Bilstein 6112 with shims?
Discussion in 'Suspension' started by nowayout, Jul 31, 2017.
  1. Jul 31, 2017 at 3:20 PM
    nowayout
    nowayout [OP] New Member
    NY
    17 CM
    I read on the inter webs that running the 6112 at the highest setting will create stiffness so assuming that is true would anyone recommend running them at the 1.9 height and then adding 1/2 inch of shims to get a better ride?
    Second ? Am I overthinking this lol?
    I just want 2.5 in of lift up front and maybe 1in rear and run 295/70/18 tires.
  2. Jul 31, 2017 at 5:21 PM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    You should be fine with that setup (Billy's at highest setting)
    Hattori and Backslider like this.
  3. Jul 31, 2017 at 5:27 PM
    Backslider
    Backslider Thirsty...
    Tooele, UT
    Agreed - you'll have better ride quality running them @ 2.5" and no spacer.
    Your other option would be to get some 5100s and get a 2.5" lift spring, leave the Bilstiens at stock setting. You still get the lift and you're not preloading the hell out of the springs.
    Law323[QUOTED] likes this.
  4. Jul 31, 2017 at 5:28 PM
    Backslider
    Tooele, UT
  5. Jul 31, 2017 at 7:05 PM
    AKJ78
    AKJ78 New Member
    Aaron
    San Diego
    2016 Silver Platinum 4X4
    3/1.5 lift. TRD sway bar. Bakflip V1 cover. Fuel wheels w/BFG A/T.
    I've been running 6112 at top setting with 1/2" shims for a few months now. Ride is better than stock overall but a little stiffer than I'd like. This setup got me 3.5" total lift up front which is more than I needed. At the next opportunity I plan to disassemble and run on the 1.9" setting. Should put me around 2.5-2.75" total lift with the 1/2" shim. If you don't need more than 2.5" front lift, I recommend against sacrificing ride quality. Also, even with a front diff drop kit, the CVs look nearly maxed out right now. I'm running SPC UCA which I knew would be necessary. At 1.9" you should be fine with stock UCA even with the addition of 1/2" shim. Hope this helps!
    nowayout[OP] likes this.
  6. Jul 31, 2017 at 7:18 PM
    nowayout
    NY
    17 CM
    @AKJ78 thats exactly what I wanted to hear. I want to lift the least amount possible to fit the 295's and to also get the best ride possible. Maybe the 1.9 setting on the 6112's and 1 coach builder shim per side. That will put me right over 2 inches and seeing that the Pros are running 2 inches and a lot of those guys have 295's I should have no problem.
    I also don't want to have to change the UCA's.
    Do you think a diff drop will be required with the above set up?
  7. Jul 31, 2017 at 8:49 PM
    AKJ78
    AKJ78 New Member
    Aaron
    San Diego
    Diff drop not necessarily required, but I recommend installing it. It's inexpensive and a quick easy install. Good insurance against premature CV wear.
  8. Jul 31, 2017 at 9:06 PM
    Joeshaker
    Joeshaker New Member
    Amado
    Evergreen, Co
    13 dcsb trd4x4
    Bilstein 6112/5160 trd sway bar and ride rite bags. Black and burnt orange wet okole seat covers.
    If you want 2.5 put the 6112's on the top setting. The ride will be fine, but be prepared for the possibility of needing ucas. 1.9" is close enough to 2". The only reason you would want to add a shim would be to get 3" lift. That's what I was going to do. But then I downsized the tires. Then I got the spc ucas.
  9. Aug 1, 2017 at 2:22 AM
    PermaFrostTRD
    Northern NY
    This was something I have considered and always questioned about the "adjustable coilovers". Are those wrenches merely adjusting the spring position which is what sets the "lift"? Are they affecting pre-load (or tension- not really sure what to call it, sorry for the ignorance) on the shock absorber at all?
    Also, could you run those OME 2-2.5" springs with 5160's (for the reservoirs) or are 5160's rear only? It doesn't specify on bilsteins online catalog.
    That might be a cheaper way to get a poor mans trd pro suspension (yes I'm aware of the tube diameter difference).
    Also tagging @Sean266 @ColoradoTJ @jberry813 for their expertise.
