Binding noise while running in 2WD
Discussion in '2nd Gen Tundras (2007-2013)' started by Tundra_2010SS, Jan 17, 2022.
  1. Jan 17, 2022 at 7:15 PM
    Tundra_2010SS
    Tundra_2010SS [OP] New Member
    2010 Tubdra DoubleCab 4.6L V8
    Hello folks,
    My tundra is making the binding noise when running in 2WD, but the noise goes away and it runs smoothly in 4HI. Any thoughts?
  2. Jan 17, 2022 at 8:44 PM
    Driving straight? Turning? What speed and does it start around 30 mph?
    You may have the infamous front differential needle bearing failure.
    I would replace with the ECGS bushing if that’s what you find.
  3. Jan 18, 2022 at 6:48 AM
    Tundra_2010SS
    I think it is happening when driving straight although I have not done any close observation on turning. It is happening at low speeds below 30 mph I believe and hear it on the driver's side, but when I switch to 4HI it is completely gone. Any idea of the rough cost to repair? and is this something any mechanic can fix or do I have to take it to a Toyota dealer?
    Thanks!
  4. Jan 18, 2022 at 12:42 PM
    audiowize
    audiowize New Member
    Paul B.
    2008 Tundra SR-5 4x4 5.7
    You can take your truck to a Toyota dealer and they will charge you for a new front differential (well over $1000).
    You might be able to find an independent mechanic to do this for you. I did mine in my garage in a couple of hours.
    Tundra_2010SS[OP] likes this.
  5. Jan 18, 2022 at 12:48 PM
    Sunnier
    Sunny
    San Diego, CA
    Lol. I first read this as ‘blinding noise’.:monocle: Glad it’s not that.
  6. Jan 18, 2022 at 12:56 PM
    Tundra_2010SS
    Thanks, audiowize. Okay, I don't want to spend that much money by taking it to the dealer. I am a bit mechanically inclined. In fact, I have a 2006 Jeep Wrangler TJ where I added a bunch of after-market stuff to it, including installing a 4-inch lift kit. I also did the clutch kit replacement of it which required the tranny to be removed to access the clutch/flywheel.
    Do you know of any youtube videos or resources/instructions on how to do the repair for the front differential needle bearing?
  7. Jan 18, 2022 at 1:11 PM
    If you can do that, you can install the bushing.
    Need:
    https://eastcoastgearsupply.com/i-18979362-toyota-9-reverse-clamshell-bushingeliminates-needle-bearing.html
    For ~180.00 and your time, problem solved.
    My 2012 had the same problem and they swapped out the front diff. 2750.00 under warranty.
    You got this.
    FrenchToasty likes this.
  8. Jan 18, 2022 at 1:18 PM
    Oh, the dealership offered and highly suggested doing the ECGS bushing. They would have charged me 600.00 + parts (100.00) for the install, and no warranty.
    I gave them 75.00 and my ToyotaCare card and told them fix it.
  9. Jan 18, 2022 at 3:26 PM
    audiowize
    Paul B.
    You're waaaay more than qualified to do this. ECGS has a video on how this is done. I would recommend buying their optional tool for popping out the old needle bearing.
  10. Jan 19, 2022 at 12:32 PM
    SeanO86
    SeanO86 Live Slow. Die Whenever.
    2018 SR5 Tundra TRD Off Road - Cement
    Fox 2.5 w/Resis +1 CB Shackles SPC UCA Alcan 750lb springs - +1" lift 3" Front : 1.65" Rear to level Toyo ATII 35s Icon Six Speed +25 offset Wheelers Superbumps Chrome delete ARE Z Topper w/ Thule rails Pinsu Topper rack RTT - Tepui Autana Ruggedized 3
    Something similar has been happening recently in my 2018 on the driver side. Except the only difference is that I hear a thud ( I guess it's a binding noise?) when I'm in 4wd going straight under or right around 30mph - usually when im downshifting / engine braking down hills in 2nd gear. I thought I might have heard it in 2nd gear 2wd the other day, but not entirely sure.
    Would my issue fall under the same category here?
    Seems like the infamous differential needle bearing issue is only in 2wd and goes away when 4wd is activated.
