Bilstein 5100s
Discussion in 'Suspension' started by 4Yotasince99, Jun 6, 2019.
  1. Jun 6, 2019 at 2:49 PM
    4Yotasince99
    4Yotasince99 [OP] New Member
    Eric
    2018 CM Tundra TRD Sport
    Bilstein 5100 (middle setting) - front only, Driver's side grab handle installed, JL Audio upgrade from Tech 12
    ok sorry I know this topic has been beat to death, but I’m new to the site... having 5100’s installed on the front on the middle setting.... hoping the back is still slightly higher; not touching the back with anything right now, thoughts?
    Had the 2006 done and loved to the look, hoping this new one looks good too
  2. Jun 6, 2019 at 2:59 PM
    CCLJ03
    CCLJ03 Tundra forever
    Craig
    2018 TRD Off-Road - Cement
    I think the middle setting does leave just a smidge of rake.
    Put anything in the back and you’ll be chin up though.
  3. Jun 6, 2019 at 3:04 PM
    xtyfighterx
    xtyfighterx New Member
    Ty
    North Idaho
    2015 Black Crewmax Mid Travel
    Ya you will be fine middle setting and even top setting you will be level
  4. Jun 6, 2019 at 3:21 PM
    4Yotasince99
    Eric
    Great thanks, I just don’t wanna be sittin ass heavy when I hook my boat up, sounds like the middle setting is the right choice. Wouldn’t think there’d be a whole lotta difference in the ride bc it’s got stock Bilstein on there now
    Black Wolf likes this.
  5. Jun 6, 2019 at 3:31 PM
    xtyfighterx
    Ty
    North Idaho
    Middle would be good if you are hauling and you still might be nose high honestly lol these stock leafs are soft
  6. Jun 6, 2019 at 4:16 PM
    CJK
    CJK New Member
    2019 Cement Gray Tundra TSS CrewMax
    I am having 5100's installed at the middle level on my '19 this weekend. However, I am undecided on just having the fronts installed or should I do front & rear? Would love to here from you all about the PRO's & CON's of doing only fronts or both. TIA!
  7. Jun 6, 2019 at 4:21 PM
    Omohundro
    Omohundro 2018 Not a Pro
    Jody
    McMinnville TN
    2018 Tundra Platinum
    I thought I had something to say,but I don’t.
  8. Jun 6, 2019 at 4:44 PM
    marcfs71
    marcfs71 New Member
    Marc
    2010 Grey Tundra TRD Offroad Pkg with TRD Supercharger
    Dual Exhaust
    I notice the fronts much more than the rears but if your budget allows, I would do the rears too.
  9. Jun 6, 2019 at 4:45 PM
    1999cutiger
    1999cutiger Top Flow Lifestyle
    2017 Toyota Tundra SR5 4x4
    RBP 67R AK-8 20x9 wheels General Grabber ATX 275/60/20
    I did the middle setting up front and .75” rear shackles...I think it’s perfect.
  10. Jun 6, 2019 at 6:03 PM
    duece292
    duece292 Appalachian American
    Greg
    Green Bay, WI
    I have 5100's on all four corners, fronts on the middle setting. I did all four because I figured that if I'm doing the fronts I might as well do the rears, my OCD wouldn't allow shiny silver shocks up front and dirty yellow shocks in the back and it's only money :rolleyes:.
    The pics are bad, truck is filthy and it's a 2nd gen but it should give you an idea of how it sits. 4ft level on the pinch weld and on the bedrail.20190606_192537.jpg 20190606_193754.jpg 20190606_193723.jpg
    parker44, Hol Milk and Tundraman1000 like this.
  11. Jun 10, 2019 at 5:22 PM
    4Yotasince99
    Eric
    Got the Yota done today... middle setting has me with about 1” rake back to front. Measured from center of wheel to bottom of wheel opening... 24” back, 23” front, love the look, exactly what I was hoping for and the stock tires don’t look stupid so i can still wear em down before going to an AT.
  12. Sep 28, 2019 at 10:54 AM
    Maxi13
    Maxi13 GuttenTight
    Montucky
    2020 Cement Sr5 TRD OR
    Nudding yet
    I did that on my 2010 and found The ride too stiff. How does your ride?
  13. Sep 30, 2019 at 5:52 AM
    attillatundra
    attillatundra New Member
    I am very curious too as to how your ride is now. Stiffer? Is it uncomfortable in any way? Is the habdling better now?
    Thanks for any input.
    Rica25 likes this.
  14. Oct 6, 2019 at 10:39 AM
    'fro
    'fro New Member
    2014 Tundra 1794 - MGM
    None YET
    Yeah, I'm curious too. Had the middle setting on my 07 Tacoma and the ride was rough. I put on toytec hd springs, put the shocks back on bottom setting and it was butter.
    Maxi13 likes this.
