Bolt on sliders for 3rd Gen?
Discussion in '2.5 Gen Tundras (2014-2021)' started by kevine0001, Jul 7, 2019.
  1. Jul 7, 2019 at 5:59 PM
    kevine0001
    kevine0001 [OP] New Member
    Kevin
    I've already used the search tool and found one thread. Curious if anyone has found a bolt on rock slider option for 3rd gen tundra (2017) and specifically, what existing holes in the frame were used, size and thickness of back plates and how many additional holes were drilled?? Also, are any of the OEM threaded holes in the bottom of the frame used? I'll be fabricating my own but curious about mounting options. Thanks.
    CaptSpaulding likes this.
  2. Jul 7, 2019 at 6:16 PM
    ep3Jee
    ep3Jee New Member
    Czar
    Los Angeles
    2016 Tundra TRD Pro
    Stock
    SDHQ, it's very nice and simple enough to install.
  3. Jul 7, 2019 at 6:19 PM
    shellshock
    shellshock Guy who drives a lot
    Iowa
    2019 TRD PRO
    InTheRough and Black Wolf like this.
  4. Jul 7, 2019 at 6:19 PM
  5. Jul 7, 2019 at 6:20 PM
    shellshock[QUOTED] likes this.
  6. Jul 7, 2019 at 6:21 PM
    Pinay
    Pinay New Member
    Monet
    Mahal kita Kuya
    Mine are from Demello, Rock Crusher sliders. Bolt on but had to drill a few holes in on bottom, the sides on top used holes in frame.
    D0B74B3D-858B-4F57-8F38-6442B0FA6501.jpg 53F00706-88BC-43BE-A8F3-48A38A4A3592.jpg 30B40833-1C9B-4336-93EF-8220ACDF3C99.jpg
    CaptSpaulding, equin and Black Wolf like this.
  7. Jul 7, 2019 at 6:23 PM
    jewsNbrews
    Jewiston Idaho
    2019 TRD PRO
    Bolt on
    Victory4x4 makes a nice set as well. 3 holes drilled on each side.
    Stroke250, equin and Black Wolf like this.
  8. Jul 7, 2019 at 6:25 PM
    Pinay
    Pinay New Member
    Monet
    Mahal kita Kuya
    I was lucky enough to have a friend help install, he did all the drilling! Hot and sharp metal, any drilling would need lots of protection!!
    Black Wolf likes this.
  9. Jul 7, 2019 at 6:39 PM
    shellshock
    Iowa
    2019 TRD PRO
    Very happy with mine. I fell off a ledge in Moab this week and bounced hard on the slider. There’s a scuff in the powder coat is that is hardly noticeable.
    CaptSpaulding and Pinay like this.
  10. Jul 7, 2019 at 6:41 PM
    Slee's are a bit pricey but "cry once buy once":thumbsup:Made locally to me anyways in Golden, CO.
  11. Jul 7, 2019 at 6:46 PM
    kevine0001
    Kevin
    Thanks for the replies and pics of the bolt ons. I looked at the SDHQ but just for what the mounting kit looks like. I'm fabricating my own. I actually learned how to weld and built up a 2000 land cruiser. Sold it a month or so ago and picked up a 2017 crew max 4x4. But not wanting to weld on sliders at this point. I guess I'll be drilling a few holes then. I figured with the larger side holes, those had to be used with backing plates, which I see Slee used. I'll be using 1/4" thick backing plates then. I'm assuming something similar was used for the mounting bolts that went up from under the frame, i.e., backing plates inside the frame? I did see a couple smaller (3/8") threaded holes under the frame, but I'm assuming there's got to be more than just two underside bolts being used.
  12. Jul 7, 2019 at 6:46 PM
    15whtrd
    15whtrd Mr. Blonde
  13. Jul 7, 2019 at 6:56 PM
    kevine0001
    Kevin
    Is there anyone who's welding/fabricating their own? Haven't read many posts where guys/gals are welding their own stuff.
  14. Jul 7, 2019 at 7:12 PM
    15whtrd
    15whtrd Mr. Blonde
    Pretty rare. There’s been a few guys that have made their own but I don’t think they were making them for anyone else. Maybe check your local welding shop?
