Blown Head Gasket
Discussion in 'General Tundra Discussion' started by Wheat Writer, Mar 17, 2019.
  1. Mar 17, 2019 at 4:26 PM
    Wheat Writer
    Wheat Writer [OP] New Member
    2002 Tundra
    I have 144,000 on my 2002 Tundra. The head gasket blew. The mechanic says he does not recommend repairing a blown head gasket because it creates an uneven pressure and the old engine will not stand up under it. He recommends replacing the engine with a used or rebuilt one.
    I am totally ignorant of these matters, but this makes no sense to me. Is he correct or should I find another garage.
  2. Mar 17, 2019 at 4:49 PM
    Ajkkane
    Ajkkane Old fart.
    Nj
    2014 CM SR5
    I call BS !!!
  3. Mar 17, 2019 at 4:56 PM
    Wheat Writer
    2002 Tundra
    Okay, so he is totally wrong? Is that what you are saying Ajkkane
  4. Mar 17, 2019 at 5:03 PM
    RLHULK
    Rich
    2022 Silverado LT.
    Still rolling stock baby....
    As long as the head is not warped or cracked, or the block is cracked, replace the gaskets and move on. I would replace the water pump and all hoses as well as the thermostat, you are in that deep might as well.
    Wheat Writer[OP] likes this.
  5. Mar 17, 2019 at 5:06 PM
    Nm6300'asl
    Nm6300'asl New Member
    2022 DC SR5 4x4
    Oem tonneau, side steps, spray in liner. Trd skidplate.
    With a blown head gasket, engine temps probably went way high. With resurfaceing the heads and block, all the other dis-re assemble, it might be better for a used/rebuilt engine
  6. Mar 17, 2019 at 5:10 PM
    Wheat Writer
    2002 Tundra
    Thanks for all the comments. The quotes for repair and for the used engine are so close that it is a wash. The issue that is causing me to pause is that the engine is a used, 76,000 miles, but has not been rebuilt. It has simply been pulled from another Tundra. A rebuilt one is north of 6K when all is said and done. I am thinking that I will have it towed to the Toyota dealership and go with the repair.
    NewImprovedRon likes this.
  7. Mar 17, 2019 at 5:30 PM
    phabej
    phabej New Member
    2018 Platnium
    I would go that route. Good luck with whatever you decide on. Cheaper than a new truck lol
  8. Mar 18, 2019 at 6:41 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    I also have a 2002. Can you give us an indication of how you think this happened? This is pretty rare for our trucks and especially rare for only 144K miles. Were there any signs before it blew? White smoke, overheating etc?
    georgiey22 and 15whtrd like this.
