Blower motor strength
Discussion in '2nd Gen Tundras (2007-2013)' started by tallguy240, Jun 21, 2021.
  1. Jun 21, 2021 at 9:14 AM
    tallguy240
    tallguy240 [OP] New Member
    Patrick
    2009 Grey Tundra Limited
    Projector Style headlights, leveling system, LED Fog Lights, LED interior lighting, Toyota emblem projector door/puddle lamps, LED puddle lights in rear view mirrors, Tonneau Cover, Bed LED lighting, 3 inch lift, trailer braking system, and aftermarket audio system.
    Hello Everyone - I have a 2009 Tundra Limited Crew and when I crank the blower up to max it just doesn't seem to blow out air as heavy as I feel like it should. I particularly notice this when running recirculated max A/C. I realize its a huge cab but the air strength/speed coming out of the vents under the max setting seems lower than it should be. Is this normal for the Tundra's or I am just expecting more than the blower motor is capable of doing. The airflow in the rear vents feels like it is just barely coming out. I do not have a frame of reference for other Tundra's as this is the first I have owned. Thanks!
  2. Jun 21, 2021 at 10:03 AM
    Taco-Blender
    Taco-Blender Old Guys Rule
    AZ
    2010 DC 4x4
    Have you checked your cabin air filter? Awhile back I thought my blower was getting pretty weak and I was ready to order a new one. I pulled the cabin filter and it was absolutely clogged with crap. Threw a new one in there and currently enjoying a good, strong, cold, airflow in our 114 degree temps.
    Life is good again...
    BlueCrushSC16 and JimboSlice413 like this.
  3. Jun 21, 2021 at 11:59 AM
    tallguy240
    Patrick
    Funny you mention that. I just put a new one in like 2 weeks ago. Well let me rephrase. I have a K&N cabin air filter that I cleaned and recharged and put back in. I had pulled it and put the OEM style in until I got the cleaner solution for the K&N and there was no difference in air flow that I remember. I am going to swap a paper one back in and see if its different though. Thanks!
  4. Jun 21, 2021 at 12:29 PM
    TXTundra2722
    2015 Black Tundra
    This isn't 100% the issue... but if you don't have any clogs in your vents, your blower motor might be on its way out. Mine is doing the same thing. It sometimes never fully gets up to speed and other times it blows full force and then starts slowing down. I've been researching this and seems to be a fairly easy swap for a new one. One piece of plastic molding to remove and then three bolts holding the motor and disconnecting the electrical connection
  5. Jun 28, 2021 at 5:08 PM
    Bgkahuna11325
    Bgkahuna11325 New Member
    Gene
    2011 Toyota Tundra SR5 Crewmax
    When you run the AC in recirculation mode (MAX), you will notice diminishing blowing performance as the evaporator freezes. Switch it to allow outside air in and this problem goes away. More noticeable in areas of humidity. Make sure the drain isn't clogged too.
  6. Jun 28, 2021 at 5:12 PM
    tallguy240
    Patrick
    Thanks Bgkahuna11325 I will give this a try. it is very humid here in MO currently. I will also check that drain.
  7. Jun 28, 2021 at 7:06 PM
    TXTundra2722
    2015 Black Tundra
    I just changed my blower motor out ($130 autozone) and this took maybe 20 minutes tops to change out.... if that. Pretty sure it took longer to get my tools out and then put back up versus the time actually working. My a/c blows hard now, just like a hooker would for the last line of coke.
    :benchpress:
