Boost mirrors causing BSM problems
Discussion in '2.5 Gen Tundras (2014-2021)' started by kenschmitz, Nov 9, 2023.
  1. Nov 9, 2023 at 1:28 PM
    kenschmitz
    kenschmitz [OP] New Member
    I recently installed aftermarket Boost towing mirrors on my 2020 Tundra. Since then I have been getting a warning that my Blind Spot Monitoring(BSM) is not functioning. The first time this happened I turned BMS off and back on and that fixed the problem. Yesterday got the warning again, but this time the off/on solution did not work.
    Looking for ideas of why this is happening and ways to fix it. I love the mirrors, but also want my BSM.
  2. Nov 9, 2023 at 1:36 PM
    RobertD
    Robert
    DFW, Texas
    Have you reached out to Boost? Their customer service is pretty good and they will probably have a better idea.
    I assume your mirrors are BSM compatible and its been working for you?
    kenschmitz[OP] likes this.
  3. Nov 9, 2023 at 4:33 PM
    kenschmitz
    Thanks, Robert. I contacted Boost and they gave me a couple of tests to do. When I gave them the results they think it a problem with the passenger side mirror and they are sending me new glass to install.
    I will report back to this thread when I get it installed and let everyone know if that solved the problem.
    Boost was very quick to respond and very interested in solving my problem.
    RobertD likes this.
  4. Nov 10, 2023 at 8:27 AM
    JDR76
    JDR76 New Member
    WA
    2021 1794 TRD OFF ROAD
    I had this same issue with mine. Intermittent BSM failure. Recorded the code it was throwing, gave it to Boost, and they sent me a replacement glass for the passenger side. I installed that (be very careful, as it's easy to break both the tabs and the glass) and it resolved the issue for a few weeks, but then it came back. They ended up sending me a replacement set of mirrors which ultimately resolved the issue.
    Boost has incredible customer support. They were really great to work with as we stepped through my issue.
