BMC and Go.
Discussion in '2.5 Gen Tundras (2014-2021)' started by ussdgates, Feb 7, 2019.
  1. Feb 7, 2019 at 2:40 PM
    ussdgates
    ussdgates [OP] New Member
    Dave
    2018 TRD Sport
    TRD Pro Exhaust
    I am sure this has been asked a thousand times, but maybe someone could help me answer this question. I have 35/12.5/R17 on the way. I want to install the tires and the leveling kit on my own. Will I be ok doing this before I get the BMC. I would probably be driving around for about a week or two “stock” before I actually get the chop done. My biggest concern is tearing up the new rubbers.
  2. Feb 7, 2019 at 2:53 PM
    3mxdivr
    3mxdivr New Member
    NorCal
    2018 Limited Crewmax TRD Off Road
    Just get the BMC/CMC done before, so you wouldn't have to worry about it rubbing. I installed kings', then chopped (BMC) it, and modified the front inner fender then last are the wheels and tires.
    What offset are your wheels?
  3. Feb 7, 2019 at 3:37 PM
    ussdgates
    Dave
    2018 TRD Sport
    TRD Pro Exhaust
    They are +0 offset.
  4. Feb 7, 2019 at 3:38 PM
    ussdgates
    Dave
    2018 TRD Sport
    TRD Pro Exhaust
    That’s true. I could do the level then do the chop and then put on the wheels. I just want to make sure the shop can see the actual tire I have installed so they can make enough room.
  5. Feb 7, 2019 at 3:43 PM
    3mxdivr
    3mxdivr New Member
    NorCal
    They can only chop the bracket so far because the rubber mount is in the way. If they do that you should clear.
  6. Feb 7, 2019 at 3:46 PM
    3mxdivr
    3mxdivr New Member
    NorCal
    With the 0 offset, they need to get really close. Plus if you have stock skid plates, they need to chop those sides as well.
  7. Feb 7, 2019 at 3:51 PM
    ussdgates
    Dave
    2018 TRD Sport
    TRD Pro Exhaust
    Thanks. I’ve seen it done on multiple 2018s. I just don’t want to do the chop myself.