  10. Aug 1, 2017 at 4:03 AM
    chphilo
    chphilo Tundra addict
    Western PA
    As far as I know, OME coils (612, 614, 613) work only with OME shocks. I know that Tacoma people use OME coils with Bilsteins, but they are using different (softer) springs. Also I read that perches for these coils are different.
    If you are interested in 3 inch lift, why not just go with OME 612 and OME shocks for 3 inch lift? OME shocks aren't that much more than Bilsteins. It's the coils that add to the expense. I definitely do not recommend 613 (longest coil) unless you have a very heavy front bumper.
    With 3 inch lift (612), you probably won't need a set of UCAs. I have 3.5. inch lift (614) and went ahead and got a set because I didn't want to do the installation twice. Some guys with 614 were able to align their trucks with stock UCAs but I didn't want to take the chance.
    PermaFrostTRD and Black Wolf like this.
  11. Aug 1, 2017 at 4:24 AM
    Hattori
    Hattori STOP SHIMMING COILOVERS!!!!
    Tommy
    Nashville
    2012 Tundra CM TRD
    Me.......
    You're over thinking this setup. 6112 at top setting will run a295-70-18 all day and ride like a champ. You don't need to re-engineer the system by adding shims. You're manipulating the shock travel wise which at some point become uncomfortable for you. I did this truck for a customer and it's PERFECT
  12. Aug 1, 2017 at 6:28 AM
    Totally agree. ^^^. The OME coil springs should only be used with OME shocks. I went with the 614's. 613's too stiff unless you have a super heavy duty aftermarket winch bumper.
    PermaFrostTRD likes this.
  13. Aug 1, 2017 at 6:57 AM
    PermaFrostTRD
    Northern NY
    That looks pretty epic. Assuming 18x9 wheel. What offset if you can remember?
    Hattori[QUOTED] likes this.
  14. Aug 1, 2017 at 7:13 AM
    nowayout
    NY
    17 CM
    @Hattori That is good to hear. What did you install on the rear of that truck?
    Could I fit the 295's at the 1.9 setting with a +30 backspaced wheel?
  15. Aug 1, 2017 at 7:58 AM
    Hattori
    Tommy
    Nashville
    2012 Tundra CM TRD
    Me.......
    This truck was a 18X9 +18 Method Mesh on Nitto Ridges. Truck also has 5160's in the rear with a Icon AAL with stock shackles.
    PermaFrostTRD[QUOTED] likes this.
  16. Aug 1, 2017 at 8:05 AM
    Hattori
    Tommy
    Nashville
    2012 Tundra CM TRD
    Me.......
    +30 on that tire might cause some rubbing issues on on the UCA. Not syaing that IT WILL but there's a possibility. It'll reduce the need to do a CMC but its gonna be close. That truck in the pic kept the mud flaps and no CMC was needed. Kept the stock UCA's but he's upgrading them later on down the road.
  17. Aug 1, 2017 at 8:12 AM
    cody@Locked-OffRoad
    cody@Locked-OffRoad New Member
    Cody
    2014 Long Travel Tacoma
    same. Run them at the highest setting with no spacer
  18. Aug 1, 2017 at 9:49 AM
    Backslider
    Tooele, UT
    The perches are the same. As long as the spring rate is similar or the same you should have no problems, right?
    I'm basing this off a bunch of research I did into going this route on a 4runner. A lot of guys have this setup and are reporting good results. Talked to the pros @ good 4x4 shop and he said it would be fine so long as the spring rate is reasonably similar.
    If this is totally wrong I would love to know - definitely don't want to make the mistake of spending all that cash and then breaking something.
  19. Aug 1, 2017 at 10:12 AM
    I would put one shim under the drivers side CO and put the shock where you want it in height.
    Remember, on this shock, anything over the second setting you need to do bumpstop work.
    Personally, I really liked the ride of the 6112 and I had them on the .75 setting, or the lowest. However, if I wanted 3" of lift and do it right...King or ToyTec would be my first call depending on my budget.
    nowayout[OP] and PermaFrostTRD like this.
  20. Aug 1, 2017 at 12:19 PM
    I'm thinking you are correct on this. All about spring rate.
  21. Aug 1, 2017 at 1:36 PM
    chphilo
    Western PA
    Backslider likes this.
