Blown headlamp bulbs
Discussion in '2.5 Gen Tundras (2014-2021)' started by agrestic1, Oct 6, 2022.
  1. Oct 6, 2022 at 4:56 PM
    agrestic1
    agrestic1 [OP] New Member
    2016 CrewMax
    AMP Research PowerStep, AMP BedStep Bumper Step, BedRug Carpet Bed Mat, Bazooka Powered Subwoofer Tube
    Anyone have suggestions as to why I'm blowing headlamp bulbs.. They were both blown a few months ago, Sylvania bulbs... Now driver's side blown...again..NAPA...Thanks..
  2. Oct 7, 2022 at 6:16 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    need more info, have you installed and LED lights anywhere, or any electrical mods/upgrades like lightbars, stereo stuff, anything that is wired?
    Which model bulbs are you using, stock halogen replacements, silverstars or ??
  3. Oct 7, 2022 at 6:58 AM
    agrestic1
    2016 CrewMax
    No LED bulbs installed anywhere..no Mods or upgrades for lights.. I have a 40 watt Kicker stereo Amp thats been there since 2017..same with a 6 inch Bazooka powered sub woofer. AMP Power Steps... Latest were Napa Night Vision Vivid, drivers side out ...Before that were Sylvania, don't recall no receipt, but middle of the road, both low beams were blown.....
  4. Oct 7, 2022 at 8:50 AM
    MRM937
    MRM937 New Member
    2007 limited 5.7L
  5. Oct 7, 2022 at 9:13 AM
    agrestic1
    2016 CrewMax
    Everything available around here is "crap"....It seems to always happen away on a trip or day before a road trip..Thanks I will look into them, especially the LED...
  6. Nov 3, 2022 at 1:33 PM
    agrestic1
    2016 CrewMax
    Follow up...Be sure when you purchase new bulbs read the warranty, register them on line and keep a copy of the receipt.. I had registered the NAPA Night Vision Vivid bulbs, 2 year warranty.. I filed a warranty claim for them and within days I received new bulbs....
    Black Wolf and AZBoatHauler like this.
  7. Nov 3, 2022 at 1:43 PM
    AZBoatHauler
    So.Arizona
    I’ve always heard you should wear gloves when handling incandescent bulbs as the oil from your skin can cause overheating and early failure…
    CNE0207, WILLINH, biebs96 and 3 others like this.
  8. Nov 3, 2022 at 1:44 PM
    This^^^^
    WILLINH and AZBoatHauler[QUOTED] like this.
  9. Nov 3, 2022 at 1:49 PM
    PlatinumPro
    PlatinumPro New Member
    2015 PlatinumPro Crewmax
    Bilstein 6112+5100s, Rigid Lighting, Fuel 20x9 Bronze Blitz
    i've had my run of garbage luck with any of those "premium" incandescent offerings. They're definitely brighter than the oem bulbs but are worth much when they last only 5 months. LEDs last regardless of brand.
    stevesgraytundra likes this.
  10. Nov 3, 2022 at 1:56 PM
    citrusmaster
    citrusmaster New Member
    Tielar
    2015 Tundra RCLB
    I had a 2005 Kia spectra 5 speed that would blow the headlamp bulbs every 3 months or so. The headlight terminals would arc for whatever reason. I always used dielectric grease on the connections but for whatever reason it would still arc.
    Eventually I ditched the connector and soldered small prongs onto the ends of the wires with extra heat shrinking around them and attached those to the headlights. Fixed my issue. Replacing your connector might do a similar job if you see signs of arcing.
    That car went to 225k before I sold it, and it was still running perfectly.
  11. Nov 3, 2022 at 2:11 PM
    stevesgraytundra
    stevesgraytundra New Member
    Stephen
    2021 MGM SR5 CM 4x4
    Some Sylvania “high output” incandescent bulbs have extremely short lifespans, as in 120 hours. Are you using those?
    biebs96 and TTund16 like this.
  12. Nov 3, 2022 at 2:14 PM
    stevesgraytundra
    Stephen
    2021 MGM SR5 CM 4x4
    Are you using LEDs in an incandescent housing?
  13. Nov 3, 2022 at 9:35 PM
    PJSD
    PJSD New Member
    I've used the Sylvania zXe silver/blue - lasted about 5.5 years until one crapped out. Changed them both to the gold series zXe. Let's see how long they last, so far look nice and bright. If they last 5 years or so I think that's pretty good. Definitely brighter than stock. They aren't LED so they aren't super expensive, I think like $70-80.
  14. Nov 4, 2022 at 5:40 AM
    pro2amendment
    pro2amendment Member
    Indiana
    2018 Tundra: 5.7L Flex, MGM Gray DC, Offroad pkg
    Bullet liner
    Or just stick your hand inside the cheap back that came w your lights or any other cheap grocery bag:).
  15. Nov 4, 2022 at 5:18 PM
    TTund16
    TTund16 New Member
    I've bought light bulbs that lasted a few years and then the next batch only a few months. Same brand (Sylvania, etc.) and I never touch the glass.
    I think they all have poor quality control.
    Also like others said the "brighter" ones have a much shorter lifespan if you read the fine prints.
  16. Nov 4, 2022 at 5:42 PM
    Fester
    Fester New Member
    2017 Crew Max
    I have been running Silverstar Ultra's in my trucks, motorcycles and the wife's car for years. I always wipe them down good with alcohol wipes and don't let the bulb touch anything on the way into the socket. They have lasted years in all my applications. I'd like to try LED bulbs but I'm still afraid of the focus/blinding oncoming traffic issues.
  17. Nov 7, 2022 at 7:29 AM
    PlatinumPro
    i am yes.
    The light scatter certainly isn't perfect but with the headlight motors aimed a little lower its no worse than meeting a car/truck running Sylvania Silverstars and far better than the elderly people that obliviously drive the entire year with their brights on.
  18. Nov 8, 2022 at 12:33 AM
    TTund16
    TTund16 New Member
    I'm not sure about the brights but in order to receive social security payments, you must leave your blinkers on. Not their fault ask the government :oldglory:
    PlatinumPro[QUOTED] likes this.
  19. Nov 8, 2022 at 6:51 AM
    PlatinumPro
    lol. its an old trick they use from all the car chase movies. signal one way... go the other! fools 'em every time :cool:
    TTund16[QUOTED] likes this.
