Bilstein 6112/5160
Discussion in 'Suspension' started by Ojata, Jan 10, 2024.
  1. Jan 10, 2024 at 7:01 PM
    Ojata
    Ojata [OP] New Member
    South Elgin, IL
    2021 Tundra Limited CrewMax
    Im currently running BFG Ko2s on Fuel Covert +1 offset on 5100s all over and really want to give shot to 6112/5160. I want to run the front on 3rd line and get 1.9 to level it ! Am I gonna fit 285/65R20 (34.6’ inch tire). I’m looking at Mickey Thompson Baja Boss A/T or Fslken Wildpeak A/T3W ! Thanks in advance!
    ATV25 likes this.
  2. Jan 10, 2024 at 8:54 PM
    RobertD
    Robert
    DFW, Texas
  3. Jan 11, 2024 at 4:22 AM
    blackoutt
    blackoutt YEAH BUDDY!
    Indy
    07 DC Long Bed - Old Man Tan
    OEM+
    Do it! I just installed 6112/5160 (the newer 5160 that come with the billet clamps) on the LOWEST setting to keep my daily driver "mostly stock". It rides amazing! Some may find the 650lb springs a bit stiff but I enjoy the reduced body roll and brake dive. I'm also a fan of the stiff feeling digressive valving that some find harsh, it can be a bit jarring at slow speeds but man, hit a huge g out or pothole on the interstate and it just eats it up. Has made the drivability of an old truck feel better than new without refreshing any other steering or suspension parts yet.
  4. Jan 12, 2024 at 7:49 AM
    memario1214
    Colton
    Missoula, MT
    '21 Limited MGM CrewMax
    You'll fit, but getting up to that size you'll need to be prepared to do some trimming of the front bumper plastics as well as probably cut the cab mount back a bit if you want to maintain full articulation. I do really like the look of the 1.9" on a Tundra as well. I recommend bringing the back up just a touch as well though as a perfectly level Tundra looks a bit nose high IMO.
    If you haven't sourced your components we're happy to help here at Hotshot Offroad as well. You can always give me a buzz too if you want to talk through things! 406-936-0206
  5. Jan 12, 2024 at 7:57 AM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    The suspension upgrade is great. But you’ll never fit that size tire without substantial cutting. I’m running a 33” tire on a +20 wheel with the same suspension setup and had to do some trimming, cutting, and there’s still a little rub in reverse. I don’t see that size tire fitting easily
    QuikreteTundra and Ojata[OP] like this.
  6. Jan 12, 2024 at 7:58 AM
    2mchfun
    You might find adjustable coilovers better as it allows you to fine tune height on each front corner and adjust over time if you change tire sizes.
  7. Jan 12, 2024 at 8:00 AM
    Ebrperk
    Ebrperk Old member
    South Central Kansas
    2018 1794 MGM
    Tinted windows, go rhino D6 side steps and shorty antenna, Bilstein 5100's rears, 6112's fonts set to 2.5" Rocktrix RT111 18x9 -12offset NItto Terra Grapplers G3's 275/70 R18's. Amp from James @ Tech12volts FRAC Harness
    Go With Hot Shot!! They will treat you right!!
  8. Jan 12, 2024 at 8:01 AM
    Ojata
    South Elgin, IL
    Thank you !
    I’m currently on 5100s in middle setting as I stated in the post and I used a heat gun and bend in the plastic and literally the is almost an inch space between the tire from both sides ! There is 0 rub anywhere on the 33s
  9. Jan 12, 2024 at 8:03 AM
    Ojata
    South Elgin, IL
    I used a heat gun and bend in the front plastic in and 0 rub on the 33s
  10. Jan 12, 2024 at 8:12 AM
    Ojata
    South Elgin, IL
    I’ve being reading in other threads that a lot of people fit that size tire on the same set up or even lower without any issues !
