Bora Spacer Question
Discussion in 'Wheels & Tires' started by demello, Mar 5, 2020.
  1. Mar 5, 2020 at 7:42 PM
    demello
    demello [OP] New Member
    Michael
    Storm Trooper
    Bilstein 6112 front to the top Bilstein 5160 rear SDHQ 3/4” shackle
    What is the smallest Bora spacer that I can install without cutting the factory wheel studs? I need a half inch more backspace to run the UCA’s that I want. If I go to big my tires will go further into the bumper. Tires are 275/65/20’s and I’m already using a half inch bumper spacer with all the plastic pushed in. Leveled with 5160’s to the top.
    Tundyfundy likes this.
  2. Mar 5, 2020 at 7:53 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Depends on the truck year. I have 1.25 on mine, i doubt i could run a 1. Some of the newer trucks guys are able to run the 1 inch. Pull a wheel and measure your studs.
    And for knowledge purposes, you’re trying to have less backspace, not more. Think of backspace as the overhang from the mounting surface
    TRDFerguson likes this.
  3. Mar 5, 2020 at 8:01 PM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    What wheels are you running? I'm using 1" Boras with OE TRD Off Road wheels. The studs on the front wheels don't stick out at all but the rear do probably about an eighth of an inch. The Off Road wheels have knockouts that leave a little room for the studs.
  4. Mar 5, 2020 at 8:01 PM
    r4z0r51o
    r4z0r51o have fallen off the forum, but I’m still alive.
    Dave
    Northeast San Francisco Bay Area
    2016 Silver Sky Metallic Crewmax 5.7L TRD 4x4
    22x12”HostileRage/33”NittoRidgeGrap/StealthFighter/FOX-BDS
    As I remember you can use 1“ Bora spacers on the front end without trimming the studs but you’ll need to go 1.25” for the rear end (at least with my Fuel wheels).
  5. Mar 5, 2020 at 8:59 PM
    demello
    Michael
    Storm Trooper
    Thanks for the replies.
  6. Mar 5, 2020 at 9:01 PM
    demello
    Michael
    Storm Trooper
    Yes, I realize this. I misspoke. Trying to pickup a half inch.
  7. Mar 5, 2020 at 9:02 PM
    demello
    Michael
    Storm Trooper
    How would one cut the studs clean without destroying the thread pattern?
  8. Mar 5, 2020 at 9:05 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    I would be worried that cutting them would heat them up and maybe weaken them? Is the 1/4 inch worth it?
  9. Mar 5, 2020 at 9:11 PM
    CrewMaxT
    CrewMaxT New Member
    Alberta
    2018 CrewMax SR5
    A grinder or any other tool you have that will shave down the stud. Hold to the tip and grind it flat. Take your time and check the threads by spinning on a nut by hand. If you have a thread chaser even better. Don’t worry about heat, the stud won’t be getting red hot.
  10. Mar 5, 2020 at 9:33 PM
    Tundyfundy
    Bay Area, CA
    Magnetic Grey DC SR5 4x4 2016
    SUSPENSION: Bilstein 6112 coilover (1.9") w/ Powder Coated Springs and Spring Perch (TRD Red), JBA Upper Control Arms, Bilstein 5160's w/Billet Aluminium Reservoir Brackets, +2 Coachbuilder Shackles, Diff Drop Kit, Carrier Bearing Drop Kit, Brakeline Extensions, ABS Extension, Poly Bushings for Leafs, Coachbuilder Shims (2 Each Side), Coachbuilder Bumpstop Extensions, TRD Rear Sway Bar, TRD Front Sway Bar, Air Lift 5000 airbags w jounce bumpers, Daystar Airbag Cradles WHEELS AND TIRES: BF Goodrich KO2's 275/70/r18, BORA wheel spacers 1.25", TRD Wheel Caps,TRD Valve Stem Caps, Spare Tire Lock PERFORMANCE: Bullydog GT Tuner(Performance Tune), TRD Intake, TRD Dual Exhaust (with Modified Exhaust Hangers for Levelling Tail Pipe),TRD Brake Pads, TRD Oil Cap (US), TRD Radiator Cap, TRD Oil Filter, Optima Yellow Top Battery,GP Battery Distribution Blocks, StopTech Slotted Cryo Treated Rotors, Goodridge G-Stop Steel Braided Brake Line Kit PROTECTION: PNP Engineering Type 4 Rock Sliders (With Full Dimple Plate) ,ADD Stealth Fighter Rear Bumper w Red/Blk Shackles and Custom Stomp Pad, TRD Skid Plate with ReadyLift Spacer Kit, Victory 4x4 LCA Skid Plates, JOMAX ABS Sensor Armor, Rear Diff Breather Mod, ARK splash guards INTERIOR: Husky Liners X-Act (Front and Full Coverage Rear and Front Weather Beater Trans Hump), Interior LED Bulbs, WheelSkins Genuine Leather Steering Wheel Cover(EuroPerf), Clazzio Genuine Leather Seat Covers(BLK/DRK GRYwith custom stitching and embroidered headrests), Clazzio Seat Heaters (Front and Rear), Entune Startup Screen MOD, Entune Off Screen Mod, Tinted Windows with Windshield Visor, AJT Key Fobs,Eagle Claws Floor Mat Clips, Bodyglove Visor Organizer,Custom Door Cup Inserts, Glass Break Sensor,AJT Radio Knobs, Custom Dior Cup Inserts EXTERIOR: Full Debadge, LED Brake Light Bulbs, LED Rear Turns, LED Reverse, LED Plate Lights, LED Cargo Lights, LED Third Brake Lights, LED Front Marker Lights, LED Fog Light Bulbs, Lamin-X Fog Light Covers (Amber),2018 OEM LED Headlights, iHacker harness, VLED Universal Puddle Lights, VLED Interior Footwell Lighting (Front and Rear),VLED Extreme Amber Fornt Turns, NSV Knight Rider Light bar, Baja Designs Sport Squadron Pods in Rear Bumper (Driving/wide), Painted Red Tow-hooks, Bed Rail System, Blind Spot Mirrors, Hitch-safe, Tail-gate lock, EAG Raptor Grille, Custom Grille Badge,Full Vinyl Wrap (Matte Black/Matte Pine Green Mettalic), Charvonia Designs Tie Bed Tie-Downs, Bull Ring Bed Rail Anchors, Line-X, Tundra Bed Mat, Bakflip F1 Bed Cover SOUND: Noico 80Mil Sound Deadening and Noico 170 Mil Thermal Insulation (All 4 Doors, Roof, Floors, Rear Panel, Dash). Hertz Uno K170's Component Speakers (Front Doors with Upgraded Sail Panels), Hertz Uno K170 Coaxial Speakers (Rear Doors), JBL C1-075ct Tweeters (Total 4) in Side Dash and Center Speaker, JBL Stadium 5 Amp w/Remote Bass Adjustment Knob and Amp Rack, 12" Infinity Reference Subwoofer in Custom Enclosure w/ “TUNDRA” Logo, Fast Rings Foam Speaker Rings System(4 Doors), Fix 86 DSP
    Put a proper sized nut on the stud (shorter than the cut you’ll make) and once the cut is made,smooth the stud with a wire wheel then remove the nut and it will clear the threads making them usable again.
    You can even use the nut to guide your grinder and at the same time protecting the threads. Two nut are preferable in that situation. (That’s what she said?)
  11. Mar 5, 2020 at 9:38 PM
    Tundyfundy
    Bay Area, CA
    Ps I have 1.25 inch spacers, no cutting, 2.9 inch lift, 275,65,r18 and they hardly rub. Which UCA’s? I have the JBA’s
