blue smoke on startup/starter spins
Discussion in '2.5 Gen Tundras (2014-2021)' started by moredogs, Jan 24, 2025.
  1. Jan 24, 2025 at 1:28 PM
    moredogs
    moredogs [OP] New Member
    Hi all.
    New member here with a couple of questions about my 68K mile 2019 Tundra SR5 Crew Cab 5.7:
    Several times in the last year my truck has released a pretty large cloud of blue smoke on start up. Then it won't do it again for months. It's been pretty cold here lately and it has gotten worse, doing it 3 mornings in a row now. With my reasonable amount of mechanical aptitude, I figure something is sticking in the valvetrain or I've got a bad valve seal(s). Anyone else experience this issue?
    Another thing that happens occasionally is when the key is turned the starter spins like crazy, but the engine isn't starting. The starter will continue to spin without the engine starting up as long as I leave the switch on, until I turn the key back off. After 5 or 6 times, the engine will start normally. Any ideas will be appreciated.
  2. Jan 24, 2025 at 2:39 PM
    Timberline
    Timberline New Member
    Colorado / South Dakota
    2016 Tundra DC TRD Limited ~ 2007 4Runner Sport ~ 2003 Tunda (sold)
    '19 TRD LED headlights, iHacker harness, RCI sliders, Tuffy Security console safe
    is yours FFV by chance?
  3. Jan 24, 2025 at 4:21 PM
    moredogs
    No flex fuel.
  4. Jan 24, 2025 at 4:51 PM
    Timberline
    hm, ok your symptoms sound like the alcohol density is off but that's only in FFV
  5. Jan 24, 2025 at 4:54 PM
    koditten
    Kirk
    Midland of the Mitten
    It's common. Many do this and worry us.
    It's been a while since mine has done the cold start smoke thing.
  6. Jan 24, 2025 at 5:10 PM
    moredogs
    I don't know if that makes me feel any better or not.
    Thanks.
  7. Jan 25, 2025 at 9:23 PM
    lr172
    lr172 New Member
    07 DC
    Blue smoke means oil was getting to combustion area. If you always gaet a small amount of smoke it can be several things. If it only does it at startup, it is usually coming in via the valves.
  8. Jan 25, 2025 at 9:44 PM
    ZappBrannigan
    Canada, by way of Hawaii
    2018 1794 MGM
    NVS light bar
    Valve stem seals tend to cause a small amount of blue smoke in the mornings. Someone on this board had a similar issue though and he said his ended up being the PCV valve.
  9. Jan 26, 2025 at 12:51 AM
    2020_Tundra
    2020_Tundra New Member
    2020 MGM Platinum
    ZappBrannigan[QUOTED] likes this.
  10. Jan 26, 2025 at 6:25 AM
    mgrs
    mgrs New Member
    '20 OR
    I also experienced intermittent blue smoke on startup, but only under the following conditions:
    Heavy throttle/high RPM (>3000) interval followed by less than 10 minutes of easy surface road driving before parking for long enough for the vehicle to cool down completely.
    I used to have a commute that ended with exactly these conditions- accelerating to merge onto a 70-80mph high traffic highway, exiting the highway after a half mile, and parking almost immediately off the highway for the day.
    I experienced it several times when I had to accelerate exceptionally hard to merge and then did not drive until close of business that day.
    My commute has changed and I have not experienced it in two years and roughly 20,000 miles.
    koditten and Nm6300'asl like this.
