Bilstein 6112 settings to level?
Discussion in 'Suspension' started by Ming15237, Nov 23, 2018.
  1. Nov 23, 2018 at 5:36 AM
    Ming15237
    Ming15237 [OP] New Member
    2015 crew max platinum
    First off, new member here and nice to meet you all. I have a bone stock 2015 crewmax platinum. I am really looking for a better ride from the front so I purchased the 6112 Bilstein setup from suspension connections. They had a hella deal @ $595 shipped. That being said I am looking to simply level the truck with this setup. Has anybody put these on their vehicle and if so what setting on the shock assembly did you use? Family owns a shop, so install will take place there. Any input would be greatly appreciated guys. As an aside this truck is a pavement cruiser, it will never go off-roading, but I do tow my rather heavy boat with it. It currently has a ready lift automatic rear airbag setup to help with the weight of the boat and trailer.
    kparrow likes this.
  2. Nov 23, 2018 at 8:05 AM
    aminter0
    aminter0 New Member
    Andrew
    2017 White Tundra CM SR5 TRD
    1.9” setting which I believe the the second from the top will get you leveled. I just installed these last month on my crewmax and found that setting paired along with a shim for the drivers side got me level.
    Good luck!
  3. Nov 23, 2018 at 9:50 AM
    mambo143
    mambo143 New Member
    Phil
    Maine
    2016 Tundra TRD Crewmax
    Bilstein 6112, 5160, Coachbuilder 1” shackle lift, Wildpeak A3’s, LED backup, Maxiplus mats, Bak Rollover Mx4, BedRug, Westin HD Headache Rack. Westin HD Brush Guard, Spidertrax 1.5 spacers. TRD Brakes. Headlight Revolution LED. TRD rear Torsion Bar. Dirty Deeds 10 inch Stainless. TRD Pro Grill. Bushwhacker Pocket Flares. Baja Designs Combo Driving/Fog lights.
    As above. Same truck and same setup. 5160’s in the rear. I ended up adding a 1” lift in the rear for more rake, but could have been happy either way. You can go to 33” tires with that setup, staying with 75 width tires and OEM wheels with no rub lock to lock. You may have to trim the corner of the skid plate and heat/bend the rubber mud flap thingy on the front.
  4. Nov 23, 2018 at 2:10 PM
    Ming15237
    I decided to get myself a set of 5160’s as well for the rear. Christmas present to myself! Thanks for the input guys, and sorry I didn’t use the search function first as someone messaged me advising as such. The plan for now is to keep it stock except for the shocks, it really rides like poop with the stock shocks imho, and bounces down the highway.
  5. Nov 23, 2018 at 2:43 PM
    mambo143
    mambo143 New Member
    Phil
    Maine
    The shocks at 1.9 will correct that and stiffen the ride a bit. I have Zero bounce and little to no lean on corners. Personally, I would leave it like that unless you want the rake back or plan to tow.
  6. Nov 23, 2018 at 2:45 PM
    justfortun
    justfortun New Member
    James
    Boston
    2016 SR5
    I just bought the 6112/5160, - going with the 1.3" (second setting) with a .5" shim on the driver side and with a 1" shackle (.625") in the back. Everything is in the mail so pictures in a week or two. Assembling myself, so I need to figure out the best way to do that. Running on stock 18 rims with BFG KO2 275/70r18.
    Looking for drive improvement and a balanced look, with slight rake. Might install the shackles first and do some measurements to see what the rake will be. Then decide if I bump up to the 1.9 front height.
    Love to see people running these with 1" shackle on 33's!
    Stormtrooper81 and Mr Swervlin like this.
  7. Nov 24, 2018 at 6:54 AM
    Ming15237
    What’s the reason for the “.5 shim”?
  8. Nov 24, 2018 at 7:10 AM
    justfortun
    James
    Boston
    2016 SR5
    There is a driver side lean - the battery and the gas tank are on that side. I havent seen or felt this lean and I'm not sure if when I put this guy in, I'll get a passenger side lean, but it was a recommended addition to buy (like $18) when I bought the Coachbuilder +1 shackle. I need to do some more measurements but I'm already going to be replacing the front shocks, so while everything is apart I figured it's small money to have the option. I'll let you know how it goes, and do some measurements today. (top of wheel well, to center of wheel)
    OR18TRD likes this.
