Bilstein 6112 Kit Part Numbers
Discussion in 'Suspension' started by cthomaschase, Feb 9, 2017.
  1. Feb 9, 2017 at 8:34 PM
    cthomaschase
    cthomaschase [OP] New Member
    So I had a shop order and install a Bilstein 6112/5160 setup. After getting home I was looking at the work and I noticed that the front strut is stamped (both in the metal and with a sticker) with a different part number 24-235310.
    This part number is not listed with Bilstein.
    The shop is closed for the day, wanted to see if anyone had any clue on this before I return there in the morning. Otherwise the strut and spring look correct. BTW The 5160 are the correct part number on the shock.
    WTF?
  2. Feb 9, 2017 at 11:19 PM
    It is probably the shock manufacturer part number that built the shock for Bilstein.
  3. Feb 10, 2017 at 7:01 AM
    Beardedbeast
    Beardedbeast New Member
    Killeen TX
    2013 tundra crewmax
    ALOT!
    Mine are the same,nothing to worry about!
    cthomaschase[OP] likes this.
  4. Feb 10, 2017 at 10:15 AM
    cthomaschase
    Thanks for confirming. The shop said the kit part number and actual strut part number were different, thanks for confirming!
    Beardedbeast[QUOTED] likes this.
  5. Feb 10, 2017 at 5:05 PM
    cthomaschase
    Just in case someone stumbles upon this thread, I want to clarify what I found. This relates to the 2017 Tundra 4WD.
    The 5160 rear shock has the part number 25-237429 printed and stamped on it.
    The 6112 front strut and spring Kit (both parts) have the part number 46-206084, however the actual part number printed on the strut is 24-235310. This is what was confusing to me.
    FYI.
  6. Feb 11, 2017 at 12:18 PM
    scotch
    scotch New Member
    Denver, CO
    2010 Tundra
    2010 Tundra Method 20x9 Fat Fives 18offset, 305/55/20 Duratracs, Bilstein 6112/5160, SPC/LR Upper Control Arms, TRD Rear Swaybar, OME/Dakar leafs with CB +1 Shackles, Husky Weatherbeaters, Du-Ha, Extang Solid Fold, Line-X, Toyota Bed Mat, Stoptech Cryo Rotors and pads, Goodridge brake lines, Stoptech STR-660, Rigid Fog Lights, Odyssey Battery, Firestone Airbags with CB spacer, etc, etc... Previous Toyota's: 97 4runner, 02 tacoma, 09 tacoma
    Here are photos of what was in my front 46-206084 kit and my 5160 rear's:
    [​IMG] [​IMG] [​IMG] [​IMG]
