boardude's [YODAGAN] Build
Discussion in '2.5 Gen Builds (2014-2021)' started by boardude, Jun 14, 2015.
  1. Aug 20, 2017 at 11:12 AM
    #391
    boardude
    boardude [OP] I am Batman
    Kris
    Tucson, AZ
    [YODAGAN]
    2015 Inferno Ex-Pro
    Got a full spare and was able to stuff it under the bed. Had to grind a few guide pieces off and it's def a tight fit but works for now. Temporary till I figure another solution or get Toytec's shackles that may give me more clearance
    MotoTundra, aperezsh, Jsena and 4 others like this.
  2. Aug 20, 2017 at 12:29 PM
    #392
    Flyin808
    Flyin808 New Member
    Nick
    2000 tundra trd
    4inch lift ,33 inch tires the
    How big is your spare? Did you need to cut exhaust.
  3. Aug 20, 2017 at 12:37 PM
    #393
    boardude
    Kris
    Tucson, AZ
    [YODAGAN]
    2015 Inferno Ex-Pro
    305/70r18 (35.1 × 12.4). I have turn downs that dump after the muffler so the tails aren't an issue. Otherwise I would risk rubbing the tire and melting on the tails.
    aperezsh likes this.
  4. Aug 20, 2017 at 12:54 PM
    #394
    Flyin808
    Flyin808 New Member
    Nick
    2000 tundra trd
    I'm running 37's wanted to try and get 35' stuffed in spare area but I have trd dual's
  5. Aug 20, 2017 at 1:27 PM
    #395
    boardude
    Kris
    Tucson, AZ
    [YODAGAN]
    2015 Inferno Ex-Pro
    Yeah I think the issue is with the driver side tail. It's doable but will be close. I know @joonbug and I think @dcsleeper408 have oversized spares under their beds too. Not sure if they have duals
    joonbug and dcsleeper408 like this.
  6. Aug 20, 2017 at 1:36 PM
    #396
    Eclipsed & Floating
    I’m right where I need to be
    Voluptuous Whitey
    I think it's GANGSTA!!!!
  7. Aug 20, 2017 at 1:40 PM
    #397
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    Does the leaf or shackle rub up and down on the Spare?
  8. Aug 20, 2017 at 2:09 PM
    #398
    boardude
    Kris
    Tucson, AZ
    [YODAGAN]
    2015 Inferno Ex-Pro
    The shackle bolt rubs on the tire. I'm planning on either reversing the bolt or switching to Toytec since they are thinner
    Jsena[QUOTED] likes this.
  9. Aug 20, 2017 at 2:11 PM
    #399
    boardude
    Kris
    Tucson, AZ
    [YODAGAN]
    2015 Inferno Ex-Pro
    Lol it gives my truck street cred
  10. Aug 20, 2017 at 2:37 PM
    #400
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    Do You have coach builders on now?
  11. Aug 20, 2017 at 2:45 PM
    #401
    boardude
    Kris
    Tucson, AZ
    [YODAGAN]
    2015 Inferno Ex-Pro
    Yeah they are pretty beefy
  12. Aug 20, 2017 at 2:48 PM
    #402
    Sefferston
    Sefferston #37sandlongtravel
    Seth
    Commufornia (not by choice)
    ERMERGERD TOYOTA
    Get some Tacoma bed tie downs and throw it in the bed.
    boardude[OP] likes this.
  13. Aug 20, 2017 at 3:45 PM
    #403
    dcsleeper408
    dcsleeper408 BASTRDS
    mark
    San Jose CA
    2015 TRD PRO
    @Flyin808 if you cut the tabs down low you can maneuver the 35" away from the exhaust. If you have cb shackles it will be VERY close to those.
  14. Aug 20, 2017 at 4:48 PM
    #404
    boardude
    Kris
    Tucson, AZ
    [YODAGAN]
    2015 Inferno Ex-Pro
    My shackle bolts are too close for comfort for me. I'm gonna reverse the bolt and see if that works and if not then try the toytecs
    4x4_Angel and Jsena like this.
  15. Aug 20, 2017 at 5:27 PM
    #405
    Flyin808
    Flyin808 New Member
    Nick
    2000 tundra trd
    Thanks for the info definitely my next step is to ditch the blocks on the rear and go to shackles and trim to get a spare under the truck.
  16. Aug 20, 2017 at 6:01 PM
    #406
    CM-LENNY
    CM-LENNY No Complaints
    San Diego, CA
    2015 4x4 CrewMax SR5
    PRO shocks, 37's Nitto G2's 4:88 diffs, few other mods
    Hey Kris you may want to try to cycle your rear suspension as much as possible and do a visual. Looks like even if reverse the bolt, the shackle itself is going to have rub issues. Easiest to try a suspension cycle is find a mound of dirt and get one side to "stuff". Not trying to school you as I know you have done plenty of off-roading, just don't want to see that tire limit your ride or ruin some of that pretty tread o_O
    dcsleeper408 and boardude[OP] like this.
