec lift would do that:
    and with that 3/1 lift kit, would I be able to use these with that lift?:
    https://realtruck.com/p/fuel-black-cleaver-wheels/v/toyota/tundra/2017/
    Fuel Black Cleaver, 5X150/5.5, -18mm
    would I need to go all the way up to 3inches in front, or would 2 inches work?
    Also, some are mentioning to get new upper control arms.... that adds about $700 to the price.... what is the purpose of changing the upper control arms, and is it necessary?
    I am new to this and don't know much of anything vehicle tech wise.....
    thank you all for any assistance.
    Lowgybear likes this.
  2. Nov 3, 2019 at 4:44 PM
    whoisbambam
    also, about how many hours would it take to install that lift, with the shackles? I am trying to get a roundabout price for installation, in other words.... 6 hours? $400 to install? any help appreciated
  3. Nov 3, 2019 at 4:47 PM
    Vancepp
    Vancepp New Member
    2017 TRD Off Road
    Toytec Boss Kit, Method Grids, 305/70-18 STT Pros
    That's exactly the set up I have and would never go any other route. Ride is smooth and has never given me any problems. If you plan to set them all the way up to 3 inches of lift, (I have mine cranked up to about 3 1/2") you will probably want the UCA's (upper control arms) as well.
    Solid company, Solid kit. You will not regret it.
    @Toytec Lifts
  4. Nov 3, 2019 at 5:05 PM
    whoisbambam
    @Vancepp , thank you very much.
    the upper control arms increases the price by about $700 it seems..... what is the purpose of these different control arms? what issues will I have without changing them?
    I am considering these rims and basically just want to be able to put on these wheels with different tires..... if 2 inches up front will accomodate that, then that is all i would want to do if it saves $700 and works:
  5. Nov 4, 2019 at 8:53 AM
    StrmTroop29
    StrmTroop29 New Member
    Anthony
    I shot you over a message sir! I'm Anthony from Toyteclifts
    Stroke250, Vancepp and T-Rex266 like this.
  6. Nov 4, 2019 at 4:27 PM
    Also drives a white 4R- fastest color
    StrmTroop29[QUOTED] likes this.
  7. Nov 5, 2019 at 3:57 PM
    dfwluis
    dfwluis New Member
    Luis
    DFW
    Tundra
    Genesis Dual battery kit. SSO Slimeline Bumper/W 12k winch. ARB Compressor. F/R ARB Lockers. Custom cradle for rear 12k winch.
    Upper control arms correct caster.
    Check out JBA UCA’s. They’re about $500ish so that’s a bit Lowe than the $700 you mention. And they’re great UCA’s
  8. Nov 6, 2019 at 3:33 PM
    whoisbambam
    thank you all. getting mixed messages.... ideally it seems i should get new upper controller arms....
  9. Nov 8, 2019 at 5:03 PM
    You can get the SPC UCA's from Toyota for $540.00