  9. Nov 28, 2018 at 1:10 PM
    fuguchan
    fuguchan New Member
    Jeff
    St. Mary's County, MD
    2018 Tundra 1794 Edition Smoked Mesquite
    ARE-Z Cap, Bed Rugs, Husky Mats
    :popcorn: Would like to see how this looks with 33's.
  10. Nov 28, 2018 at 1:43 PM
    Sephon
    Sephon Don't be an American't
    Northwest PA
    2020 Black Tundra TRD Pro
    Icon Rebounds w/285/75 BFG KO2’s, Coachbuilder +2
    same
  11. Nov 28, 2018 at 1:44 PM
    Nm6300'asl
    Nm6300'asl New Member
    2022 DC SR5 4x4
    Oem tonneau, side steps, spray in liner. Trd skidplate.
    6112-5160 and toytech shackles top setting on 6112, 1.5" on shackles. 275-70-18 michelin atx 2's
  12. Nov 28, 2018 at 4:06 PM
    Ericsopa
    Ericsopa Old man and the sea
    Nice truck! @Nm6300'asl ..... you must be from Santa Fe. I used to fly out of the airport there ... choppers with the Army Nat'l Guard. 717th Medevac. Way back in the '70s. I remember the field elevation being 6340ft or so.
    Nm6300'asl likes this.
  13. Nov 28, 2018 at 6:09 PM
    justfortun
    James
    Boston
    2016 SR5
    Ahhh, looking awesome. My shocks arrive tomorrow. Like being a kid again waiting for Christmas. Any driver side lean? I don’t think I can wait for the coachbuilder .5” shim before I put the 6112s on! I can lean.
    I’d like to see a profile to see your level...torn between 1.3” and 1.9”
    OR18TRD[QUOTED] likes this.
  14. Nov 28, 2018 at 6:14 PM
    1Cmnt2nv
    1Cmnt2nv New Member
    Benjie
    Honolulu Hawaii
    2018 Cement Tundra
    6" Readylift w/ 5100 Frt n Rr 22 x 10 Fuel Tritan w/ Atturo MT 35 x 12.5 Afe Intake n Exhaust Pedal Commander Bushwacher Flares Tint / Wet Okole / TRD Frt n Rr Sway Bar Bakflip G1 / Bedrug
    Hey guys quick question, planning on lifting truck 6" via readylift kit n bilstein 6112 in frt n 5160 in rear will this combination work?
  15. Nov 29, 2018 at 2:44 AM
    justfortun
    James
    Boston
    2016 SR5
    Theoretically, you could get close to 6” with the 6112, and spacers, but I think there are much better options gaining that height with something else. The 5160 is only a 0-2” so you’d need something else in back.
    There are much smarter people here, and I’ve never researched that height. So I dont have a good recommendation. Good luck up there!
  16. Nov 29, 2018 at 2:59 PM
    fuguchan
    fuguchan New Member
    Jeff
    Your Tundra looks really nice. I can see a 5160 shock from the pic and the awesome TRD dual exhaust. The shackles in the back provide a good rack look. How do you like your installation?
  17. Nov 29, 2018 at 3:10 PM
    fuguchan
    fuguchan New Member
    Jeff
    Your Tundra looks nice too. I see a sticker of something on the gas cover. Darn it, you got the TRD dual exhaust too? I gotta convince the wifey. I just got an ARE cap w/bedrugs for my 2018 1794 Edition and now my wallet says get more.
  18. Nov 29, 2018 at 3:50 PM
    BRTundra
    BRTundra New Member
    Tony
    Baton Rouge, LA.
    2017 Tundra Platinum 5.7L CM
    I got Bilstein 6112 on top setting for 2.5 inch lift and Coachbuilder +1 in the rear. Truck is level with 33 inch tires. Love the look.
  19. Nov 30, 2018 at 6:42 AM
    Nm6300'asl
    2022 DC SR5 4x4
    Very impressed with the ride quality of the 6112-5160 combo, very "controlled" feeling and I am not even running the front sway bar. Wasnt my plan but had to go with the higher setting on the shackles because the daystar cradles thickness was adding "preload" on the airbags even at 5 psi. The TRD duals, TRD cai and TRD pro skidplate really complete the truck!
