Bilstein 6112 availability
Discussion in 'Suspension' started by weerwolv_1776, Nov 20, 2021.
  1. Nov 20, 2021 at 1:52 PM
    weerwolv_1776
    weerwolv_1776 [OP] New Member
    2021 Tundra Limited TRD DoubleCab
    Hi all,
    Looking for recommendations of vendors who have the Bilstein 6112's in stock and can do the assembly for me. Going to go with 1.3 inch lift and 275/70r18.
    Just want room in the front for the tire install and a bit of rake. I think the 1.9 would put me level.
    My ride is a 2021 Tundra TRD Limited Double Cab.
  2. Nov 20, 2021 at 2:18 PM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    try toytec
  3. Nov 20, 2021 at 4:06 PM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    Literally nobody has them right now. Call boss 4x4 and get on their wait list for mid December. I decided to go eibach front coilovers since they in stock and adjustable while on vehicle.
    Blang805 likes this.
  4. Nov 29, 2021 at 2:12 PM
    fireman_pete
    fireman_pete New Member
    Pete
    2021 SR5 Trail Edition
    I have been waiting for a set of 6112's for nearly 6 weeks. Still no ETA when they might be in stock. I already purchased a set of 5160s for the rear.
    It sucks to wait, but not really another option in the same price range.
  5. Nov 29, 2021 at 2:18 PM
    SouthWestGA
    SouthWestGA New Member
  6. Nov 29, 2021 at 2:19 PM
    weerwolv_1776
    I ended up pulling the trigger on the new Eibach Pro-Truck 2.0 Coil Overs for the front. I'm holding off on the rears as there are rumors they will have an external resevoir version soon.
    The design is what intrigued me the most as the new version can be raised or lowered via a spanner wrench while installed in the truck. Comes from the factory set at 2" or so in height so we will see how that works out when installed. It's min-max adjustment range is 0-2.5" which is the most I will ever need. Need to take some measurements before install to see if shims will be needed or I will just adjust them on the truck.
  7. Nov 29, 2021 at 2:23 PM
    fireman_pete
    Pete
    I was about to do the same, and might if the 6112s dont show up soon. I do like the idea of being able to adjust the height via wrench, but prefer the 6112s as they have a larger tube body.
  8. Nov 29, 2021 at 2:56 PM
    MadMaxCanon
    I just bought these too. Good deal with the discount and free shipping. I wonder if these springs will sag...I have the small gas tank but will have a bumper and winch that weigh 200 lbs together, along with about 40 lbs of armor under the engine. I'm going for 2 inches as well.
  9. Nov 29, 2021 at 3:01 PM
    SouthWestGA
    I believe it is recommended you have a higher rated spring for added weight,no matter the lift height.
    @memario1214
    He will know
  10. Dec 1, 2021 at 11:34 PM
    Clemshady
    Clemshady Bama Storm Trooper
    Jeff
    2017 Super White Limited DC TRD 4x4 Offroad
    \ Factory OEM LED Tundra Pro headlight upgrade Diode Dynamic amber Pro fogs 3" DD amber Pro ditch lights SDHQ ditch brackets 42" DD light bar SwitchPro 9100 Pedal Commander Vinyl wrapped bumpers Painted calipers Painted horns Chrome delete complete ARE CX Evolve Topper TRD rear swaybar Matching door handles and mirror caps Oh shit handle upgrade Matching grille surround/hood bulge TRD PRO insert grille BBS Forged TRD PRO wheels Coachbuilder +3 shackles Eibach Pro 2.0 Coilovers and rear shocks
    I was in the same boat as the OP on this and kept waiting for the 6112s to come in stock. Been watching the Eibach Pro 2.0 coil overs to come down in price and seeing how everyone likes them. The wait is over and research is done. :thumbsup:
    I just received my shipping notification directly from Eibach saying my front and rears are on the way. I ordered them this past Friday. Free shipping and $934 out the door. So long Bilstein.
    Peeeheeuuu and Blang805 like this.
  11. Dec 2, 2021 at 12:04 AM
    Blang805
    Blang805 New Member
    Central Coast California
    2010 CrewMax Platinum 4x4
    Build in Signature
    I went with Eibach myself and couldnt be happier.
    Reason being was the fact Bilsteins were almost impossible to get. So, I tried something trustworthy besides Billys and couldnt be happier to have something different and great riding.
    Clemshady likes this.
  12. Dec 2, 2021 at 12:06 AM
    Clemshady
    Jeff
    That is good to hear. Can’t wait to get mine on. Have heard nothing negative on these so far.
