Body plugs on 2023 Tundra SR5 TRD OR
Discussion in '3rd Gen Tundras (2022+)' started by WhiteDevil1978, Apr 16, 2023.
  1. Apr 16, 2023 at 2:25 AM
    WhiteDevil1978
    WhiteDevil1978 [OP] Ye Olde White Devil
    Dustin
    North Carolina, 'Murica
    2023 Tundra SR5 TRD Off-Road
    6 inch lift, 37 inch tires, Badlands Apex 12,000 lb winch, Fab Fours concealed winch mount with 30 inch LED, Prinsu roof rack with RC 40 inch LED and 10 inch RC LED's on sides, Auxbeam 12 switch controller, Heretic ditch lights, RetraxPro XR bed cover, Elevate bed crossbars with additional bar that connects them, Pedal Commander throttle control, overlanding solar array (2) LiTime 230ah batteries, Renogy 40 amp DC to DC charger, LiTime 60 amp MPPT, LiTime 40 amp LiFePO4 AC to DC charger, Renogy 400 watt suitcase panels
    Hey everyone! I am looking to build a nice 2nd battery under the rear seat system and want to know if the 2022+ Tundra has any pre-drilled holes filled with body plugs. The only way that I am aware of that allows you to run wire from outside the cab into the cab is through the firewall on the driver side. I have googled this question, but found nothing. If anyone is aware of another way (besides through the firewall), I'd be greatly appreciative to know. Thank you!
  2. Apr 16, 2023 at 4:11 AM
    devron11
    devron11 New Member
    Ron
    Denver
    On my SR5 I used the factory harness pass thru under the passenger side for 2 - 1/4 inch diameter cables.
  3. Apr 17, 2023 at 9:32 PM
    WhiteDevil1978
    Dustin
    Is there any way of sending a pic exactly where that is? Is it under the front passenger seat or the rear one? Thank againA
  4. Apr 18, 2023 at 4:16 AM
    devron11
    devron11 New Member
    Ron
    Denver
    It's in the back. No pics available. Lift and lock the seat cushion. Remove the door sill plastic cover and then remove the large plastic panel that forms the pass side wall of the below seat storage area. There are 3 or 4 pushpins that hold the wall in place. One pushpin for the central section that abuts to the pass side It helps if you have plastic trim panel removal tools to separate the panels from each other. Everything pulls apart with careful use of brute force......
    WhiteDevil1978[OP] likes this.
  5. Apr 18, 2023 at 9:11 PM
    WhiteDevil1978
    Dustin
    Thank you! I'd have never come up with all that!
