Bilstein 5160 reservoir frame mount??
Discussion in '2.5 Gen Tundras (2014-2021)' started by Redrider29, Dec 17, 2019.
  1. Dec 17, 2019 at 1:33 PM
    Redrider29
    Redrider29 [OP] HARDTRD
    Mitch
    2019 SR5 Crewmax TRD Offroad 4x4 Cement
    Paint matched mirror caps, grill surround, hood bulge, and Bumper Shellz Wireless phone charger in center consule TRD rear sway bar Black painted TRD off road wheels with TRD center caps Black emblems TRD air filter Tyger roll up tonneau cover Extra USB plugs in cab TRD Pro grill Paint matched Bumper Shellz 1.25" Spider Trax spacers Lamin-x fog light covers yellow-removed Diode Dynamics SS3 amber fogs Bilstein 5160 rear shocks DIY bed rail system AJT TSS relocation bracket AJT interior chrome delete bits and pieces Caliraised LED 32" light bar bracket GG Lighting 32" light bar
    First question is if the Bilstein 5160 reservoir has to be mounted to the shock or can it be frame mounted with a bracket?
    Second question is if anyone has done a frame mount for the 5160, what did you do and are there any pictures?
    Thanks
    Mitch
    Rica25 likes this.
  2. Dec 18, 2019 at 3:04 AM
    Flyinryank
    Flyinryank New Member
    Ryan
    Las Vegas, NV
    White 2015 CM 4x4
    I’m interested to know too.
    My buddy just got them for his Tacoma and they included a frame mount for the reservoirs. Wondering if new tundra 5160 kits come with a frame mount as well.
    Rica25 likes this.
  3. Dec 18, 2019 at 3:47 AM
    ShreveportTSS
    ShreveportTSS Huh?
    Eric
    Louisiana
    2018 5.7 4x4 Crewmax TSS
    Rica25 and Vr0ck like this.
  4. Dec 18, 2019 at 5:26 AM
    CavBluTundra
    CavBluTundra CavBluisdabomb
    Howard
    2018 TRD Off Road Limited
    So for you 5160 swappers, I have a question. Do you need to do anything else to the truck if you put the 5160's at all 4 corners, and front on about the middle setting? In other words, all of the posts talking about diff drop, bearing angles, etc??? I want to put the 5160's on, but don't want to do the other stuff. Not interested in lifting, only slight front end lift/level.
    Rica25 likes this.
  5. Dec 18, 2019 at 5:58 AM
    Rica25
    Ricardo
    Tulare
    5160 are onlyvforbthe rear the matching set is the 6112s for front
  6. Dec 18, 2019 at 6:13 AM
    CavBluTundra
    Howard
    So if I go with 6112's in the front, do I have to concern myself with the comments in my original post?
    Rica25[QUOTED] likes this.
  7. Dec 18, 2019 at 6:21 AM
    Rica25
    Ricardo
    Tulare
    6112s dont have a reservoir just new strut and new coil
  8. Dec 18, 2019 at 6:24 AM
    Rica25
    Ricardo
    Tulare
  9. Dec 18, 2019 at 6:27 AM
    equin
    equin Texarican Tundra
    Ed
    DFW, TX
    No need for carrier bearing spacer if you don’t lift the rear. 5160’s don’t lift the rear.
    As for the front, I’m not a believer in the diff drop. I set my 6112’s at 1.9” and did not do the diff drop. Others believe it’s necessary to keep the CV axles more in line with the stock geometry if you lift the front with coilovers.
    Rica25 likes this.
  10. Dec 18, 2019 at 6:32 AM
    Bprose
    Bprose Old member
    VA
    17 Tundra CM TRD
    Nope. Just put them on. Don’t worry about a diff drop unless you go higher in front. Tears don’t need to do anything
    Rica25 likes this.
  11. Dec 18, 2019 at 6:35 AM
    CavBluTundra
    Howard
    Thanks fellas. Still trying to decide my route when I purchase new tires.
    Rica25 likes this.
  12. Dec 18, 2019 at 6:37 AM
    equin
    Ed
    DFW, TX
    Oh, and as for the frame mounted reservoir, I suppose you could do that, but you’d probably have to fabricate the mount. Easier to just buy the aluminum piggy-back bracket and attach it that way I would think.
    Rica25 likes this.
  13. Dec 18, 2019 at 9:38 AM
    WestexSBK
    WestexSBK New Member
    2019 SuperWhite CM TRD Sport 4x4
    Here ya go! Personally I would run the bilstein piggyback mount listed by those other guys
    Rica25 likes this.
  14. Dec 18, 2019 at 9:44 AM
    WestexSBK
    I won’t coat tail what others have said but of you raise/level the front end you will need an alignment afterwards
    Rica25 likes this.