  20. Nov 30, 2018 at 11:13 AM
    justfortun
    James
    Boston
    2016 SR5
    Just finished the 5160 install and seems to be a smoother ride on the backend. Hard to be “omg wow” like when I installed the rear sway bar, but me brain says it better.
    But really doesn’t matter how it drives. Looks fukn awesome, so that’s all I care about when parking at the mall this Christmas season...;)
    So...onto the 6112 install this weekend. Anyone modify the pin to the spring compressors so they can lock around the coil? The whole process seems shady as hell, but I’m the sort of person who doesn’t mind extreme bodily harm to have a small amount of satisfaction. I’ve seen a guy on YouTube grind them down. Has to be safer that not using them.
    And just so this isn’t a complete thread hijack - I’m setting them to 1.3” with a coachbuilder .5” driverside shim.
  21. Nov 30, 2018 at 10:17 PM
    Mr Swervlin
    Mr Swervlin "Yes....In Dee Face"
    O H I O
    2017 Silver Sky limited TRD Crewmax
    Line X bed liner Window tint AVS in channel vent visors Paint protection wrap Husky front & rear floor liner ESP Crewmax rear storage Console organizer and tray TRD shift knob TRD rear sway bar Thule exporter pro 500 Color matched door handles, side mirrors, and grill surround VLEDs interior/reverse/cargo Driver side grab handle 10" BAmuffler Trd pro headlights
    @justfortun I'm looking to do the same but, not till spring. Please post up some pics when your done. Very curious. Thanks
  22. Dec 1, 2018 at 1:14 AM
    justfortun
    James
    Boston
    2016 SR5
    Will do :thumbsup:
    Mr Swervlin[QUOTED] likes this.
  23. Dec 3, 2018 at 12:27 AM
    iamsmokey
    iamsmokey Smokey the Tundra
    Oahu, HI
    2018 Cement SR5 Off-Road 4x4 Crewmax
    Hey can you tell me how you measured yours? I feel like I see a slight lean with the naked eye but am not sure the best way of measuring
  24. Dec 3, 2018 at 12:30 AM
    iamsmokey
    Oahu, HI
    Hey how did you measure with the shim? Do you only have a shim on the driver's side?
  25. Dec 3, 2018 at 8:15 AM
    justfortun
    James
    Boston
    2016 SR5
    Bilstien 6112 at 1.3" vs OEM shocks
  26. Dec 3, 2018 at 3:42 PM
    Mr Swervlin
    O H I O
    @justfortun Nice!!! I'm really liking the 1.3 look. That's without any rear lift,right? What size tires are you running in these pictures? How's the ride now?
  27. Dec 3, 2018 at 4:02 PM
    Travo60
    Travo60 New Member
    Travis
    Austin, TX
    2018 Limited CM Cement
    Look I’m am chasing, truck looks awesome. Did you include any shims? UCA?
    Rica25 likes this.
  28. Dec 3, 2018 at 4:15 PM
    justfortun
    James
    Boston
    2016 SR5
    Thanks man. I got it aligned this morning, so I drove it home tonight sort of like an asshole to see how it handled. It handles as nice as it looks. Really impressed with the handling. It's stiffer, and seems to enjoy curves. Didn't take it offroad, but I also didn't slow down for the three speedbumps in my building's parking lot.
    As for the looks, I like it a lot. If I went to a bigger tire I'd consider the higher settings. The back isnt lifted right now, but the coachbuilder 1" shackle arrived in the mail today. I'm out of town for the next couple days but I'm going to throw those on the back end (supposed to lift it .625-/+") sometime next week. They look like an easy install and they don't change the drive as far as my alignment. But I have to be honest, I thought I wanted the rake, but this level look is really appealing. If the Coachbuilders raise the back too high, I'll pull them off and pack em up and save them for when I lose my mind completely to all you people, bump the fronts to 2.5, get a couple more shims and pop on some 35s.
    Tires are 275/70r18 BFG KO2s
    DMG85 and Mr Swervlin[QUOTED] like this.
  29. Dec 4, 2018 at 6:13 PM
    BRTundra
    BRTundra New Member
    Tony
    Baton Rouge, LA.
    No shims or upgraded UCA. Hope this helps.
  30. Dec 4, 2018 at 7:10 PM
    Ubnpast
    Ubnpast New Member
    6112 @ top setting with rear toytec shackle and 5160s in rear.
    Dgjman, equin and Boerseun like this.
