BlueDriver Scan in my Tundra 2012
Discussion in 'General Tundra Discussion' started by CautionXP, Feb 20, 2021.
  1. Feb 20, 2021 at 1:46 PM
    CautionXP
    CautionXP [OP] New Member
    Marcelo
    Tundra 2012 4X4
    3" lift OEM Suspension
    Hi guys,
    Hope everything is going well with y'all.
    I got a Tundra 2012 4x4 and I ran the Bluedriver scanner and its showed three different codes
    1 - C1241 Low or High Power Supply Voltage
    2 - C1267 Brake Pedal Load Sensing Switch
    3 P1604 Startability Malfunction.
    Any thoughts about these errors??
    Cheers from Colorado!
    Thanks!!!!
  2. Feb 20, 2021 at 2:47 PM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    battery running low?? I got my battery recharged and they placed some note on it about it might not start car when its hot, or cold, but other than that its OK...
  3. Feb 21, 2021 at 7:30 AM
    couchpotato013
    couchpotato013 New Member
    If you click on the arrows or the code, BlueDriver gives you a repair report about the most likely cause of failure and a guestimate to the part on Amazon.
