Blower Motor Making Noise.
Discussion in '2nd Gen Tundras (2007-2013)' started by ICECOLDBEER, Dec 23, 2024.
  1. Dec 23, 2024 at 12:12 PM
    ICECOLDBEER
    ICECOLDBEER [OP] New Member
    2009 Toyota Tundra TRD Off Road 5.7 4x4 Double Cab
    My blower motor/fan is making a weird noise. The filter was pretty dirty and I can see some leaves stuck in the fan. Any good way to clean it out? I tried a vacuum/air compressor no dice.
    Safe to keep using it? Will i damage it? I have to drive it for work right now unfortunately.
  2. Dec 23, 2024 at 12:38 PM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    Use it until it stops working or you can't handle the noise from the leaves. If you are patient you might be able to pick the leaves out. Use it as you need to, I would not worry about leaves damaging it unless they fully block its ability to turn/run.
    Being a 2009, it is probably original. Blower is easy and inexpensive to swap out when you have time.
    https://www.youtube.com/watch?v=czW53kMugVU
    Cruiserpilot and ICECOLDBEER[OP] like this.
  3. Dec 23, 2024 at 6:28 PM
    Cruiserpilot
    Cruiserpilot New Member
    Jon
    Ladysmith
    2010 5.7 RCSB 4WD
    Thanks for posting, especially the video. Mine is squeaking, I’ll pull it it and clean now I
    have decent instructions
  4. Dec 24, 2024 at 7:39 AM
    COTundie
    COTundie Whoa Black Betty
    Trey
    Black 5.7 DC TRD 4x4
    Pretty things
    Cruiserpilot likes this.
  5. Dec 24, 2024 at 9:49 AM
    Cruiserpilot
    Jon
    Ladysmith
    2010 5.7 RCSB 4WD
    Being in Canada has real disadvantages one major being we don't get the sales south of the 49th enjoy. It's bad enough
    we lose close to 40% on dollar exchange ++ profits the oh so poor dealers struggle for. I've bookmarked that thread
    but what I'm also doing is making a definitive parts list for next years 25%+free shipping deal so I can have an
    organized bunch of parts I am able to put off until next year. On a single muffler I saved over $225 this year.
    ZappBrannigan likes this.
  6. Dec 24, 2024 at 12:56 PM
    VWTim
    VWTim Mid-Travel Crew
    Corvallis, OR
    Is it a rhythmic clicking from leaves and debris hitting the fan blades? If so, drop the fan, remove the debris, and reinstall. It's like 3-4 Phillips screws,.I've done it a couple times on road trips when the clicking drives me crazy.
  7. Dec 26, 2024 at 12:20 PM
    Stevebaseball
    Stevebaseball New Member
    Arizona
    2008 Tundra crewmax
    3” lift- 35 x 12.50 on 18” custom rims
    Very easy to remove and clean or replace- most aftermarket ones work just as well..
