Block Heater
Discussion in '2.5 Gen Tundras (2014-2021)' started by alpinepro4, Jan 19, 2025.
  1. Jan 19, 2025 at 10:39 AM
    alpinepro4
    alpinepro4 [OP] What is your MPG Today!
    Pat
    2017 TRD Pro Cement DC
    Baja Designs Squadron Sport Fog lights, ARE CX Series Topper, Alcan Springs , DAP Tune, Coach Builder +1 Shackles, Headlight Revolution Supernova V.4 LED bulbs, HR LED interior bulbs. General Grabber ATX 275/70/R18
    My block heater has stopped working. What fuse should I check? Going to get real cold tonight.
  2. Jan 19, 2025 at 10:45 AM
    Mr Badwrench
    Mr Badwrench New Member
    Your block heater is not externally powered? I thought they all plugged in to an external AC power source.
    Wynnded and BrandonL812 like this.
  3. Jan 19, 2025 at 11:17 AM
    BrandonL812
    BrandonL812 New Member
    Brandon
    2021 Tundra Platinum
    Is this a Canadian vehicle?
  4. Jan 19, 2025 at 12:49 PM
    alpinepro4
    Pat
    No, American
  5. Jan 19, 2025 at 2:47 PM
    alpinepro4
    Pat
    Ok that makes sense, block heater could be dead then.
  6. Jan 19, 2025 at 4:52 PM
    BrandonL812
    Brandon
    Was it an added feature? Or aftermarket?
    Ive had oem block heater on previous toyota, and you have to always plug it into the house outlet to keep it going.
    What make you think it’s dead? I’m curious.
  7. Jan 19, 2025 at 5:23 PM
    alpinepro4
    Pat
    Aftermarket heater. When I plug it in I hear silence. Also seem like the truck should start up more chipper then it does. Are you suppose to get some warm air if left on all night?
  8. Jan 19, 2025 at 5:25 PM
    Betting the cord/element went bad. Your truck will start though.
  9. Jan 19, 2025 at 5:32 PM
    BrandonL812
    Brandon
    You should be able to feel a little warm, not much, on the engine block. But not warm air. It’s not supposed to heat up the coolant to normal working temp. At least that’s in my experience. i would follow your cord and see where the heating element is mounted to the block. If you are able to access it, carefully wave your hand over it. See if you can feel some heat?
    Otherwise, coloradotj said, element/cord took a dump.
  10. Jan 19, 2025 at 5:57 PM
    alpinepro4
    Pat
    How do I replace the element in the cord?
  11. Jan 19, 2025 at 6:01 PM
    bfunke
    bfunke Tundra Curmudgeon
    South Carolina
    If the element is bad you have to replace the entire unit.
  12. Jan 19, 2025 at 6:01 PM
