Bilstein 5100s and 275 70 r18
Discussion in '2.5 Gen Tundras (2014-2021)' started by Dustydirt19, Jan 12, 2017.
  1. Jan 12, 2017 at 2:21 PM
    Dustydirt19
    Dustydirt19 [OP] Hoghead
    Dustin
    Duluth, MN
    2015 Blue Ribbon Metallic 5.7L 4WD SR5 TRD DC
    ProComp 6" stage 2 lift 18x9 Fuel Vapor -12 offset 35x12.5 Nitto Ridge Grapplers BullyDog Tuner Gibson Metal Mulisha cat-back exhaust, S&B cold air intake, Color matched TRD PRO Grille, Compustar Remote Start N-Fab Hooped Nerf Bars, AMI Big stick antenna, Salex organizer and tray, Weathertech laser cut floor mats, Weathertech window deflectors Black out badge Black out front and rear bumper Black out flags 24/7 black out TRD Off-road decals Spray in Line-X Bedliner Scosche phone mount Soft rolling tonneau cover TRD pedals and footrest
    *Posted this in suspension as well*
    I'm sure this has been posted before but I'm being too lazy to try and search for the answer. I was going to lift my truck with a toytec boss kit but I ran into a family issue and can't spend that much right now. I was wanting some info on the Bilstein 5100 shocks. Just looking to level the truck out for now and jump up to a 275 70 18 tire. Can you guys give me some pros and cons. Any other add ons I would need for this setup? Any rubbing issues? I am going to use my stock rims so I was also wondering if I should get spidertrax spacers or not. @Sean266 @csuviper @Law323 I know you guys are pretty knowledgeable about this. What are your thoughts. Thanks
  2. Jan 12, 2017 at 2:51 PM
    computeruser6
    computeruser6 Gott Mit Uns
    Dirk
    Escondido
    2008 Regular Cab Tundra
    My LT285/70R-18 tires fit on stock wheels without spacers. Also, look here.
    Dustydirt19[OP] likes this.
  3. Jan 26, 2017 at 8:05 AM
    balou
    balou Texas Tundra
    2016 tundra cewmax 4x4 tss option
    bilstein 5100 adj front shocks led lights for bed
    I set up 5100's on my tundra sr5 tss with 20 in wheels. No problems looks good while i save money for a complete toytec lift
  4. Jan 26, 2017 at 8:37 AM
    zcarpenter92
    Zach
    NE Colorado
    2008 Desert Sand 5.7L DC
    In sig
    I don't think you'd have much trouble fitting 275/70's with the 5100's set on the middle or top setting. They're only 10.8" wide in most cases, just a little taller than 275/65's.
    Law323 likes this.
  5. Jan 26, 2017 at 8:55 AM
    Fly'n Family
    Fly'n Family New Member
    TX / CO
    2014 CM Limited
    Might as well ask the same - Billsteins in front and back - 18 x 9 with 25 offset - 285/65 18 BFG's.....any foreseen issues? Shop says no problem - no UCA's/alignment/rubbing issues. Y'all agree?
  6. Jan 26, 2017 at 9:15 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    go bigger!
    zcarpenter92 and Law323 like this.
  7. Jan 26, 2017 at 10:05 AM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    I'd jump to 295/70!!
    joonbug likes this.
  8. Jan 26, 2017 at 10:33 AM
    Fly'n Family
    TX / CO
    2014 CM Limited
    The two sizes of BFG's KO's they suggest was to use either the 285/65 18 or 305/65 18.
    I don't want rubbing hassles - but also want things to be symmetrical (properly proportioned) in appearance. Do you suggest the 305? Or some other tire dimensions?
  9. Jan 26, 2017 at 11:08 AM
    Zharris
    Zharris Merica!
    2016 Super White 4x4 Crewmax
    @Fly'n Family I'm running 285/65 18 trail grapplers on a +30 offset with no rub. No trimming or anything required and I've still got stock suspension. With those Bilsteins, you should be golden.
  10. Jan 26, 2017 at 11:11 AM
    Zharris
    Zharris Merica!
    And while this thread is up, anyone be able to point me in the direction of the Bilstein 5100s I would need for a 2016? Or are they the same as the ones for the 14? Like Amazon sells the Bilstein set for $352 but it says it only goes up to 2014s.
  11. Jan 26, 2017 at 1:06 PM
    zcarpenter92
    Zach
    NE Colorado
    In sig
    Same as the ones for a 14, Toyota didn't change the suspension at all from the 07's-17's.
    Zharris[QUOTED] likes this.
  12. Jan 26, 2017 at 1:16 PM
    CaptTyler
    CaptTyler Life’s too short to have an ugly boat.
    Tyler
    2018 Ram 2500 Cummins
    I PERSONALLY would set them on the middle setting. To me the top setting should have some kind of rear lift in addition.
    I'm very happy with my 5100's.
    SouthBoundSteve likes this.
  13. Oct 25, 2017 at 1:24 PM
    SC_HANK
    SC_HANK New Member
    2016 Tundra TRD Off-road
    2016 SR5 TRD Off-Road: New here and know this has been asked and a link is posted above but see people saying both 285/65 R18 or 275/70 R18 will both fit a stock SR5 TRD Off-Road without mods or rubbing- does anyone have experience with this and what works the best? Would 5100's help? Thanks.
