Blowing tow/haul fuse
Discussion in 'Towing & Hauling' started by Benstoy, May 26, 2019.
  1. May 26, 2019 at 6:35 PM
    Benstoy
    Benstoy [OP] New Member
    2008 Tundra Crew Max 4x4
    3/1 ready lift, added step bars, blue tooth, back up camera, assault roll up tonneau cover...has spray in liner, fender flares, leather
    I've never used the 7way connector before, so when I discovered that my new trailer didnt have running lights, I checked the fuses. Blown. When I replaced it, it immediately blew again. What should I check next? Would there be a bare wire somewhere on the truck maybe?
  2. May 26, 2019 at 7:36 PM
    Benstoy
    Yes, it was with the trailer plugged in. The brakes and blinkers work, but no running lights (which I assume is this fuse). I applied 12 volts to the running lights on the trailer and they came on nicely, independent of the truck. So i guess i am chasing that running light wire through the trailer?
    Thanks
    Watt maker likes this.
  3. May 26, 2019 at 9:22 PM
    Black@Blue19
    Black@Blue19 Old Salt
    Ken
    SE Texas
    Bum wire or grounding problem with the trailer? Sometime trailers can be a PITA!!!
  4. May 26, 2019 at 9:42 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    So I had a trailer blowing my fuses like crazy. There was 2 frayed wires in the trailer side of the harness I didn’t see that were contacting in turns
  5. May 26, 2019 at 10:03 PM
    JH5370
    JH5370 Member
    Josh
    Eastern WA
    2017 White DC TRD PRO
    I had this same issue and it was a corroded wire in the plug itself. Rewired the plug, replaced the two/tail fuse and all was well.
  6. May 27, 2019 at 6:07 PM
    Benstoy
    Found it. The running lights wire had a rub spot in it and it was grounding. Taped it up and viola. Now my back is not happy about my gravel driveway, lol.
