Blue Bailey Expedition/Tow Rig Build
Discussion in '2nd Gen Builds (2007-2013)' started by LibertySand, Feb 17, 2017.
  1. Feb 17, 2017 at 8:53 AM
    LibertySand
    LibertySand [OP] IH Support Rig
    Montclair, CA
    07 TRD DC 5.7 Tow 4X4
    I figured I start my build thread now that parts and nick nacks are rolling in. Took me some time but I've also finally gave my Tundra a name. Blue Bailey. Bailey is more of a guys name but I've meet a few girls named Bailey and it worked for my Tundra. Boom! Blue Bailey!
    Bailey-
    Ward, or bailey, a courtyard of a castle or fortification, enclosed by a curtain wall. Outer bailey, the defended outer enclosure of a castle. Inner bailey, the strongly fortified enclosure at the heart of a medieval castle. Motte-and-bailey castle.
    Bailey-
    Sir name or Given name typically Male.
    Here is a present picture of Blue Bailey taken in Johnson Valley, Landers California 2017
    The plan is to have a cross between a Tow Rig for my 72 Scout II and an Expedition Rig when I dont want to do any hardcore wheelin in the Scout. Currently I've been daily driving the Tundra to work and back.
    Tundra:
    2007 Double Cab 5.7 TRD Tow Package Blue Pearl with the short bed.
    Current Modifications when I bought it:
    Bought in 2016. 6" Fabtech lift, Blocked rear, 34" Nitto's, Rockstar XD rims, TRD Air Intake, HID lights, HID lights in Fog lamps also.
    BEFORE:
    Since I bought it I've added lights inside the grille and got rid of the Cockstars for some 17" Bronze Methods and 35" KO2's.
    AFTER:
    List of Future Modifications:
    Expedition / Bed Rack-
    Since the spare 35" Tire is a bit tight to put back under the bed I want to build a rack for the spare and other miscellaneous items. I don't plan on camping in or on the Tundra so this Expedition / Bed Rack will be more to hold Day Camp, Trail items and Rescue items. I also want to have the ability to take the Rack off when I need to use the truck for it's intended purpose, as a truck bed.
    Lights- LED 9" Lights Behind Grille
    I'm not to big on light bars since every ass in Cali has them and is now ruining the off road community by driving around the freeways with their light bars on. Only to give guys like me a bad rap and an easy ticket for not having bars now covered... I like the old look of KC or Hella lights so I found a set of Knock Off ARB Intensity 9" lights, made some brackets and shoved them behind the grille. I did a write up already.... I'll add it to this build soon.
    Transfer Fuel Spare Tire Tank-
    Since these Tundras are pigs and can't get enough Dino-Goo I plan on adding a transfer tank. I live in Cali and since they frown on making lives easier I can't install a non 50 State legal larger fuel tank like the aftermarket 46 gallon Transfer Flow one. It WILL NOT pass visual inspection, trust me, I live in an area where if the smog station see's a small crack in a line you'll have to replace every rubber tube you have. So my plan is, to add a transfer tank where the spare tire used to be under the bed. Then cover it with a skid plate. That's the plan at least. I don't want a transfer tank in the bed as I want to be able to utilize the whole bed when needed.
    Air helper springs-
    So far I have learned that the rear stock leafs aren't strong enough sitting on blocks on the axle while towing. At night I blind every Prius driver on the road since my lights are now shinning up from the sagging rear towing my trailer. So I need air ride helper springs in the rear. Still researching what I want.
    Rear Frame Support-
    So something I have learned about these Tundras is that, even though it say's we can tow 10K lbs doesnt really mean we should. I've read a few stories of guys that pull a lot of weight and the rear frame can bend a bit where the hitch is now no longer parallel with the ground but more pointing at the ground. So since I plan on pulling a load around 10K lbs eventually I am going to channel the rear frame and give it some more strength.
    New Lift-
    Eventually I want a new lift. I dont like the lack of ground clearance in the front form the Fagtech drop down brackets and what not. I'd like to get King shocks all around and aftermarket Upper/Lowers for the front. The rear I'd like to ditch the Blocks and do a Deaver spring lift of chit, maybe a 4 link since I'm down there. Still researching good lifts, there's a few out there.
    Electrical-
    I plan on adding switches to the dash to operate my lights in the grille, power a reverse/camp light, an Amber Dust light in the back, Air Compressor, power for an ARB fridge in the Bed.....
    Communication-
    I already have several hand held Rugged Radios for car to car communication but I'm looking into more powerful 50W in car radios. May be getting my HAM's license also. So this means I'll need to make some sort of bracket inside the Tundra for the radio's.