  22. Aug 1, 2017 at 2:02 PM
    Backslider
    Tooele, UT
    What got me looking in to this option is a guy on 4runners.com (sister site to this one) who is running Wheeler branded coils on Bilstein 5100s. I took that to mean that OME springs would work as well. I do see some instances online where people are claiming to use OME coils and 5100s. I'm not sure how accurate this is and now I seriously doubt the validity of this configuration, if only because the perches may not be compatible with OME springs. For this reason if I still do go this route I'll be sure to use the Wheeler's springs instead of the OME springs.
    Thanks for bringing this up, It very well may have saved me time and money. Two of my favorite things.
  23. Aug 1, 2017 at 2:08 PM
    nowayout
    NY
    17 CM
    I think I am going to try the 6112 at the 1.9 setting with one shim for the drivers side and 295's. From what I am reading with the correct wheel offset clearance won't be a problem.
  24. Aug 1, 2017 at 2:52 PM
    JackWagon
    JackWagon Dr. Wookiee
    16 Tundra DC TRD Pro MGM
    I ran bilstein 5100's with OME coil on my 15 Taco and got about 2.5-3" lift. Great budget lift. They were actually paired together and recommended by headstrong offroad as well as tacomaworld. Now, that does not mean that they work well for the Tundra, just that they did for the Taco. I've heard great thiongs about the 6112's and will consider them when my Pro suspension wears out.
  25. Aug 1, 2017 at 7:00 PM
    Backslider
    Tooele, UT
    Nice - I read the same from many Tacoma and 4runner owners... I just assumed the same would hold true for the Tundra.
  26. Oct 29, 2019 at 10:51 PM
    Ryan_Sal67
    Ryan_Sal67 New Member
    Ryan
    2019 Tundra Limited 4X4
    Any running? If so where and what did u do to get rid of it
  27. Oct 30, 2019 at 4:27 AM
    Basskrazee
    Basskrazee Pop
    Joe
    Indianapolis, IN.
    2016 Tundra SR5 /TRD
    AFE mass air intake TRD rear anti sway bar Headwaters seat covers TRD Pro grill Bilstien 6112 coil overs Bilstien 5160 rear shocks Consol vault
    It’s a truck not a car.
    MAGDADDY likes this.
  28. Oct 30, 2019 at 5:41 AM
    MAGDADDY
    MAGDADDY TTC #280
    JON
    Houston TX
    18 Platinum CM MGM
    Leer 100XL, Bedrug, Go Rhino running boards, LED int/ext lighting, Bilstein 6112/5100 1/2”shims up front, Coachbuilder +3 shackles, CB drop, TRD front/rear sway bar, 275/65/20 Michelin LTX M/S 2, sequoia painted mirror cap/door handles, Rago Fab low pro ditch brackets, Baja Designs S2 sports ditch lights. Baja Designs S2 sport rear flush mount pod
    You’re right! I see everyone wanting to lift but be comfortable. I can totally get that, but I like a truck to ride like a truck. The factory suspension felt like wet bread! I run my 6112 at the top and run a LT tire which makes the truck very tight.
  29. Oct 30, 2019 at 1:58 PM
    Basskrazee
    Basskrazee Pop
    Joe
    Indianapolis, IN.
    6112 at top setting. If you shim, shim drivers side and passenger side. Drivers side lean is a myth. I used Bilstien 5160 in the back with a sway bar and Coach Builder #3 shackles. Quite over thinking the preload crap. If you shim change the UCAs. If you don’t shim don’t change the factory UCAs. It’s that simple. There are people on this site that over think a tenth of a gallon of gas.some drivers live in the hills some live in the flat lands. There is no way to compare the mileage you should get from truck to truck. From what I’ve gathered from this forum over time is that Bilstien is a great product. The CLIP is dependable. Simple as that. Seems like there are a lot of issues with some of the prestigious manufacturers other than Bilstien with a huge amount of money spent on premium equipment that is way overkill. My thoughts
    19NOlimited and Hattori like this.
  30. May 3, 2022 at 3:16 PM
    Marshwalker
    Marshwalker New Member
    Z
    Did you do a diff drop, whats in rear?
    Thanks
