Body lift vs suspension lift
Discussion in 'Suspension' started by tundraz28, Feb 24, 2016.
  1. Feb 24, 2016 at 2:52 PM
    tundraz28
    tundraz28 [OP] New Member
    California
    2014 TRD tundra crewmax
    Can't wait to meet all my fellow tundra owners...
    I would like to do a body lift . What's your take on a body lift vs a suspension lift???
    T-Rex266 likes this.
  2. Feb 24, 2016 at 3:18 PM
    Welcome! Suspension would be safer.
  3. Feb 24, 2016 at 3:29 PM
    tundraz28
    California
    How does it impact the driveability
  4. Feb 24, 2016 at 4:16 PM
    Body roll
    Black Wolf likes this.
  5. Feb 24, 2016 at 4:24 PM
    CaptTyler
    CaptTyler Life’s too short to have an ugly boat.
    Tyler
    2018 Ram 2500 Cummins
    Stay away from body lifts if possible. Sean pretty much summed it up.
  6. Feb 24, 2016 at 4:47 PM
    mdavis
    mdavis I need a beer.
    Michael
    Rock Hill, SC
    Not a fan of body lifts at all. Do it right and get a quality suspension lift.
    RoVASr5 likes this.
  7. Feb 24, 2016 at 5:10 PM
    Ditto^^
  8. Feb 24, 2016 at 5:11 PM
    Ditto^^^
  9. Feb 24, 2016 at 5:12 PM
    If you want to do it for looks... Go for it. For practicality/good handling/ and possible safety issues.... forget it.
  10. Feb 24, 2016 at 8:11 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    If you do a body lift you shouldn't really go over 1". Body lift does nothing for your ride except increase you center of gravity. Suspension lift gives you added suspension travel if you choose the right one. New extended Coilover gives you a better ride and increases travel.
  11. Feb 25, 2016 at 5:22 AM
    Scarecrow
    Scarecrow New Member
    Zack
    06 Tundra SR5 4.7 v8 4x4
    Finally something I know a little about. Body lift does just that raises the body higher while keeping everything else where it is. Including the axle thus being very ineffective when it comes to off roading because you still have the stock ride height. A suspension lift will lift the axles and everything up higher giving you the clearance you need. Cost wise a body lift is what you want but if you want t done right and safe like everyone else is saying go with a suspension lift dude.
  12. Feb 25, 2016 at 9:14 AM
    tundraz28
    California
    Thanks guys. .. actually quite a bit. .. now the bigger question . What lift would be a decent one? I would like a 6 -7 inch lift something moderate not too over the top .
  13. Feb 25, 2016 at 10:37 AM
    3-4": Looks, and functional.
    anything more is looks, and one some kits at 6" plus you may need to cut the frame...good bye frame warranty.
  14. Feb 25, 2016 at 11:09 AM
    tundraz28
    California
  15. Feb 2, 2023 at 8:26 AM
    TundraTRD08
    TundraTRD08 Somehow I fit 37s on a level
    Wesley
    08 Super White TRD Off-Road on 37s
    3.5' RC lifted struts with RC UCA Alcan rear leaf spring upgrade with 300lbs added weight+1" lift built in. Adjustable Alcan Shackles set to add an extra inch which equals to a 2" lift in the rear. 37” Maxxis RAZR M/Ts with 1.5” spacers 8” BAMuffler Tuned by Bully Dog Tuner
    I know this is an older thread, but I have 3.5” up front and 2” in the back. I have adjustable shackles in the back that I’ve tried lowering but I don’t like them that low, I have quite a bit of nose dive, maybe more than factory. Is there like a 1” body lift kit that only goes on the front of the truck, or would that strain the rear cab mounts?