    So there you have it. Like it, Leave it or Hate it. Lets just see how long and how far this takes me to complete...
  2. Feb 17, 2017 at 8:54 AM
    LibertySand
    Montclair, CA
    So here is my plan for the Bed Rack. I want to hold my Spare tire, 1 - 4 Gallon Rotopax Gas can, 1 - 2 Gallon Water Rotopax Can, 2 SeaHorse Cases (that will have Straps, chains, Tow rope, Tools, Tire Repair Kit etc...) inside them, a Harbor Cheap "Race Jack" style and possible area for some chairs all to be secured tight.
    I made a quick Photochop of what I'd like to do. I'll be making this from flat steel and bent up. Kinda like a large metal battery box. I'll tie it all into the Tundras slide rails with T-Slots that I already have.
    Tundra%20Bed%20Rack%20Side%20Photchop%20_c58bf95e320f350026b3f1cc57fb5943289939dd.jpg
    Update Pic:
    This is the side profile where you can see the Spare tire and a "number wing" that I plan on adding a rear facing Amber inside of.
    Tundra%20Bed%20Rack%20Side%20Photchop%20_442384e1883a08db967b5c346754a955e7e63b76.jpg
    My Rotopax cans that I just got from the Group buy in the other week from here.
    My Harbor Freight "Race Jack" that I will be adding the passenger side of the Bed Rack.
    The 2 SeaHorse cases (kinda like Pelican Cases but way cheaper and better) that I'll have Miscellaneous Tools and Gear in for the Tundra and Rescue Gear.
  3. Feb 17, 2017 at 8:54 AM
    LibertySand
    Montclair, CA
    Reserved for Advertising 2
  4. Feb 17, 2017 at 8:54 AM
    LibertySand
    Montclair, CA
    Reserved for Advertising 3
  5. Feb 17, 2017 at 9:23 AM
    TheBeast The Beach
    I like it. Any plans on getting rid of the chrome ? I think it would look even better with the black fenders and 35"
  6. Feb 17, 2017 at 10:50 AM
    LibertySand
    Montclair, CA
    I've thought about it but it's low on the totem pole of the build. I'm partial for chrome but it works for what I got on it. I may just get some aftermarket bumpers. I thought about getting something for the rear bumper.
  7. Feb 17, 2017 at 5:15 PM
    blue16
    blue16 New Member
    steve
    Mesa AZ
    2016 tundra
    Your truck is looking good . I am liking the rack idea
    LibertySand[OP] likes this.
  8. Feb 17, 2017 at 6:20 PM
    LibertySand
    Montclair, CA
    I'll be doing all my measurements this weekend for the rack. Then have a coworker give me a hand with the Solid Works drawings when I get back into the office.
    I'll also measure for a second rack near the tailgate to hold my 65qt YETI and another locking tray/box for firewood or miscellaneous crap I don't want in the cab. I'll make this rack low also so the YETI's lid is bed rail height. All able to use T Slots in the rails.
    dcsleeper408 likes this.
  9. Feb 17, 2017 at 7:10 PM
    040Tundra
    040Tundra Teddy 2013-2019
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
    I like your truck brutha! Your rack sounds/looks like it's going to be awesome. Can't wait to see it.
  10. Feb 17, 2017 at 8:11 PM
    MotoTundra
    MotoTundra The Ocho
    Don
    I love your truck, those wheels look great! I have never heard of seahorse cases, I need to check them out. Have you ever used them for rifles?
    Also I'm very jealous of the dunes. "Riding dunes" is definitely on my bucket list.
  11. Feb 17, 2017 at 8:28 PM
    This is going to be a sweet build. The color is one of my favorite colors. The Methods with the bronze color have been talking to me.
    Have you considered 4.88 gear swap to tow that kind of weight? Do you currently have a trailer to tow the Scout II? The Tundra frame does flex a lot in the rear (designed that way for overloading), but the people I have heard of bending frames or hitches were grossly overweight.
    The 4.88 gears would also help with the extra weight you are adding with all the accessories.
    Food for thought. I towed 8K behind my Tundra in stock form, but you are not as high in elevation as we are in CO. Your not losing 18-32% of your power.
    zcarpenter92 likes this.
  12. Feb 17, 2017 at 9:03 PM
    Porschetech29
    Porschetech29 New Member
    Francis
    Rancho Cucamonga, CA
    2008 white double cab 4x4
    Looking good. Love the blue with bronze Methods. I think I saw you on the opposite side of the 60fwy earlier this week.
