Blown Tire
Discussion in 'Wheels & Tires' started by mrohme, Jun 5, 2024.
  1. Jun 5, 2024 at 9:51 AM
    mrohme
    mrohme [OP] New Member
    I blew a back tire on the freeway and am trying to find the most affordable way to deal with it. I found a great price on the right tire size but its a Firestone and the rest of my tires are Michelin. Will this create any problems for me? Do I need all 4 to be Michelin?
  2. Jun 5, 2024 at 9:53 AM
    AZBoatHauler
    So.Arizona
    How old and how many miles on the tires?
  3. Jun 5, 2024 at 9:57 AM
    mrohme
    About 1.5 years old and 25k miles. I have a brand new spare Micheline full sized tire that I put on for now but wanted to even out the tread in the back so figured I should replace the other as well. So that would be 2 more worn tires in the front, 2 brand new ones on the back but 2 different brands on the back tires.
  4. Jun 5, 2024 at 9:58 AM
    AZBoatHauler
    So.Arizona
    Assuming there is still good life left on the front - that’s what I’d do.
  5. Jun 5, 2024 at 9:59 AM
    mrohme
    Okay, thank you. The tire shop was telling me the firestone had a different tread pattern so it wouldnt be recommended. That didnt make a lot of sense to me if the tread life is the same.
    AZBoatHauler likes this.
  6. Jun 5, 2024 at 10:02 AM
    AZBoatHauler
    So.Arizona
    I’m shocked the tire shop wants to sell you more tires.
    :p
    DogRunner2 likes this.
  7. Jun 5, 2024 at 10:03 AM
    mrohme
    Ha! Exactly. I am just newer to having this truck and didnt want to screw myself by making the wrong choice. Thank you for your help!
  8. Jun 5, 2024 at 10:04 AM
    Tire shop guy is right. Mixing tread and rubber compounds can mess with the traction control system.
  9. Jun 5, 2024 at 11:14 AM
    mrohme
    Oh, interesting! Thank you for the info. I wasnt sure on that.
  10. Jun 5, 2024 at 11:28 AM
    Bprose
    Bprose Old member
    VA
    17 Tundra CM TRD
    Just stick with same size and you’ll be ok. It might look a little ghetto but it shouldn’t hurt anything. I’d go get a used tire, same size, and start planning/saving for a new set of four that suit your needs.
    You may even find a nice set of 4 takeoffs from dealership, tire/rim shop, or this site/ FB marketplace.
    mrohme[OP] likes this.
  11. Jun 5, 2024 at 11:30 AM
    mrohme
    Thank you! I think that is what I am going to do. Things are a little too tight right now so trying to buy some time. Thank you!