  11. Jan 12, 2024 at 8:16 AM
    Ebrperk
    Ebrperk Old member
    2018 1794 MGM
    I am running 6112's at the 1.9 setting with 33's. I had to cut and plastic weld the front portion of my inner fender to get an inch of clearance
  12. Jan 12, 2024 at 8:17 AM
    memario1214
    Colton
    Missoula, MT
    Oh yeah fully understood, and good on you for not being afraid to move some stuff out of the way! Stepping up probably 1.5" in diameter just makes fitment a bit more interesting than you'd think is all. You can fit them, but just might have to be prepared to move a bit of metal if you don't want contact anywhere (it's an easy mod as far as steel cutting goes so don't sweat it). The +1 offset also doesn't do any favors as it relates to approach angle of the sidewall corner entering the wheel well. Making some assumptions about what your current setup is, here's probably what you'd be looking at. The overlay photo gives a lot of context to just how much bigger the rubber is.
    Ojata[QUOTED][OP] likes this.
  13. Jan 12, 2024 at 8:19 AM
    Ebrperk
    Ebrperk Old member
    2018 1794 MGM
    Yes, I had read that also, but I still had to cut and weld. I believe it has to do with the offset of the rims. I tried just using my heat gun and molding it, but I ended up pulling them off and cutting them and plastic welding them
  14. Jan 12, 2024 at 8:23 AM
    Ojata
    South Elgin, IL
    I’m not afraid to do some cutting
    I have a buddy of mine that have a body shop and he is really good with the torch he would love to cut my truck !!
    memario1214[QUOTED] likes this.
  15. Jan 12, 2024 at 8:28 AM
    Ojata
    South Elgin, IL
    IMG_8697.pngI run 275/60R20 and to step up to 285/65R20 will have to do some cutting ! Thanks again ! As soon I’m ready to pull the trigger on the Bilstein I’ll het a hold of you !
  16. Jan 12, 2024 at 8:34 AM
    memario1214
    Colton
    Missoula, MT
    DO IT! You're already ready to go I can feel it. You just gotta be ready to make room which isn't a problem.
    I'm personally running 295/70/18 on a +25 offset which is slightly smaller than what you're looking at. I was moving plastic, moving plastic... And then just daylighted it :anonymous:
    RobertD and Ojata[QUOTED][OP] like this.
  17. Jan 12, 2024 at 2:27 PM
    GrayWolf
    GrayWolf New Member
    2018 Magnetic Gray Tundra Platinum
    I pulled the trigger on a set of 295/65-20 BFG All-Terrian TA, after installing 6112 and 5160. (2 days out)
    I know I have some trimming to do, as I get the noise when backing up, in the mornings. Still need to get it aligned.
    This is after installing the 6112 <top setting> and 5160 on 275/55-20. Then after getting the BFGs installed (cloudy day). <don't know if pic will show>
    I ran (drew out) the differences between 275/65-20 & 285/65-20 & 295/65-20 or 34" - 34.5" - 35". I thought 1/2" increments, which was a 1/4" increase on top and bottom side. Same for the width, I increased the width by 3/4" going to a 295 from the stock 275. Here again 3/8" increase inside/outside. Enough to cause the rub (the 3" increase), but still the look I was going for.
    I might go to the 3rd (1.9") setting, but don't know what a 0.6" drop will do with the 35s. Have not measured on a flat ground yet. Also, have to decide "if" it is needed or WORTH the time it takes. If it does not bother me, then.... No it is not worth the time.
    YES, you can use the trucks weight to change the setting/compress the springs. Actually, all you have to do is (read up on it/watch the videos) is remove the top nut for the shock and lower the lower control arm. Lots of unbolt this and loosen that, and the lower control are drops down, where you can pull the spring and shock out, adjust it and then put it back in. Yes, there is a LOT of trial and error on the first one, but the second one is much easier. Saved me $300 to have them done at a shop. "OH..." and don't forget to look at the "What setting do you want them set on" when you order your 6112, or they come on the bottom setting... like mine. Nieve, not knowing how these get adjusted AND missing that "what setting" question. I would start with the 1.9" third setting, as I think the top 2.5" might have been too high for level w/ no other lift at the rear. (Maybe that is the answer- add 1/2" to the rear).
