bilstein shock help
Discussion in 'Suspension' started by HiRootz, Dec 24, 2020.
  1. Dec 24, 2020 at 4:30 PM
    HiRootz
    HiRootz [OP] New Member
    Hawaii
    2021 AG TRD Sport Crewmax
    can i get your guys opinion on these shocks please. about quality and performance. im mostly on road with occasional light/mild off road.
    ReadyLIFT | 2007-2021 Toyota Tundra Bilstein 8125 Coil-Over Upgrade Kit
    also, i have a 6 inch readylift kit on my 4wd crewmax. these are adjustable from 6-8 inches, but come preset at 8 inch. if i get these and want to keep the 8 inch preset, what could i do the lift the rear to level it out?
  2. Dec 26, 2020 at 1:42 PM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    They are meant for use with either their 6 or 8 inch lift kits. So they offer no additional lift beyond whatever lift they are being installed on, 6 or 8 inches.
    If you already have a 6 inch lift installed, your rear would already be lifted.
  3. Dec 26, 2020 at 3:54 PM
    HiRootz
    Hawaii
    I understand I could adjust the coil over down to 6in via spanner wrench, but since they come pre set at 8in I want to see my options to go 2 inches higher and keep that preset. So my rear would be squatting of I don’t do anything. They offer a 6-8in conversion kit, but it’s like $400 and comes with the extra compression spacer for the front which I don’t need and bigger blocks for the rear.
    just want to know if I could eliminate the blocks completely or do something else to add to the blocks I already have.