  17. Aug 20, 2017 at 6:29 PM
    #407
    boardude
    Kris
    Tucson, AZ
    [YODAGAN]
    2015 Inferno Ex-Pro
    Yeah I was planning on lowering it in the morn to see how much it's really rubbing after driving on it around town today. I want to cycle it into the rotation so def don't want to mess up the tread. It's more temporary right now and would never wheel with it under there. Most likely it will end up locked up in the bed lol. Good looking out though bud!!
    CM-LENNY[QUOTED] likes this.
  18. Aug 20, 2017 at 6:39 PM
    #408
    DrewKing23
    DrewKing23 New Member
    Andrew
    2014 Toyota Tundra
    Beast Good Shit @boardude we Need To Link Up Soon
  19. Aug 20, 2017 at 7:17 PM
    #409
    boardude
    Kris
    Tucson, AZ
    [YODAGAN]
    2015 Inferno Ex-Pro
    Anytime man! Need to get the Tucson meet going
  20. Aug 20, 2017 at 8:13 PM
    #410
    T-Rex266 Moderator Staff Member
    :spy:
    Be there in a couple of weeks again.
    Eclipsed & Floating likes this.
  21. Aug 21, 2017 at 11:34 AM
    #411
    boardude
    Kris
    Tucson, AZ
    [YODAGAN]
    2015 Inferno Ex-Pro
    Let me know :thumbsup:
    T-Rex266[QUOTED] likes this.
  22. Aug 24, 2017 at 1:32 PM
    #412
    crishard
    crishard Occasional Member
    Cris
    2014 Barcelona Red CM
    3" level in front, ICI Bumper & Skid, 12k lb winch, UCAs, Radtech 2.5s, Kenda 35s, Dual Batteries, 3500w inverter
  23. Aug 24, 2017 at 5:25 PM
    #413
    boardude
    Kris
    Tucson, AZ
    [YODAGAN]
    2015 Inferno Ex-Pro
    I think I had a dozen more lights or so that came on lol.
  24. Aug 24, 2017 at 6:09 PM
    #414
    crishard
    Cris
    I was hoping that you had the same experience & could tell me what is going on. I'm wondering if it's being caused by the hypertech speedo calibrator. It never did this before I installed & it is happening more frequent. Sucks driving to work on the interstate in the am with no speedo & no dash lights.
  25. Aug 24, 2017 at 6:19 PM
    #415
    boardude
    Kris
    Tucson, AZ
    [YODAGAN]
    2015 Inferno Ex-Pro
    Wait your speedo and dash lights don't work? Wonder if you disconnected something by accident durring the install. I would call Hypertech and see what's going on. My dash only lit up like an xmas tree when I first started it back up because the battery was disconnected for nore than 20 mins. That resets everything so it's normal that all the lights came on. It all cleared within a few mins of driving.
  26. Aug 24, 2017 at 6:41 PM
    #416
    crishard
    Cris
    It happened once after I installed last November & I assumed electrical glitch because my door locks are jacked up. Then it happened a few months later & again in another couple of months. Now it happens daily. Sometimes I start up the truck & it's business as usual. Sometimes it's a turd.
  27. Sep 17, 2017 at 2:29 PM
    #417
    boardude
    Kris
    Tucson, AZ
    [YODAGAN]
    2015 Inferno Ex-Pro
    I love the STT Pros. They look amazing and ride quality is awesome especially offroad. A little noisy on the highway and my mpgs tanked after I put these on since they weight like 80lbs a piece. If you're thinking of going the same size (305s) you'll most likely need wheel spacers to help with the offset on the stock wheels and also a CMC. Otherwise 295s might be your best bet and seem to have the best fitment with stock pro suspension and wheel setup.
    Stryker770[QUOTED] and T-Rex266 like this.
  28. Sep 17, 2017 at 5:27 PM
    #418
    boardude
    Kris
    Tucson, AZ
    [YODAGAN]
    2015 Inferno Ex-Pro
    I love sunsets lol
    dcsleeper408, Tacotundra and T-Rex266 like this.
  29. Sep 24, 2017 at 3:53 PM
    #419
    boardude
    Kris
    Tucson, AZ
    [YODAGAN]
    2015 Inferno Ex-Pro
    Having mod withdrawls so decided to paint the All Pro logos on the sliders. Need to find a new project before I do something that requires an explanation to the wife lol
    Jsena, aperezsh, TheBeast and 3 others like this.
  30. Sep 27, 2017 at 3:39 PM
    #420
    DrewKing23
    Andrew
    2014 Toyota Tundra
    looks nice.... bro I need a new battery help me out which one is the best or will get the job done?
