Bluetooth Microphone Placement?
Discussion in 'Audio & Video' started by Riskyguy, Oct 27, 2017.
  1. Oct 27, 2017 at 11:07 AM
    Riskyguy
    Riskyguy [OP] New Member
    Stewart
    2018 Tundra SR5 Crewcab
    Where have you mounted your mic for your aftermarket head unit? I am wrapping up for install of the head unit, amp, new speakers, front and back cameras. This is about the last piece of the puzzle. Thanks.
  2. Oct 27, 2017 at 1:36 PM
    dumbassdave
    dumbassdave Member
    Dave
    2016 Crewmax Limited
    I put mine where the stock one was.
  3. Oct 27, 2017 at 4:48 PM
    Riskyguy
    Stewart
    I don't know where that is.
  4. Oct 27, 2017 at 4:53 PM
    dumbassdave
    dumbassdave Member
    Dave
    It's in the overhead console. Little rectangular slots on the left side, facing down
    Pudge likes this.
  5. Oct 27, 2017 at 5:50 PM
    Riskyguy
    Stewart
    Thanks. I will look for it.
  6. Apr 28, 2018 at 7:18 AM
    B737
    B737 Throbbing Member
    Jersey Shore
    2015 Tundra Double Cab Limited
    can you elaborate on this, did you just hot glue the new one in? is there room? did you have to modify the location?
  7. Apr 28, 2018 at 7:52 AM
    dumbassdave
    dumbassdave Member
    Dave
    I don't remember having to modify anything. Pretty sure there was space and I used a small screw to secure it.
    B737[QUOTED] likes this.
  8. May 6, 2018 at 3:19 PM
    bowhun2r
    bowhun2r New Member
    Scott
    Steeler Nation
    apologizes in advance...do not want to high jack thread. Can't you use the OEM mic for an aftermarket head unit? I was planning to go that route.
  9. May 6, 2018 at 3:28 PM
    B737
    Jersey Shore
    I don' think that's possible.
    by removing the 'stand' off the kenwood mic, it fit it right into the overhead stock location getting creative with some o-rings. it works really well in the location, and its great to not see it.
    just unplug it, remove it and stick the new one in with a method of your choosing. you could prob even use hot glue.
    disregard the green arrow (was from another DIY)
    you see mic in bottom left-ish.
    bowhun2r likes this.