    Ojata[OP] likes this.
  18. Jan 12, 2024 at 3:38 PM
    Ojata
    South Elgin, IL
    Thanks for the info mate ! Deffinatly I’ll get them and start from 3rd setting (1.9) and see where I’m standing ! After that the trimming and cutting will start Right now I have 33s and with 5100s on the middle setting (1.57”) and I had to heat ip the front bumper plastic and kind of bent it in and remove the factory mud flaps , because I have fender flares and I have roughly like 1 inch clearance from both sides ! We will see how it will work out ! First I’ll go with the Bilsteins and I have another 10k miles on the tires and get 34.6 tire !
  19. Oct 18, 2024 at 8:59 PM
    Kmcleanw
    Kmcleanw New Member
    Kyle
    Oregon
    2020 TRD Off-Road
    - Bilstein 5160/6112 - BFG KO3 295/70/18 - Black Emblem badges - AJT key fob - Front window tint and windshield Sun strip - 2021-22 TRD Pro bed storage boxes - leather wrap steering wheel - MeSo Customs LED white/red cabin lights - TRD shift knob
    I’m running the 6112/5160 combo and fit 295/70/r18 BFG KO3s on stock rims. I’ve had the billsteins for about 3 years before I swapped out the stock tires. They are solid all the way around and fitting a larger tire is a huge bonus. Big improvement over stock. Get them, you won’t regret it.
    AZBoatHauler likes this.
  20. Oct 18, 2024 at 10:36 PM
    AZBoatHauler
    So.Arizona
    Shocked to see 6112 getting so much hate lately. Only 65k miles on mine.
    RobertD and Tbrandt like this.
  21. Jan 27, 2025 at 6:49 AM
    QuikreteTundra
    QuikreteTundra Previously owned '16 Tacoma SR5 Pro
    '21 Tundra Cement TSS OR 4x4 | '23 T4R Lunar TRD ORP
    What items are best that you used to do some trimming and cutting of the fender? I'm finding I need to do that as well but haven't yet determined what tool to use. I wasn't sure if something as simple as an exacto knife would be sufficient lol.
  22. Jan 28, 2025 at 2:30 PM
    memario1214
    Colton
    Missoula, MT
    An Exacto knife will require a mountain of pressure to cut through OEM plastics. A sheetrock knife can do it, but I always recommend something like a Dremel or oscillating tool.
  23. Jan 28, 2025 at 2:44 PM
    Ebrperk
    Ebrperk Old member
    2018 1794 MGM
    With Patience(be careful I sliced my thumb pretty good )a heat gun and utility knife, you can massage all the plastic fender liner out of the way, You could also use bumper shims to move your bumper out. A Dremel would work well. I used a Utility knife, heat gun and my plastic welder
  24. Feb 7, 2025 at 8:58 AM
    SLOWER
    SLOWER New Member
    I went from 5100s and stock rears after 55K miles, to the 6112/5160 combo and absolutely love it.
  25. Feb 10, 2025 at 11:03 AM
    memario1214
    Colton
    Missoula, MT
    Solid upgrade! :thumbsup:
    Ebrperk likes this.
  26. Mar 21, 2025 at 12:37 PM
    BigWheel
    BigWheel New Member
    Tell us more?
    What’s the ride like off road?
    I don’t go fast off road, relatively slow.
  27. Mar 21, 2025 at 1:18 PM
    IEsurfer
    IEsurfer New Member
    jimbo
    Socal
    2005 tundra 4x4
    I have the 6112 5160 top clip setting with coach builder shim to compensate for driver lean and plus 3 coach builder shackles in the rear oem leafs
