BORA 1.5 Wheel Spacers
Discussion in 'Wheels & Tires' started by JMB, Apr 21, 2016.
  1. Apr 21, 2016 at 4:42 PM
    JMB
    JMB [OP] Not new, just a little old.
    Chesapeake, VA
    2013 Super White Tundra DC
    I'm considering changing tire size to 295-70-18, with leveling shocks. Using my fat finger feeler gauge I think less backspace will be required so I started searching spacers, I don't want to get new rims although I could. While looking at BORA 1.5 spacers I found several forums and such that indicated that the BORA 1.5 spacers wouldn't fully engage the nuts provided. Does anyone have experience with this, do you have to change the wheel studs to get proper thread engagement with the nuts that hold the spacer to the hub?
  2. Apr 21, 2016 at 6:03 PM
    That's a solid brand, as is Spidertrax. Both will hold up well for u.
  3. Apr 21, 2016 at 8:47 PM
    JMB
    Chesapeake, VA
    That's what I've gathered. But I've seen information that the BORA's counter bore for the holes where the existing studs go isn't deep enough to engage more than about half of the nut supplied by BORA. The pictures I've seen make me go "huh". Not saying it's NFG, but looking for hands on experience. EDIT Actually that condition from a visual standpoint is NFG, but it may not be if the thread engagement is sufficient to provide the correct preload considering all of the variables associated with a bolted connection. Surface finish, debris, fatigue and on and on...
  4. Apr 21, 2016 at 9:41 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Hmm. Bora is a really good brand. Crazy they would make a product that requires you to press out the studs for new ones. Maybe that is just the case with the wider ones so that there is more to hold????
    I have the 1.25" spidertrax wheel spacers. Fully engaged nuts on the wheels studs.
    Can you get the look you want with 1.25" wheel spacers?
  5. Apr 22, 2016 at 7:37 AM
    JMB
    Chesapeake, VA
    I think that 1.25 will work, I'm going from the stock 255 tires to 295 and want to reduce the offset without the expense of new rims.
  6. Apr 22, 2016 at 8:31 AM
    csuviper
    Broomfield, CO
    Stock wheels have an offset of +60. With 1.25" spacers you will be at +19.24ish if my math is right.
  7. Apr 22, 2016 at 12:42 PM
    JMB
    Chesapeake, VA
    1.25" is 31.75 mm, so reducing 60 by 31.75 leaves +28.25 offset if my conversion is correct. Thanks for the info on Spidertrax, I believe I'll get them on order tonight.
  8. Jun 18, 2016 at 3:56 PM
    JMB
    Chesapeake, VA
    Got the spidertrax from @ToyTec Lifts, fit great. Added 295-70-18 tires to the stock steel rims and all's well. Thanks for the turn on to toytec., good to deal with.
    mdavis and T-Rex266 like this.
  9. Aug 29, 2016 at 9:48 PM
    tundrarida
    tundrarida New Member
    2012 2wd Double Cab
    1.5" BORA wheel spacers.
    In reply to post #3, from Apr 21, 2016 at 10:47 PM:
    I just installed my 1.5" BORA wheel spacers on my 2012 2WD DoubleCab Tundra yesterday (8-28-16) and the fit is great. The lug nuts sent by BORA seated completely onto the factory lugs; contrary to the concerns expressed in post #3, above (in which several threads are shown, left exposed, beyond the lug).
    The lug nuts included were roughly 3/4" to 1" long (I did not measure them [sorry], but rest assured: they threaded on to their full length).
    Lenny Stahl of Motorsport Tech (BORA) did a great job answering my questions about the spacers before I ordered them, and they were produced just-as-described. I re-torqued them after a 5 mile drive (per install instructions) and they have not budged. My truck handles dramatically better now; no more of that sloppy factory 'roll' for small steering inputs. It looks tougher, too, with the wider stance.
    I'd definitely buy these spacers again!
    Respectfully,
    MS22, kparrow, Tundra_361 and 3 others like this.
