blinking lights on the panel
Discussion in '2nd Gen Tundras (2007-2013)' started by thomazsarkis, Mar 9, 2018.
  1. Mar 9, 2018 at 6:50 AM
    thomazsarkis
    thomazsarkis [OP] New Member
    thomaz kleber
    Silver Spring
    tundra v8 5.7
    nothing
    good morning friends.
    I have a 5.7 V8 tundra, and I have all the panel lights on.
    I put the Scaner in the car and follow the images with the error codes.
    I read some related topics, saying to change the fuel tank cover. I changed the cover and reset the codes through the scanner. but after 15 minutes driving the car all the lights came back to flash.
    Would you have any suggestions where to start to solve this problem?
    thank you
  2. Mar 9, 2018 at 6:57 AM
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
  3. Mar 9, 2018 at 7:30 AM
    Or AIP.
    TheBeast likes this.
  4. Mar 9, 2018 at 3:47 PM
    thomazsarkis
    thomaz kleber
    Silver Spring
    tundra v8 5.7
    nothing
    Tks e30cabrio.
    It is quite cold here. I had read this topic too. Through it I changed the fuel tank cap to see if it would get any better. See if my reasoning is correct? Should a problem occur in the system, should not the light of the injection light only? Why does it light up almost everything, including traction?
    thank you
  5. Mar 9, 2018 at 3:47 PM
    thomazsarkis
    thomaz kleber
    Silver Spring
    tundra v8 5.7
    nothing
    What is AIP?
    Tks
  6. Mar 9, 2018 at 3:53 PM
    TheBeast The Beach
    looks like dreaded AIP issue. what year is your Tundra ? it might be covered under warranty.
    thomazsarkis[OP] and Black Wolf like this.
  7. Mar 9, 2018 at 4:05 PM
    Air Injection Pump. There are two.
  8. Mar 9, 2018 at 5:35 PM
    thomazsarkis
    thomaz kleber
    Silver Spring
    tundra v8 5.7
    nothing
    Tks Matlut.
    The year is 2009. Do you have any video or procedure that I can perform to try to repair it?
    thank you
  9. Mar 9, 2018 at 6:34 PM
    TheBeast The Beach
    you should be covered under warranty. they extended it 10 years IIRC.
  10. Jun 7, 2019 at 6:15 AM
    AJ xKHAOSx
    AJ xKHAOSx New Member
    AJ
    2011 Grey Tundra
    20 inch Ultra rims on 33 BFGoodrich all terrain tires, JVC double din.
    Dealing with this issue on my 2010 right now. I just rolled over 150,000 (153,000) and Toyota told me yesterday that they only cover up to 150,000. I get it but it sucks I'm just over. Looks like I’ll be taking care of it on my own even though it’s a known issue by Toyota and I’m just over.
    Any pointers would be super awesome.
  11. Jun 7, 2019 at 7:57 AM
    e30cabrio
    Did you contact Toyota corporate? They good willed my Camry Hybrid battery similarly out of warranty.
    Good luck.
  12. Jun 7, 2019 at 8:23 AM
    AJ xKHAOSx
    AJ
    2011 Grey Tundra
    I did. My local dealership gave me their number. I pleaded my case for 45 minutes with them yesterday but they said that because I was over the mileage that there wasn’t anything they could do.
    Sucks knowing that they are aware that there is an issue and have made it clear by extending the warranty on that part 4 times but are leaving me out to dry because I drive my truck so much.
  13. Jun 7, 2019 at 8:25 AM
    e30cabrio
    Sorry, there is a bypass people use that is much less expensive.
  14. Jun 7, 2019 at 8:29 AM
    AJ xKHAOSx
    AJ
    2011 Grey Tundra
    I think I might have seen the write up for it. I will do some digging around when I get off work to try and find it to explore my options. Thanks man.
  15. Jun 29, 2019 at 9:38 PM
    Splicerforever
    Splicerforever New Member
    Rich
    2008 Toyota Tundra SR5 4x4
    None
    Air Injector Pumps