  13. Dec 2, 2021 at 12:08 AM
    Blang805
    Blang805 New Member
    Build in Signature
    Theyre awesome riding. I do suggest if you are going to use the Eibach springs, to get a CB shim. I installed mine before I received my shim and it does sit a 1/2" lower on the driver side due to the lean (tank, driver, battery). So if you can wait, order one of those from Coachbuilder for 20 something shipped and youll be golden. I have yet to install my shim but I will at some point.
    Clemshady[QUOTED] likes this.
  14. Dec 2, 2021 at 12:11 AM
    Clemshady
    Jeff
    Do you need the shim? Aren’t the front coil overs adjustable? I was just gonna even it out with the wrench if it sat lower.
    Blang805[QUOTED] likes this.
  15. Dec 2, 2021 at 12:13 AM
    Blang805
    Blang805 New Member
    Build in Signature
    Sorry, I have the Stage 1 kit. Therefore the shocks arent threaded like the Stage 2.
    If I had the Stage 2, it would be an easy jack the driver side up and adjust the coilover :thumbsup::thumbsup:
  16. Dec 2, 2021 at 12:16 AM
    Clemshady
    Jeff
    Yep, that was what I was thinking. I can’t imagine anyone buying something else after this new design in the 2.0. Glad I waited. I am assuming they will ride as good as the Stage 1.
  17. Dec 3, 2021 at 9:15 AM
    fireman_pete
    Pete
    Would there be any issues running the Eibach Pro Truck 2.0 up front and Bilstein 5160's in the rear? I already have the 5160's, and I am about done waiting for the 6112's I have an order for nearly 2 months. Plus I prefer the spanner adjustability of the Eibachs.
  18. Dec 3, 2021 at 11:55 AM
    Clemshady
    Jeff
    I wouldn’t think there would be any issues. If anything, you might swap the rears out on a later date. I should be getting mine soon and will let you know how they ride.
  19. Dec 8, 2021 at 3:09 PM
    fireman_pete
    Pete
    Has anyone had any luck recently getting a set of 6112's?
  20. Dec 8, 2021 at 5:39 PM
    Bo Dangles
    Bo Dangles New Member
    Jesse
    Canada
    2021 Tundra TRD Sport Premium
    I ordered mine at the end of June, they’ve been pushed back to sometime in February now, in Canada.
  21. Dec 9, 2021 at 2:19 PM
    fireman_pete
    Pete
    Just an FYI, I spoke with Bilstein, and it appears that the next anticipated ship date of 6112's for the Tundras are March, 2022 :-(
    I think it is time to look at a different option.....
    Roselaker likes this.
  22. Dec 9, 2021 at 2:21 PM
    chaddydubbs
    chaddydubbs New Member
    Chad
    Omaha, NE
    2017 MGM Tundra SR5 Crewmax
    Tyger running boards, black badge overlays, stubby antenna, TRD Pro grille, window tint, LED interior lights
    I am selling a brand new set of 6112s and 5160s. Check my post in the marketplace.
  23. Dec 9, 2021 at 2:22 PM
    Dsptundra
    Austin TX Area
    2021 Silver Limited CM
    Based on what Eibach has said these use their off the shelf 3” springs. So in theory you could buy a set of heavier Eibach springs to compensate for the added weight and have them swapped.
  24. Dec 9, 2021 at 2:26 PM
    MadMaxCanon
    I actually called and asked Eibach about it and they said i should be fine since they are 650lb springs. I wanted it lower then the 2.5" lift setting that comes preset so I figure it may sag around 1/4 inch due to weight, which I would be Ok with. I have shims as well but not sure if I will need to use them.
  25. Dec 9, 2021 at 3:03 PM
    Dsptundra
    Austin TX Area
    Got it. Is 650lb the same as the stock springs?
  26. Dec 9, 2021 at 3:04 PM
    MadMaxCanon
    That I am not sure of. I know the strongest rate springs I have seen talked about on here have been 700 lbs so its not too far off.
  27. Dec 9, 2021 at 4:55 PM
    Dsptundra
    Austin TX Area
    Not sure where you are in SoCal but Eibach lists Tundras on their list of vehicles needed for testing. Could be a cool way to get plugged in to their products.
  28. Dec 9, 2021 at 6:49 PM
    MadMaxCanon
    Where did you see that? I am pretty close
  29. Dec 9, 2021 at 7:55 PM
    fireman_pete
    Pete
    I am very close to Eibach's shop. I looked at the website, but did not see that listed. Can you post a link? TIA
  30. Dec 10, 2021 at 9:29 PM
    fireman_pete
    Pete
    I cancelled my order for the 6112's and ordered the Eibach's today. I am still going to use the 5160's on the rear. Getting everything installed just after Christmas. Looking at a 2"-2.25" lift/level on the front end. I will also be adding the TRD rear sway bar as well.
