Blown Head Gasket
Discussion in '2.5 Gen Tundras (2014-2021)' started by Andrew_Tress, Oct 31, 2023.
  1. Oct 31, 2023 at 7:29 PM
    Andrew_Tress
    Andrew_Tress [OP] New Member
    Andrew
    2014 Tundra SR5 5.7l
    Has anybody anywhere ever seen this on a tundra 5.7 liter? 2014 SR5. Mine has 185k miles/300k KM and has been maintained to an aircraft level of meticulousness. Rust free. Super clean. Coolant and tranny was flushed on schedule. Literally all highway miles to the point where I wont even drive it if its a distance less than what it takes to warm up to operating temp. Oil changed every 5000 miles or less. I started kicking a misfire code (cylinder 8 misfire), it was intermittent and I figured if i changed the coil and plug it would solve it. Didnt work. No other symptoms, no abnormal temperature fluctuations and never overheated. I drove to the airport (about 40 miles) with no issue and left it in the long term parking to go to mexico for 2 weeks. Come back, its cold outside I fire it up and lots of white steam in the exhaust for about 2 minutes. uh oh. Drive it back home, have the same intermittent misfire issue which resolves when I cycle the engine. Leave it to cool down, few days later (no driving in between) take out my coil and spark plug and put a scope down the hole.. coolant in cylinder. WTF! I am speechless. I need that truck to last me another 10 years, I didnt think head gaskets fail in those engines! I cant find much info online anywhere, dealership said they have never done one and never seen one go. I'm at a bit of a loss. Any ideas anybody? No shops here will even take it because everybody is so booked out. So I'm desperate for advice/answers. Cheers
    from BC Canada
    TK1979 likes this.
  2. Oct 31, 2023 at 7:34 PM
    Sorry to hear about the potential head gasket issue. Any evidence of cam tower leak or prior repair? Have you owned it since new?
  3. Oct 31, 2023 at 7:41 PM
    It is rare, but doing a search on 2/2.5 Gen tundras threads on head gaskets pulled 488 posts about it.
    Repairing will get you that 10 more years. Head gaskets do go at times.
  4. Oct 31, 2023 at 9:13 PM
    Andrew_Tress
    Andrew
    No previous issues known. 1 previous owner, his son was a mechanic and it was a highway princess. I called the previous owner, he was just as surprised as I was. In fairness I have not necessarily determined that it is infact a head gasket and not a cracked head or cam tower. I am not sure which is worse.
  5. Oct 31, 2023 at 9:15 PM
    Andrew_Tress
    Andrew
    If I manage to get it repaired properly.. my concern is that its a DOHC and if the other head gasket goes then I'm fucked. I could do both at once but its financially devastating for me.
  6. Oct 31, 2023 at 9:45 PM
    ZappBrannigan
    Canada, by way of Hawaii
    2018 1794 MGM
    NVS light bar
    I hate to put it so bluntly but, in all honesty, shit happens. This is a mechanical device and mechanical devices wear out and fail. Your odds of failure like these are better with a Toyota but not zero. I would try to make sure it isn’t a cracked head or something of that nature before you dive straight into a headgasket. Do keep us posted.
    if you’re capable of doing the work yourself you’ll save yourself a fortune. If not, it’s not going to be cheap. There’s absolutely no guarantee that this repair will give you another 10 years.
    This is also going to be a huge “while I’m in there” moment. Don’t go overboard, but don’t cheap out either. Use factory parts and get the head surfaced when replacing the headgasket.
    Fobroader and TK1979 like this.
  7. Oct 31, 2023 at 10:15 PM
    Andrew_Tress
    Andrew
    How can I determine if its a cracked head?
  8. Oct 31, 2023 at 10:38 PM
    Ruggybuggy
    Ruggybuggy Seasoned Veteran
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Actually Toyota recommends that you don't resurface the head. It can change valve timing and through cam sync codes.
  9. Oct 31, 2023 at 10:45 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    Yea no resurfacing. Cometic makes thicker head gaskets for some engines. That’s the only way to surface it and not ruin timing
  10. Nov 1, 2023 at 6:31 AM
    ZappBrannigan
    2018 1794 MGM
    NVS light bar
    In fairness I’ve never worked on these 5.7s
    I have, however, used the thicker head gaskets with mixed results. I have never had any kind of luck putting a head back on without resurfacing. YMMV.
  11. Nov 1, 2023 at 11:56 AM
    Andrew_Tress
    Andrew
    Where are you getting that info from?
  12. Nov 1, 2023 at 12:43 PM
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    From the service manual. I’m a just retired Toyota Pro tech.
  13. Nov 1, 2023 at 12:59 PM
    Andrew_Tress
    Andrew
    hey man thanks for letting me know. I am staring down the barrel of a few tough decisions and I need some advice. Have you done head gaskets in a 3ur-fe before?
