Bolt size for truck bed rail system?
Discussion in '2.5 Gen Tundras (2014-2021)' started by pannelld, Mar 27, 2019.
  1. Mar 27, 2019 at 7:58 AM
    pannelld
    pannelld [OP] New Member
    Dustin
    Toyota Tundra 2014
    20 inch fuels on 33" Toyo Trail Grapplers
    Does anyone know the bolt size for the truck bed rail system in a tundra? I have some stripped bolts that ill have to take out. I need to get some new ones, but I'm not sure what size they are?
  2. Mar 27, 2019 at 8:13 AM
    Str8up50
    Str8up50 New Member
    WL
    S Louisiana “Chasin Redfish”
    2016 Tundra DC
    6mm
    pannelld[OP] likes this.
  3. Mar 27, 2019 at 8:15 AM
    pannelld
    Dustin
    Toyota Tundra 2014
    Thanks. Anyone have any tips for removing those stripped bolts?
  4. Mar 27, 2019 at 8:19 AM
    Str8up50
    Str8up50 New Member
    WL
    2016 Tundra DC
    Bruh I'm right with you. I should had tapped those inserts before cranking down on them screwa
  5. Mar 27, 2019 at 8:20 AM
    BlueBottle
    BlueBottle not a PRO
    '16 Platinum 4x4
    See fine print
    Had an issue with that bolt stripped too. Used an extractor bolt kit. Came out relatively easy.
  6. Mar 27, 2019 at 8:22 AM
    Str8up50
    Str8up50 New Member
    WL
    2016 Tundra DC
    Or u can use a dremel cut a slit, insert flat tip and unscrew it
  7. Mar 27, 2019 at 8:46 AM
    pannelld
    Dustin
    Toyota Tundra 2014
    that dremel cut sounds like my speed. Never used a bolt extractor before
  8. Mar 27, 2019 at 9:23 AM
    They are really easy to use. Drill the hole, tap in the extractor, and remove the damaged bolt.
  9. Mar 29, 2019 at 9:26 AM
    Str8up50
    Str8up50 New Member
    WL
    2016 Tundra DC
    Got new screws, tapped the threads, and they finally fit perfect with no stripping
  10. May 6, 2019 at 10:31 PM
    Flyinryank
    Flyinryank New Member
    Ryan
    Las Vegas, NV
    White 2015 CM 4x4
    Just had a similar issue. I drilled the head off with a large bit and used a pair of pliers to unscrew what was left. Did you replace with factory screws? If so you happen to know the part number?
  11. May 7, 2019 at 2:33 AM
    Str8up50
    Str8up50 New Member
    WL
    2016 Tundra DC
    I did replace with factory screws. As far as part number I just went down to dealer. They were not that $$$$