  13. Feb 18, 2017 at 2:04 AM
    dcsleeper408
    dcsleeper408 BASTRDS
    mark
    San Jose CA
    2015 TRD PRO
    I like where you are heading! :thumbsup:
  14. Mar 6, 2017 at 9:42 PM
    LibertySand
    Montclair, CA
    So as usual, time, kids and work get in the way but I've got enough sketches and measurements to get me something I can start with for the Spare Tire Expedition Rack.
  15. Mar 6, 2017 at 9:48 PM
    LibertySand
    Montclair, CA
    Probably was me... my route usually is Resivoir 60 to 57 to 91 to 5 exit Artesia in the Morning. Then reverse that around 5PM on the way home.
    Thanks
    So that being said, I saw the Tundras to Sedona 2017 Promo...
    ....and now I want to make my own Cali Tundra sticker. Curious if someone has one already but in the mean time, I'll make my own. Still working out the details.
    EDIT:
    The color is irrelevant and most likely will be an all white vinyl sticker. I also noticed that the other AZ sticker says TUNDRA"S". I'll be adding an S as well.
  16. Mar 25, 2017 at 4:13 PM
    TheBeast The Beach
    Cali Tundra is a good idea. I would be in for one ;)
    Post the idea in the california sub forum
  17. Mar 29, 2017 at 7:09 PM
    LibertySand
    Montclair, CA
    Had a chance to work on the next phase of the Bed Spare tire storage Rack.
    Modeling in Solidworks. Will be using .120" CRS then powder coat it all. There will be various speed holes and weight reduction holes. I will be using stainless carriage bolts to make it a full bolt in. And T slots to bolt it all onto the inner bed rails.
    dcsleeper408 and ReCKzX like this.
  18. Mar 29, 2017 at 7:24 PM
    ReCKzX
    ReCKzX New Member
    2023 Tundra TRD Pro Ice Cap
    I really like your spare ideas! I want something similar but I need to have room for a dog crate as well.
  19. Mar 29, 2017 at 9:29 PM
    kenomouth64
    kenomouth64 New Member
    Tetrus
    2007 Toyota Tundra Sr5 4x4 (TRD Off Road) Crewmax 5.7L
    Hold the Line! If you are not holding the line, abandon your ship. Destruction is inevitable without more to hold the line!
    Very nice modifications. I love the color and attention to detail. I am sensing that you may have Engineering experience?
  20. Mar 30, 2017 at 12:03 AM
    LibertySand
    Montclair, CA
    You could say that with a Graphics background and working for a Laser Manufacturing company has its benifits. No talent wasted.
  21. Apr 17, 2017 at 10:36 PM
    LibertySand
    Montclair, CA
  22. Apr 18, 2017 at 5:36 PM
    LibertySand
    Montclair, CA
    Hoping tomorrow to cut and bend this masterpiece.
  23. Apr 18, 2017 at 7:02 PM
    LibertySand
    Montclair, CA
  24. Apr 19, 2017 at 1:30 PM
    LibertySand
    Montclair, CA
    It's on!!!
    Black Wolf likes this.
  25. Apr 19, 2017 at 7:23 PM
    LibertySand
    Montclair, CA
    Test fitting. IMG_2927.jpgIMG_2938.jpgIMG_2939.jpgIMG_2943.jpgIMG_2934.jpgimage.jpg
  26. Apr 19, 2017 at 7:28 PM
    blue16
    blue16 New Member
    steve
    Mesa AZ
    2016 tundra
    That is looking sweet.
  27. Apr 19, 2017 at 8:17 PM
    Tacotundra
    Tacotundra New Member
    Vegas
    2022 Tundra
    Nice work!!
  28. Apr 19, 2017 at 10:31 PM
    Spolar
    Spolar Going broke
    Zac
    Seal Beach CA
    2016 sr5
    Looks really clean man. Definitely plan to be checking that out in person next week.
  29. Apr 19, 2017 at 11:25 PM
    aperezsh
    aperezsh Blessed are the peacemakers
    Ali
    cal-exit landed in GA
    16 Tundra SR5 4x4 Crew Max Magnetic Gray Metallic
    A little this and that...Broke now
    Good stuff brother!
  30. Apr 19, 2017 at 11:56 PM
    Thegr8punkin
    Thegr8punkin A G.D.M/Sofa King Cool/COTJ's dreamboat
    Connor
    Northern Colorado
    08 blue sr5 2wd
    2 +5 hp stickers
    Looks sweet nan
