Bilstein TRD Pro suspension on 2020 Limited?
Discussion in 'Suspension' started by mattyd170, Apr 17, 2022.
  1. Apr 17, 2022 at 10:00 AM
    mattyd170
    mattyd170 [OP] New Member
    Albuquerque, NM
    2020 Tundra Limited Crewmax with Leer shell. Calvary Blue
    TRD Front Suspension, Bilstein Rear, TRD rear sway bar kit, 35" tires, working on stereo.
    I looked all over and couldn't find a direct answer, which is I believe I can, but wanted to ask.
    Can you run the Bilstein Toyota TRD Pro front coilovers on a 2020 Limited Crewcab? I know the newer version are the Fox, but I found a screaming local deal on the older TRD Pro suspension and want to buy it, but only if it will fit. I already put Bilstein 5160's on the rear, so looking for something for the front and to help level.
    Thanks as always.
  2. Apr 17, 2022 at 10:00 AM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    yes
    15whtrd and mattyd170[OP] like this.
  3. Apr 17, 2022 at 10:05 AM
    15whtrd
    15whtrd Mr. Blonde
    Yep! All coil overs/shocks from 07 to 21 are interchangeable. Same frame on the second and 2.5 GEN
    mattyd170[OP] and 831Tun like this.
