Bluetooth problem.
Discussion in 'Audio & Video' started by DevinH18Platinum, May 26, 2020.
  1. May 26, 2020 at 1:15 PM
    DevinH18Platinum
    DevinH18Platinum [OP] New Member
    Devin
    2018 Platinum.
    4 inch lift on 33s
    Hello, so I’m driving down the road talking on the phone on Bluetooth it just suddenly disconnected from Bluetooth and would not reconnect, I get home and had to delete my phone then re pair, I’m thinking this is an iPhone problem hopefully. iPhone XS Max on iOS 13.4.1.
  2. May 27, 2020 at 4:24 PM
    Tigereye
    Tigereye New Member
    Eric
    2019 SSM Limited
    bed liner, diamondback se, level kit, nitto ridge grapplers,tufskinz letters, grab handle
    I loaded the latest iPhone update last week and 2/3 of my calls in the truck get dropped now. I've tried removing and pairing the phone but it didn't help. I have an iPhone 8 plus.
  3. May 27, 2020 at 6:06 PM
    DevinH18Platinum
    Devin
    2018 Platinum.
    4 inch lift on 33s
    I had to turn off Bluetooth, restart my phone and then re pair phone to truck. Definitely iPhone problem.
  4. May 27, 2020 at 11:07 PM
    Muddog
    Muddog New Member
    Bay Area California
    Kings front and Rear BMC Sliders 17s on toyo 35s
    Yup same thing is happening to me. After the update my calls just drop.
    DevinH18Platinum[OP] likes this.
  5. May 28, 2020 at 12:08 AM
    ZappBrannigan
    Canada, by way of Hawaii
    2018 1794 MGM
    NVS light bar
    I have the same problem on the regular.
  6. May 29, 2020 at 4:16 PM
    Tigereye
    Tigereye New Member
    Eric
    2019 SSM Limited
    Called the dealership today. They will load Entune updates on Tuesday and I'll report back on effectiveness.
  7. Jun 6, 2020 at 2:23 PM
    Tigereye
    Tigereye New Member
    Eric
    2019 SSM Limited
    The update at the dealership didn't change anything. I spoke with Verizon and they suggested a Network Reset. The Network Reset seems to have worked. My iPhone is an 8 plus. Hope this helps.
  8. Jun 6, 2020 at 2:31 PM
    biebs96
    PA
    This just started happening to me last week.
  9. Jun 7, 2020 at 1:18 AM
    ZappBrannigan
    2018 1794 MGM
    NVS light bar
    What does a network reset entail?
  10. Jun 7, 2020 at 5:13 AM
    Tigereye
    Tigereye New Member
    Eric
    2019 SSM Limited
    general settings>reset>reset network settings
    Seems to have worked for me but YMMV.
  11. Jun 8, 2020 at 6:13 AM
    biebs96
    PA
    Did a network reset, deleted and repaired the phone. Now it still doing it. Once the call is dropped, the headunit restarts.
    lost.
  12. Jun 8, 2020 at 6:56 PM
    biebs96
    PA
    Fixed!
    Found the answer on a 4Runner forum.
    Turns out the headunit’s memory is flooded when it tries to sync all the contacts (if you have a lot 200+) and then perform another task (phone call, gps) and it crashes and restarts.
    Solution: Delete the phone, on the phone Bluetooth settings, turn off contact syncing, then re-pair it.
    If you want to add numbers into your headunits 4 favorites.
    Add those numbers to your phones favorites, and select “contact syncing” “favorites only” on your phone.
    Hope this helps!
  13. Jun 9, 2020 at 5:48 PM
    Tigereye
    Tigereye New Member
    Eric
    2019 SSM Limited
    I tried your solution. Works so far. Thanks
    biebs96 and DevinH18Platinum[OP] like this.
  14. Jun 10, 2020 at 6:17 PM
    biebs96
    PA
    One more addition to potential fixes if you are still having an issue.
    Co-worker (F250 owner) said his phone calls started doing this all the time, but only on the way or from work.
    Turns out his apple AirPods were the culprit. Deleting them from his phone (AirPods still in vehicle) and his issue was resolved.
    I will say, I have also done this and the issue is gone.
  15. Jun 10, 2020 at 7:45 PM
    Tigereye
    Tigereye New Member
    Eric
    2019 SSM Limited
    I'm back to square one. Dropping calls again at the 2 1/2 minute mark.
