Bled brake lines, still no pressure
Discussion in '1st Gen Tundras (2000-2006)' started by Tonecapone1007, Nov 6, 2021.
  1. Nov 6, 2021 at 3:34 PM
    Tonecapone1007
    Tonecapone1007 [OP] New Member
    Tony
    05 Tundra TRD sr5
    Hi everyone,
    I have a 2005 Tundra TRD sr5, I had the brake line that goes, from the middle of the truck to Brake Proportioning valve blow on me, I replace the line, bleed the lines, pretty much, a full flush ended up been. Bleed all 4 corners. But still have no pressure. If anyone could please help with any suggestions or tips, It will be greatly appreciated.
    Thank you in advance.
  2. Nov 6, 2021 at 3:53 PM
    des2mtn
    SW
    2004 Black DC Limited 4x4
    Tonto cover
    Did you bleed the the proportioning valve itself too?
    Passenger rear
    LSPV
    Driver rear
    Passenger front
    Driver front
    Dr Doobie likes this.
  3. Nov 6, 2021 at 4:41 PM
    Tonecapone1007
    Tony
    05 Tundra TRD sr5
    That was the only thing I didn't do the bleeder is old and very rusted and I'm scared, if I try is going to break. I may have to get a new one, but also not sure if that has to do with the ABS.
  4. Nov 8, 2021 at 5:29 AM
    10 blue trucks
    10 blue trucks New Member
    04 4WD RCLB
    How did you bleed all 4 wheels with no pressure?
  5. Nov 8, 2021 at 6:41 AM
    des2mtn
    SW
    Tonto cover
    Just to check, before the brake lines blew and all this happened, you had good pressure to your brake pedal?
    The LSPV isn't part of the ABS system, it's separate. In a nut shell, it changes your front and rear brake bias depending on how much weight is in the bed.
    Your brake lines go along the frame rail to the LSPV first before your rear wheels, then from the LSPV it goes to a tee at the center of the rear axle. From that it then goes to each rear wheel. Bleed it.
    15whtrd likes this.
