Blinking 4wd light but 4wd engaged
Discussion in '2nd Gen Tundras (2007-2013)' started by sarcomere, Feb 1, 2025.
  1. Feb 1, 2025 at 5:03 PM
    sarcomere
    sarcomere [OP] New Member
    2019 tundra. So my 4wd light continues to blink but the truck is in 4wd. I confirmed by jacking up the front and confirming the wheels are engaged. If I shut the truck off and restart in 4wd, the light goes solid and everything is fine. It disengages fine without shutting it off. The same sequence works for 4lo. I have to shut the truck off and restart for the light to go solid.
    any ideas? I did have electrical issues with the gateway computer and can bus system which seem to be otherwise fixed and I no longer have the codes.
    Thanks!