  14. Nov 1, 2023 at 1:51 PM
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Not myself but have seen the job done by other techs in our dealership. I specialized in front end and alignment at our dealership although Ive got stuck doing head jobs when our engine tech was off, just not the 3UR. The reason you shouldn't shave the head down is because it moves the cams closer to the crank because you have removed material. The timing chain will have a slight difference in distance to travel and the ecu will read the cam sensor and crank sensor out of sync. Toyota motors are very sensitive to out of sync conditions and will even set the code on high mileage engines that have timing chain stretch.
    Rdrcr, equin and Saltyhero13 like this.
  15. Nov 1, 2023 at 3:34 PM
    Andrew_Tress
    Andrew
    Interesting. I have been told that you absolutely have to refinish the head when you do it. Do you know how I can access the service manual? Is there a step by step guide to doing head gaskets in a 3UR-FE? I am considering doing it at home with a mechanic friend in his garage. Need to know about special tool requirements ETC.
  16. Nov 1, 2023 at 3:52 PM
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Refinishing on an old push rod engine is probably where you got that info from. When you have the head off have it professionally cleaned and they can check to make sure the head is straight. Unlikely you will have a warped head. As for a the manual, you can buy a subscription from Toyota that will give you access to the service manual.
    Saltyhero13 likes this.
  17. Nov 1, 2023 at 4:08 PM
    Andrew_Tress
    Andrew
    essentially what i was told is that I should send the head to a professional engine shop that the toyota dealership here works with to have the cylinder head refinished jet washed and pressure tested and the valve seals refinished and tested.
  18. Nov 1, 2023 at 4:25 PM
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Cleaned, not refinished. Just remove any head gasket material. I would skip pressure testing and valve seat work unless you have very high mileage. It's just not a problem on that motor. If you do have a ton of miles on it, it will probably be cheaper to find a used motor with low mileage.
    equin, TK1979 and Saltyhero13 like this.
  19. Nov 1, 2023 at 6:23 PM
    Bulldog9
    Bulldog9 "My other car is a Porsche"
    NOVA
    2017 TRD PRO in Cement
    see sig for mods.....
    Classic Head Gasket issue............ Get them done, drive another 180K
  20. Nov 2, 2023 at 4:35 PM
    Adamace1
    Adamace1 New Member
    2021 SR5 Tundra doubleCAB
    None....
    The car care nut just did a video on this. He said don't resurface it. But you have to carefully check it to make sure it's still flat or true.
  21. Nov 2, 2023 at 5:14 PM
    Johnsonman
    Johnsonman New Member
    Austin
    Sequoia
    Hope it didn't 'overheat' slightly and crack a head, best of luck.
    ZappBrannigan likes this.
  22. Nov 3, 2023 at 7:12 AM
    cmiles97
    cmiles97 New Member
    2018 Toytota Tundra SR5 4x4 XP
    XP package
    IsaiahCanada and Saltyhero13 like this.
  23. Nov 3, 2023 at 7:32 AM
    2mchfun
    FWIW, I bought a complete set of paper factory service manuals on eBay. It's expensive and about 7 volumes, but it covers the entire truck from A-Z. For me it's a better investment than paying shop labor for a Toyota tech. Good luck with the repair!
    vtl, yakeng and Saltyhero13 like this.
  24. Nov 3, 2023 at 8:49 PM
    Andrew_Tress
    Andrew
    THanks man I love that guy, could you link me the video? the plan at this point is to send it to an engine refurb shop and have them pressure test it and all the valve heads.
  25. Nov 3, 2023 at 8:50 PM
    Andrew_Tress
    Andrew
    I'm very confident it didnt overheat
  26. Nov 4, 2023 at 12:22 AM
    blenton
    blenton New Member
    That is interesting. Makes sense, though.
    @Andrew_Tress Bad luck about the head gasket. Every once in a while one pops up on the forum but they aren’t common. As expensive as it is to, it’s still cheaper than a new truck. But I would still be quite disappointed as well.
    @Ruggybuggy - mind if I send I PM you a few alignment/front end questions?
  27. Nov 4, 2023 at 7:19 AM
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    NP
  28. Nov 7, 2023 at 12:02 PM
    Pr4sno
    Pr4sno New Member
    Loveland, CO
    Have you drained the engine oil? You can send that oil in to blackstone labs for analysis to see if there is additional wear debris. It is about a $30 round trip test and can help inform the decision more. They will provide a breakdown on what metals are in high concentrations per the mileage on the fluid and you may glean some information on if the coolant has caused accelerated wear anywhere else, or if you caught it really early and its just effecting ignition of fuel in the cylinder.
  29. Sep 7, 2024 at 10:25 AM
    Tunrod
    Tunrod New Member
    Rod
    2021 SR5 CM 4x4
    Car Care Nut just released a video saying this is a common issue with 2UR :(
    IsaiahCanada and 1UP like this.
  30. Sep 8, 2024 at 12:32 PM
    Rph74
    Rph74 New Member
    Springfield,MO
    2007 Tundra Crewmax Limited Silver/Redrock
    I just watched this vid yesterday, and it was very concerning. I would like to hear from those who have had HG failures as to how often the coolant was changed. Carcarenut stated that dealership intervals are too long, needs to be done sooner.
