Bilstein 6112 install ?
Discussion in 'Suspension' started by Stumpjumper, Aug 28, 2017.
  1. Aug 28, 2017 at 6:11 PM
    Stumpjumper
    Stumpjumper [OP] Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    I know Fabtechs are side specific with one marked driver side. I see no such mark or sticker on the Bilstein so I assume they are not.
  2. Aug 28, 2017 at 6:13 PM
    Flyinryank
    Flyinryank New Member
    Ryan
    Las Vegas, NV
    White 2015 CM 4x4
    I don't believe so but do remember reading somewhere that the writing on the Springs should be facing out and right side up.
  3. Aug 28, 2017 at 6:14 PM
    Stumpjumper
    Fate, Tx
    2017 Tundra TSS 4x4
    They are marked out on top on both. I got that part covered.
    Flyinryank likes this.
  4. Aug 30, 2017 at 5:28 AM
    stlaw
    stlaw New Member
    Alabama
    17 SR5 TRD Off Road Crew Max
    Not side specific.
  5. Aug 30, 2017 at 5:49 AM
    Might want to look into a 1/4" shim for the drivers side to help with the Tundra gangster lean if you haven't done so already.
    CM-LENNY likes this.
  6. Aug 30, 2017 at 10:11 AM
    Stumpjumper
    Fate, Tx
    2017 Tundra TSS 4x4
    Thought about it but I am not OCD enough to let a 1/4" bother me
    Bprose and ColoradoTJ[QUOTED] like this.
  7. Aug 30, 2017 at 3:53 PM
    BOBONTUESDAY
    BOBONTUESDAY Grocery Getter
    2016 Limited Trd
    I said the same thing but now I notice it everytime I fill up gas.
    ColoradoTJ likes this.
  8. Aug 30, 2017 at 3:55 PM
    A 1/4" shim at the shock is about 1/2"...FYI
    joonbug and CM-LENNY like this.
  9. Aug 30, 2017 at 6:48 PM
    Stumpjumper
    Fate, Tx
    2017 Tundra TSS 4x4
    I am guessing that the brake lines are not an issue with a 2" lift.
  10. Aug 30, 2017 at 6:50 PM
    I did not have an issue.
  11. Aug 30, 2017 at 7:14 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    When did you get a Tundra??
  12. Aug 31, 2017 at 3:17 AM
    Stumpjumper
    Fate, Tx
    2017 Tundra TSS 4x4
    Last week. I got it tow 2200 Bay Champ. I had planned on buying one early next year but pushed up because of boat purchase.WP_20170630_001.jpg
  13. Aug 31, 2017 at 3:44 AM
    Boondoc89
    Boondoc89 Shit happens when you party naked
    Doc
    '17 mgm DC TRD 4x4
    No mods
    When are we going fishin???
    Tundra_mike89 likes this.
  14. Aug 31, 2017 at 4:57 AM
    BlueFalconActual
    Kevin
    29 Palms, CA
    Tundra-less
    How’s it tow vs the Taco?
  15. Aug 31, 2017 at 8:34 AM
    Stumpjumper
    Fate, Tx
    2017 Tundra TSS 4x4
    Taco always towed kind of rough even with lighter load. Heck the Taco road rougher period but also handled corners a lot better. The Baja has a pretty stiff suspension. Only thing that disappointed towing with Tundra was MPGs. I figure it would do better than Taco but they were same. Much improved towing over Taco.
