Blown engine dilemma......
Discussion in 'Off-Topic Discussion' started by Tracker, Apr 4, 2017.
  1. Apr 4, 2017 at 2:21 PM
    Tracker
    Tracker [OP] New Member
    Shane
    Colorado, Denver Burbs
    2016 Silver Tundra SR5 Lifted
    I just don't know what to do. I have a 2003 GMC Envoy with 90k miles on it. The oil ran low causing a severe knocking. We took it in and spent $2,400 on differential seal, tranny flush, oil change and some little stuff. They said let the new oil work with Lucas oil additive. Well it got worse the next day. Now they say $3k to tear engine open and diagnose or new engine for $8,200. The Envoy looks brand new and is loaded but probably only worth $6-8k running. So I lost $2,400 and now have no trade in for a new car Any suggestions?
  2. Apr 4, 2017 at 2:26 PM
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
    Donate and claim as tax deduction next year and use return to get something else?
  3. Apr 4, 2017 at 2:37 PM
    xj2202009
    xj2202009 New Member
    x
    Lutz, Fl
    2017 tundra sr double cab v8 5.7L black 4x2
    looking to replace factory Radio with a pioneer avix588bhs
    Go to GMTNation they can help...seems a lot of $ for simple work. I had my trainny rebuilt, servo upgrade and new trainny cooler put in all for $2k
  4. Apr 4, 2017 at 2:41 PM
    xj2202009
    x
    Lutz, Fl
    Inline 6 is a really hard engine to kill..I know they are know for the exhaust manifold to become lose and might cause knocking
  5. Apr 4, 2017 at 4:59 PM
    bobeast
    bobeast really old member
    Bob
    Hollister, CA
    2008 DC
    The cost to repair exceeds the value of the vehicle which effectively renders it worthless. Time to cut bait. Either that or start shopping around for a used engine.
    Wynnded likes this.
  6. Apr 4, 2017 at 5:24 PM
    Tracker
    Shane
    Its not that, its very loud like a rod slapping around inside
  7. Apr 4, 2017 at 6:10 PM
    Rngr188
    Rngr188 Ranked the best new member of all time
    Chad
    Harrison AR
    2020 1794 MGM TRD OR
    Damn bud, I just traded a 2007 Envoy Denali with the 5.3L V8 that had only 67k miles a week ago for my new Tundra. Retail was around $11.5k they gave me $8.5k. I would've sold it in a heartbeat if I had a buyer but didn't want to go through the hassle.
  8. Apr 4, 2017 at 6:39 PM
    xj2202009
    x
    Lutz, Fl
    I would just buy a used motor.. Specially the inline 6 I have seen go as low as $400
  9. Apr 4, 2017 at 6:40 PM
    Well Shane, the 4.2L motor was a problematic one with engine sludge issues among other problems.
    The way I see it, buy used motor with warranty, do a R&R and sell it, find a reman'd motor and do the R&R and keep it, or pay a shop big money for a motor removal and replacement and have more into a vehicle than its worth.
    Personally, I would go with finding a used motor and dump it.
  10. Apr 4, 2017 at 7:25 PM
    MotoTundra
    MotoTundra The Ocho
    Don
    That's an unfortunate spot to be in. What do you think you could get for a trade?
    Have you tried any other places? $8,200 seems high for a motor and swap.
    ColoradoTJ likes this.
  11. Apr 4, 2017 at 8:39 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    Lots of used 4.2L's on ebay for under $1K, but I'd try find one at a reputable wrecker close to you.
    Agree 100%
  12. Apr 4, 2017 at 9:21 PM
    FlashCulprit
    FlashCulprit ColoradoTJ's whipping boy/Gino's illegitimate son.
    Joe
    Salt Lake City, UT
    2010 Super White SR5 TRD 5.7 4x4
    Way to high for a GM block/engine... There's a lot of options. But I'm with @ColoradoTJ on this one.
  13. Apr 5, 2017 at 1:50 AM
    The cost is usually the labor of removing and installing.
    When customers would come in with dead cylinders, I would see grown men cry. A remanufactured 24V Cummins was 4400.00 plus 26 hours R&R at shop rate (100-140 hour). A common rail diesel motor is even more.
    I looked into motor replacements for my Tundra. Holy hell I made sure the oil changes were done by me and correctly. I was seeing 100-140k mile motors going for over $5k. I don't know what book time is on that with the Tundra for R&R.
    Same with my current truck. Hell, the upgrade from gas to diesel is 10000.00.
    I couldn't find a LML duramax motor, but here is a lightly broke in 180k mile LB7 motor for 4500.00.
    http://m.ebay.com/itm/142327001799?...93&_trksid=p2385738.c100694.m4598&_mwBanner=1
    MotoTundra[QUOTED] likes this.
  14. Apr 5, 2017 at 3:48 PM
    bobeast
    Bob
    Hollister, CA
    2008 DC
    26 hours seems pretty steep for a motor swap. Back in the day, I could do it with a weekend and a six-pack. Have things changed that much?
  15. Apr 5, 2017 at 4:01 PM
    To remove the Cummins motor from a Ram truck is not easy. I thought the same thing. Remove radiator, front support, hood, the head needs to be removed first, shoe horn that out. Disconnect motor and pull. It is pretty time consuming. My friend could do it in way less time (as most mechanic can). That was just book time.
    Same sequence when installing except for the head torquing.
    I'm pretty sure it was 26, but I may have been mistaken for 22.
    Crazy huh? Back in the day we could pull a chevy V8 pretty quickly.
    Now for shop time on some trucks, just to get to the motor is 4 hours for cab off and another 4 hours cab on.
  16. Apr 5, 2017 at 5:01 PM
    bobeast
    Bob
    Hollister, CA
    2008 DC
    Crazy indeed. As you get older you have more money to pay for labor, and less muscle to do it yourself. I suppose there's a nice symmetry to that. My days of running out to rent a cherry-picker are long gone.
  17. Apr 5, 2017 at 6:10 PM
    100% the reason you own a Tundra so you don't have to sweat that crap.
    :mudding:
    T-Rex266 and bobeast[QUOTED] like this.
  18. Apr 5, 2017 at 7:15 PM
    So I did a little research on this, 26-30 hrs is about right...:eek:
    Motor cost for a 6.7L Cummins
    http://www.dieselpowerproducts.com/...-engine-long-block-and-all-related-parts.aspx
    Short blocks are cheaper of course.
    Shane's motor would be much easier to R&R if he wants to go that route.
