Bluetooth connection on 2012 tundra with oem nav.
Discussion in 'Audio & Video' started by blacktundra2311, Nov 26, 2018.
  1. Nov 26, 2018 at 9:01 AM
    blacktundra2311
    blacktundra2311 [OP] New Member
    Orlando
    2012 Black tundra
    Hello
    I want to know if everyone has run into the same issue I have. I have a 2012 Toyota Tundra with OEM Nav. and recently got an iPhone xs and I can pair the phone to my truck with no problem. I can talk on calls via Bluetooth with truck but I can't stream music at all. I wanted to know if anyone has come across this same issue.
  2. Nov 26, 2018 at 9:23 AM
    TheBeast The Beach
    with your older phone was it streaming fine ? what streaming app are you using ?
  3. Nov 26, 2018 at 9:25 AM
    TheBeast The Beach
    make sure you got latest iOS and streaming app on phone. You can also try to un-pair and pair again the bluetooth.
    bluetooth and iOS can sometimes be finicky.
  4. Nov 26, 2018 at 10:09 AM
    blacktundra2311
    Orlando
    2012 Black tundra
    I had an iPhone 6s before and it worked perfectly since I got the new one this week the streaming of music doesn't work. The only way it can work is to connect directly to USB. I also disconnect the Bluetooth and remove it from the list. Then I reconnect it but still had the same issue.
