Bilstein 6112 noise?
Discussion in 'Suspension' started by YoTundra, May 13, 2020.
  1. May 13, 2020 at 6:13 AM
    YoTundra
    YoTundra [OP] New Member
    2018 Tundra SR5 Quicksand
    I had Bilstein 6112's installed on my truck late fall last year, and I get kind of a squeaky clunk noise from them when hitting bumps and stuff. Anyone else get that by chance?
  2. May 31, 2020 at 7:39 AM
    33jeep
    33jeep New Member
    In 40k on my 6112s I have not noticed any noise from them. My guess would be bushing in the upper mount of the shock.
  3. Sep 23, 2021 at 5:59 PM
    YoTundra
    I never posted the solution to this, it ended up being the diff drop that was put on. It changed the angle too much and was causing the noise. It's been removed and deemed unnecessary.
  4. Sep 23, 2021 at 7:19 PM
    georgiey22
    georgiey22 Moving to Idaho
    2019 Tundra | TRD Sport | Cavalry Blue | Crew Max
    Thanks for sharing the update.
  5. Oct 29, 2021 at 4:47 AM
    cdavi060
    cdavi060 New Member
    Virginia Beach, VA
    2017 Super White Tundra Platinum CM
    285/70r18 NITTO RG | Method NV 18x9 | Bilstein 6112 @2.5" w/CB shims, SPC UCA, 5100 & CB +3 Shackles | Entune 3.0 Swap | 2018+ Platinum grille + Pro LED Headlights
    I have a rubber squeaking noise when I go over bumps with my 6112s. No diff drop. Any ideas?
  6. Oct 30, 2021 at 7:11 AM
    BillyB
    BillyB New Member
    Billy
    AZ
    2021 SR5 TRD Sport 4x4
    Thanks for posting this. I just had 6112's (2.5 w/ Coachbuilder spacers, too) and a diff drop installed and have a clunk when hitting speed bumps at around 15 mph.
  7. Oct 30, 2021 at 7:16 AM
    ZPhilip
    ZPhilip Custom title here
    Philip
    West Chester, PA
    2015 Platinum Super White Crewmax
    Harrop supercharger, TRD Pro Fox suspension, CB +1 shackles, 295/70-18 Toyo ATIII, TRD Pro forged rims
    How much lift did you have?
  8. Oct 30, 2021 at 7:22 AM
    memario1214
    Colton
    Missoula, MT
    '21 Limited MGM CrewMax
    Diff drops don't do anything on current Gen trucks except move the oil away from the pinion bearing. I’d ditch it.
  9. Oct 30, 2021 at 7:29 AM
    BillyB
    BillyB New Member
    Billy
    AZ
    I most likely will
  10. Oct 30, 2021 at 7:30 AM
    memario1214
    Colton
    Missoula, MT
    I’m not saying that is definitely your issue… but it’s a place to start!
  11. Oct 30, 2021 at 7:31 AM
    BillyB
    BillyB New Member
    Billy
    AZ
    Yup, at least I have one possible solution now
  12. Oct 30, 2021 at 12:31 PM
    cdavi060
    cdavi060 New Member
    Virginia Beach, VA
    I think it’s the bushings for the sway bar for me. I think they are the squeaking. Will try and grease them this week and see if mine goes away.
    It happens on turn bumps and such. Just bouncing the truck up and down by hand doesn’t make a sound.
  13. Nov 3, 2021 at 6:22 PM
    AggiePhil
    AggiePhil Texas Chapter President
    College Station, TX
    2020 Smoked Mesquite Platinum 4x4
    How so? This is the first I’ve heard against diff drops.
  14. Nov 3, 2021 at 6:33 PM
    Blang805
    Blang805 New Member
    Central Coast California
    2010 CrewMax Platinum 4x4
    Build in Signature
    It doesnt change the CV angle when you install it so it really doesnt "drop the diff". It's more so of 'lean'
  15. Nov 3, 2021 at 7:12 PM
    AggiePhil
    College Station, TX
    Interesting.
  16. Nov 3, 2021 at 7:13 PM
    Blang805
    Blang805 New Member
    Build in Signature
    do a few google searches and make an opinion for yourself.
    Im not here to judge, im just here to state my opinion :D :fistbump:
    Edit: Jberry knows his stuff too.. he has been someone I've know and trusted for over 10 years. Great dude with lots of knowledge.
    Diff Drop Needed?
    AggiePhil[QUOTED] likes this.
  17. Nov 9, 2021 at 11:04 AM
    cdavi060
    cdavi060 New Member
    Virginia Beach, VA
    Greased up the front sway bar rubber bushings, which did help, but I still have squeaking coming from my SPA UCA bushings now :(
  18. Nov 10, 2021 at 3:10 PM
    Southshore30
    Southshore30 New Member
    2018 Limited Crew Max
    You did grease with full synthetic right? Something like SuperLube? Polyurethane bushings will degrade from regular grease
  19. Nov 11, 2021 at 7:17 AM
    cdavi060
    cdavi060 New Member
    Virginia Beach, VA
    Yeah, was the bushing lube that came with the Coachbuilder shackles. I had extra packets.