    Pinay likes this.
  15. Jul 7, 2019 at 7:18 PM
    kevine0001
    Kevin
    Oh I don't need a welding shop. I have my own 220 gas mig, oxy/acetylene and 220 plasma cutter. I make as much of my own stuff as possible. I armored up my old Land Cruiser myself including a double swing out rear bumper. That was a job
  16. Jul 7, 2019 at 8:55 PM
    equin
    equin Texarican Tundra
    Ed
    DFW, TX
    If I had my own equipment, I'd try to make my own, too. I'm not the best welder, but I can booger weld with the best of them! But yeah, like someone else said, most folks on here are like me and don't fabricate their own stuff. A few do, though.
    I think the links to the pictures already posted give a good idea of the bolt-on mounting setups. I hate drilling on frames, especially when drilling upward. But the Tundra frames don't look to be as thick and beefy as the old Ford truck frames I've drilled in the past. So I'm thinking the few holes needing to be drilled shouldn't be too bad.
    Anyway, looking forward to seeing what you come up with. So please post pictures and a write-up of your slider build!
  17. Jul 7, 2019 at 8:58 PM
    Sas
    Sas Humor is everywhere
    OKC, OK
    '17 SR5 CM TSS 4WD MGM 5.7 FF
    Lost track after #1.
    nlaroy likes this.
  18. Jul 8, 2019 at 8:13 AM
    kevine0001
    Kevin
    Sas, thanks. I found the P&P, but I did not read every post that didn't indicate bolt-on slider in the caption after doing the search. Having to read dozens and dozens of posts, several that are over a year old, and many which aren't on topic, is reason enough for my post. Weird, the Victory didn't show up when I did my search. I've since found the SDHQ sliders. I suppose I should have clarified that I was looking for someone who fabbed their own as I just wanted to see what OEM holes, if any, were used for install. I've since confirmed what I assumed, i.e., that some holes would need to be drilled and that backing plates are required. Thanks again for policing but wasn't trying to be redundant.
    Pinay likes this.
  19. Jul 9, 2019 at 12:11 AM
    Diesel3612
    Diesel3612 New Member
    2019 tundra SR5 crewmax 4X4 super white
    Bull bar, chase rack leveling kit 33s on anthracite rims
    Contact Heavy Metal Off-Road
    The guy is in cali and hes a great fabricator and has 3rd gen sliders made specifically for your truck to your specs
    kevine0001[OP] likes this.
  20. Jul 9, 2019 at 7:45 AM
    kevine0001
    Kevin
    Diesel, thanks for the tip. Such great info and guidance on here. I will be fabricating my own, probably going to use 2x2 square tubing, similar to Pinay's sliders. Won't require any tube bending. However, I will likely add additional gussets. I won't be wheeling my truck hard, but prefer to overbuild these types of things. Thanks again.
    Pinay likes this.
  21. Jul 9, 2019 at 10:16 AM
    Diesel3612
    Your welcome
  22. Jan 11, 2020 at 5:50 PM
    Mike19
    Mike19 New Member
    Chi town
    2019 SR5 CM 4X4 TRD Sport
    TRD Exhaust, Bilsteins 6112/5100, CB Shims 2/1, CB +3 Shackles, Air Ride, RCI Engine and Trans Skid Plates, Cooper AT3 XLT 275/65/20
    Why did you switch from the White Knuckle to Demello’s?
    Pinay[QUOTED] likes this.
  23. Jan 11, 2020 at 5:51 PM
    Pinay
    Pinay New Member
    Monet
    Mahal kita Kuya
    I didn’t. Demello’s are all I’ve had. I did almost sell em to get White Knuckle over Black Friday but got wheels instead...
  24. Jan 11, 2020 at 6:13 PM
    Mike19
    Mike19 New Member
    Chi town
    Oh, sorry. I thought you had WK. If you had to do it over again, what would you go with?
  25. Jan 11, 2020 at 6:15 PM
    Pinay
    Pinay New Member
    Monet
    Mahal kita Kuya
    Demello’s are awesome and quality sliders and am very happy with em!! The White Knuckle with the thicker dom would provide the most protection...
