Blew up my factory entune
Discussion in 'Audio & Video' started by spankiee, Apr 11, 2018.
  1. Apr 11, 2018 at 6:06 PM
    spankiee
    spankiee [OP] New Member
    Patrick
    2018 Tundra TRD Sport
    Infinity kappa components front and rear.
    Yep.. that’s what I did to my Tundra today.. 400 miles on it.
    I installed infinity kappa components and dynamat in all four doors, was trying to replace the factory amp using first, a wiring diagram I sourced from the internet using taps on the factory wiring. When that failed I ordered an amp wiring harness from ********* and cut the ends off to use with my amp (wish I would have just bought their amp and wire kit). But I had a newish mini amp that was on my motorcycle that was still in perfect condition. It uses very little power it’s just barely better than factory. So I decided to just use the factory wiring to power it.
    I went out after work and spent about an hour getting it all wired up, I was rushed for time. Got it all hooked up, it sounded amazing! So I turned the truck off to go eat dinner and relax and the radio wouldn’t shut off.. I noticed that when I hooked the amp up the radio came on, thought it was weird but went with it. So once I noticed the amp on music playing and no way to shut it off I pulled it all apart again.. this time only using my test light and multimeter testing the wires. It seemed right so I turned the truck on and the speakers made a screaming noise then the radio went blank.. nothing.. black screen.. I think start pulling fuses The radio fuse and amp fuse are fine. I pulled the negative off the battery let it sit a few hours put it back and still nothing.. so I pulled the radio out used my multimeter and test light and checked the wiring into the radio and I have power there just one wire, the amp has the constant power but no remote power and no other power behind the radio either.. even worse, it’s a lease... FML ..
  2. Apr 11, 2018 at 6:19 PM
    Trooper2
    JR
    Houston, TX (Suburban South)
    Quick, put all that stock stuff back in and take to the dealer!!! LOL
  3. Apr 11, 2018 at 6:22 PM
    boostedtrdpro
    boostedtrdpro voided warranty
    Jeremy
    2024 GMC Sierra 2500HD AT4X 2020 Sequoia TRD Pro 040
    Right!
  4. Apr 11, 2018 at 6:26 PM
    spankiee
    Patrick
    I put all the factory amp back in it’s all back to stock but the factory speakers are still out wouldn’t take much to put them back in. But that Dynamat ain’t coming out lol that crap don’t come off.
  5. Apr 11, 2018 at 6:33 PM
    boostedtrdpro
    Jeremy
    Doubt they'll open up the door panels, but they could. I'd still try it.
    Trooper2 likes this.
  6. Apr 11, 2018 at 6:35 PM
    spankiee
    Patrick
    In 3 years this entune should be cheap? I think I’ll just buy a Tesla screen for it and come lease end get a used entune for it.
