Block or shackles?
Discussion in 'Suspension' started by 040Tundra, Jan 26, 2017.
  1. Jan 26, 2017 at 8:30 PM
    040Tundra
    040Tundra [OP] Teddy 2013-2019
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
    What's better for towing? Or does it even matter?
  2. Jan 26, 2017 at 8:38 PM
    MotoTundra
    MotoTundra The Ocho
    Don
    I'm not a suspension expert but the block does nothing but raise the back end. The shackles will raise it but probably give a better ride quality compared to the blocks.
    I think an add a leaf or air bags would be the only thing that will stiffen up the rear to support the extra tounge weight.
  3. Jan 26, 2017 at 8:44 PM
    Ardnut
    Ardnut New Member
    TX
    If it's for towing only, airbags and cradless for them.
  4. Jan 26, 2017 at 9:23 PM
    040Tundra
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
    Yes, add a leafs and air bags are better for towing. I'm trying to decide whether to go with a block for the rear or shackle on a 3.5/1.5 I'm looking at. Just was curious if either are better whilst towing. Sounds like not.
  5. Jan 26, 2017 at 9:27 PM
    MotoTundra
    MotoTundra The Ocho
    Don
    Sorry, my bad.
    Hopefully some of the suspension guru's on here will chime in....
  6. Jan 27, 2017 at 6:07 AM
    040Tundra
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
    No worries. You're right though. Maybe I should add airbags to the rear of my truck.
    Ardnut and MotoTundra[QUOTED] like this.
  7. Jan 27, 2017 at 6:16 AM
    xtyfighterx
    xtyfighterx New Member
    Ty
    North Idaho
    2015 Black Crewmax Mid Travel
    Airbags or a leaf pack. Shackles preload your leaf springs you won't really get a better ride out of a block or a shackle. If you are towing a leaf pack or air bags are what I'd put on. But a shackle is better than a block if you decide to pick one of the two
    ColoradoTJ and MotoTundra like this.
  8. Jan 27, 2017 at 6:17 AM
    040Tundra
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
    Thanks for your input!!
    MotoTundra likes this.
  9. Jan 27, 2017 at 6:52 AM
    Chaosx4
    Chaosx4 New Member
    2016 White Tundra SR5 TRD
    I have kings 2.5 on fronts and tears with the coachbuilder shackles; not complaints here! I guess the real question is what are you towing? If it's the occasional trailer and toys, not sure airbags are necessary. But if it's a toy hauler or bigger camper, then it's a must.
    I have been looking at these for a while and wonder if anyone has an opinion on them...
    http://timbren.com/tag/toyota-tundra/
  10. Jan 27, 2017 at 6:57 AM
    Ardnut
    Ardnut New Member
    TX
    I went with the block and airbag route, tow a 9k trailer once a month. If you do go with airbags along with the shackles or blocks just make sure to get the cradles. Either way you'll probably want the drop carrier kit. Although there is one company who makes a tapered 1" block to help keep the axle at the proper angle as well as a longer air bag bracket so it still contacts the axle for support.
    Pictures here:
    https://www.tundras.com/threads/ardnuts-tow-hunt-rig.6348/#post-166725
  11. Jan 27, 2017 at 7:03 AM
    Ardnut
    Ardnut New Member
    TX
    Looks like bigger bumper stops, wouldn't that take away from the travel?
  12. Jan 27, 2017 at 7:04 AM
    040Tundra
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
    Thanks for the link!!
  13. Jan 27, 2017 at 7:05 AM
    040Tundra
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
    Thank you sir......
  14. Jan 27, 2017 at 7:19 AM
    Well, let me chime in here.
    I had the CB 2" shackles. The truck had a better ride, but that was probably due to the 5160 shock installed. Now here is the but: my truck never towed the same again, and not in a good way.
    Now to be fair, I also was at the maximum limits of my truck, especially with my flatbed trailer and Jeep. 8500lb+
    My camper wasn't as bad even though it is a huge wind sail, but it was lighter.
    In my opinion, lifting a truck and using for towing, spring packs should be swapped out. My 1999 Tacoma was needing some help in that department and I ordered some leaf packs from Alcan Springs in Colorado, never happier. I tried some other options and just ended up breaking springs.
    It isn't cheap to lift a vehicle properly, and it really isn't cheap if you plan on towing with it. There is a reason I have a designated off-road vehicle and a designated tow vehicle. Trying to mix them both is like putting oil and water in a blender.
    01erionracing, Sas, Sunnier and 3 others like this.
  15. Jan 27, 2017 at 7:58 AM
    J4RR3N4
    J4RR3N4 New Member
    South east Texas
    14 Tundra
    3” lift on 35’s
    Stay away from blocks period. They will de-arch your springs eventually
  16. Jan 27, 2017 at 8:36 AM
    xtyfighterx
    Ty
    North Idaho
    If U get a block or shackle keep the lift around 1-1.25in and make sure your shocks can accommodate for that lift
  17. Jan 27, 2017 at 8:43 AM
    J4RR3N4
    J4RR3N4 New Member
    South east Texas
    14 Tundra
    3” lift on 35’s
    X2. Make sure your shocks are going to work still.
  18. Jan 27, 2017 at 9:06 AM
    xtyfighterx
    Ty
    North Idaho
    Change out your bumpstops as well makes a big difference