  16. Jun 10, 2020 at 7:47 PM
    biebs96
    PA
    Exactly where I was.
    I deleted the AirPods from my phone and the issue stopped
  17. Jun 11, 2020 at 12:55 AM
    ZappBrannigan
    2018 1794 MGM
    NVS light bar
    I don’t have AirPods and have the dropping call problem so I don’t think that specifically is the issue. Maybe multiple Bluetooth devices paired to the phone?
  18. Jun 11, 2020 at 5:05 AM
    DevinH18Platinum
    Devin
    2018 Platinum.
    4 inch lift on 33s
    My problem is still there as well, mine is usually the same spot on the highway I take home from work everyday, it will disconnect from Bluetooth entirely and not do anything. I have to wait until I put it in park, delete my phone on Bluetooth settings and re pair. It’s a massive PITA.
  19. Jun 11, 2020 at 5:57 AM
    TOYOTRD8
    TOYOTRD8 New Member
    Utah
    2017 TUNDRA SR5 TRD OFF-ROAD
    TRD Pro Grilled, Color match bumper end caps, OEM LED headlights, MX4 Bed cover, GoRhino RB20,TRS LED Fog Lights, Camburg leveling kits, SR8 wheels, STT Pro tires 295/70/18 and heritage decal.
    I feel you man. It is PITA and frustrating as the same time. I think it’s tundra head unit. My phone works fine in other car.
  20. Jun 12, 2020 at 7:07 PM
    Tigereye
    Tigereye New Member
    Eric
    2019 SSM Limited
    My issues began the day after I loaded Apple update 13.5.1. I spent 40 minutes on the phone with Verizon. We tried several things before we deleted the last Apple update. It seems that it is working well now.
    Tundra11Racing likes this.
  21. Jun 12, 2020 at 7:18 PM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    Fortunately I have not had this issue (yet - knock on wood) but I do have another question. Is anybody else annoyed by the limited volume on Bluetooth calls? I listen to the radio on about 20, but Bluetooth calls are so faint, I have them turned up to 55-60. I have tried turning my phone volume up but that hasn't helped. Of course it is MUCH worse if the truck is hot and the A/C is blowing harder (and louder).
  22. Jul 1, 2020 at 4:58 AM
    Tundra11Racing
    Tundra11Racing New Member
    Justin
    VA
    2017 Black Tundra SR5 TRD OffRoad
    Katzkin Leather Seats TRD Pro Grille TRD Pro Wheel Caps Color Matched Front End Caps Extang Encore Tonneau Cover
    My issue started as well immediately after I downloaded the latest iPhone Update.
  23. Jul 1, 2020 at 5:20 AM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    What iPhone do you have? What iOS version do you have now? I have an X with iOS 13.5.1, which I believe is the latest without getting beta versions. I am not seeing these issues.
  24. Jul 1, 2020 at 5:24 AM
    Tundra11Racing
    Justin
    VA
    iPhone X with 13.5.1. If anyone finds the fix that works, let me know. It is very frustrating to be dropping calls all time time and the headunit resetting.
  25. Jul 1, 2020 at 12:04 PM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    I would try for a replacement under warranty.
  26. Jul 11, 2020 at 4:01 PM
    TOYOTRD8
    TOYOTRD8 New Member
    Utah
    Try to updating the software from below. After I updated the software, it seems like it working. I was on a called for about 5 mins and it didn’t dropped call.
    https://securedp.toyota.com/download-app/getUpdates
  27. Jul 11, 2020 at 11:00 PM
    jwatt
    jwatt I heart men
    Jack
    Oregon
    This has never happened to me. Though I ve never owned an iphone...problem solved.
  28. Jul 12, 2020 at 5:07 AM
    Tundra11Racing
    Justin
    VA
    Deleting the link to my Airpods has worked so far. Crazy this is the fix.
    biebs96 likes this.
  29. Jul 14, 2020 at 6:26 AM
    Tundra11Racing
    Justin
    VA
    Same problem again. Apparently the Airpods were not the problem. This is so frustrating!!
  30. Jul 19, 2021 at 8:25 PM
    Pitbull410
    Pitbull410 New Member
    2020 TRDPro CM MGM, 2018 LC200 MGM
    Also having this problem and it's seriously pissing me off. Toyota headunit is a piece of shit
    Bluetooth and Alexa(BT connection) both drop after about 30 seconds everytime
    ZappBrannigan likes this.