  10. Jul 26, 2019 at 12:38 PM
    LT75
    LT75 Seasoned Pro
    Saint Charles, IL
    No mods yet
  11. Dec 16, 2019 at 9:38 PM
    kparrow
    kparrow New Member
    Kevin
    Nampa, ID
    Did you do all 4 corners or just the front?
  12. Dec 18, 2019 at 5:54 AM
    Albinator
    Albinator SAINTRIOT
    Utah
    2008 Tundra Crew Cab 5.7 4x4
    RC 3.5” M1 Lift 18X9 5-150.00 12 Offset Vision Turbine
    How have the 1.25” Spidertrax held up? I have a 2008 Crew and have been debating doing this. Any issues, complaints, etc.? I’m running 275x70x18 and want that same poke your pics show.
    kparrow likes this.
  13. Dec 18, 2019 at 7:51 AM
    csuviper
    Broomfield, CO
    I had the Spidertrax from Toytec Lifts as well on my 2012 Rock Warrior for over 2 years without issue. Ended up taking them off and selling them to someone on here. Cant remember who now. Maybe follow up with them for full confirmation of continuing success.
  14. Dec 18, 2019 at 7:53 AM
    csuviper
    Broomfield, CO
    @1BadTundra
  15. Dec 18, 2019 at 7:56 AM
    csuviper
    Broomfield, CO
    I sold them to him Sept 2017 and I guess he sold them August 2019. He got two years out of them and now someone else is enjoying them.
  16. Dec 18, 2019 at 9:17 AM
    JMB
    Chesapeake, VA
    No issues whatsoever. I highly recommend
    Albinator[QUOTED] likes this.
  17. Dec 18, 2019 at 10:50 AM
    kparrow
    kparrow New Member
    Kevin
    Nampa, ID
    I just bought 1.5” BORA spacers from @Alexstundra and once they get here I’ll take some pics for you. I also have an 08 running 275/70/r18 on current trd off road wheels with +60mm offset. Should bring me to +21.9 if my math is right.
  18. Dec 18, 2019 at 7:33 PM
    Albinator
    Albinator SAINTRIOT
    Utah
    Appreciate it!
  19. Dec 20, 2019 at 9:29 AM
    1BadTundra
    1BadTundra New Member
    Clinton
    2010 TRD Rock Warrior Crewmax
    Too Much to List
    Yep, I ran them for 2+ years, no issues and sold them. I'd still have them if not for getting new wheels with the offset I needed without them.
  20. Dec 29, 2019 at 9:18 PM
    kparrow
    kparrow New Member
    Kevin
    Nampa, ID
    Here’s before and after. Haven’t gotten the rear done yet. Will post up that too. Had to take the front “mini mudflaps” off but that’s it.
    ADEE1447-31E7-4BCD-9412-733C28347352.jpg F81981F7-6298-4088-B680-BC1D8E217BDB.jpg
  21. Jan 1, 2020 at 6:39 PM
    Albinator
    Albinator SAINTRIOT
    Utah
    That looks good, thanks doe remembering to share!! So it took 1.5” spacers and an offset wheel to have it poke like that? I thought just a 1.25” spacer with stock wheels would do the trick but I guess not.
  22. Jan 1, 2020 at 6:43 PM
    kparrow
    kparrow New Member
    Kevin
    Nampa, ID
    Nope just the 1.5” spacer. I am running stock wheels. Current production TRD Off Road wheels which is a +60 offset from the factory
    Mike19 likes this.
  23. Jan 2, 2020 at 6:33 PM
    Albinator
    Albinator SAINTRIOT
    Utah
    Are you still running factory rake?
  24. Jan 3, 2020 at 11:23 AM
    kparrow
    kparrow New Member
    Kevin
    Nampa, ID
    currently yes. Will be leveling out sometime this year.
  25. Mar 14, 2022 at 10:34 AM
    pvn.beluga
    pvn.beluga New Member
    Phuc (Phooc)
    Connecticut
    @csuviper Did you run both front and rear spacers?
  26. Mar 14, 2022 at 10:38 PM
    csuviper
    Broomfield, CO
    Yes front and rear. No issues. Gave the look I wanted.
    pvn.beluga likes this.
