Bilstein 5100
Discussion in 'Suspension' started by Pimpala1962, Sep 14, 2024.
  1. Sep 14, 2024 at 3:48 AM
    Pimpala1962
    Pimpala1962 [OP] New Member
    Kyle
    Massachusetts
    2015 double cab
    So im getting ready to install some 5100s on the front of my 15 dc , planning on going top clip and i believe bilstein includes a washer/spacer for the factory bump stops on the frame, my question is being from massachusettes theres a very good chance the factory bump stops will snap when i try to remove them to put the washer/spacer on , how necessary are they and can i just leave the factory bump stops the way they are and tun the 5100 on top clip without problems ?? Also to add truck is my daily driver never off road or anything like that strictly pavement
  2. Sep 15, 2024 at 9:12 AM
    Pimpala1962
    Kyle
    Massachusetts
    2015 double cab
    Any idea?
  3. Sep 15, 2024 at 9:59 AM
    pvn.beluga
    pvn.beluga New Member
    Phuc (Phooc)
    Connecticut
    Yeah, you can leave the bump stops as is. No need for washer/spacer.
  4. Sep 15, 2024 at 10:09 AM
    Pimpala1962
    Kyle
    Massachusetts
    2015 double cab
    Awesome that will save me some headaches , i know they will end up snapping on me
  5. Sep 15, 2024 at 11:27 AM
    That extra washer is supposed to help
    Limit up travel due to the extended length design. I ran my first set without it, blew the passenger side shaft seal out at 45k miles. On my second set now with the spacer adeed around 50k with no issues.
  6. Sep 15, 2024 at 11:30 AM
    pvn.beluga
    Phuc (Phooc)
    Connecticut
    What did you do to blow the seals? I’ve ran mine for 40k now.
  7. Sep 15, 2024 at 11:34 AM
    Ran it without the washer and likely exceeded the uptravel range of the shock. Or just got unlucky.
  8. Sep 16, 2024 at 2:03 PM
    Pimpala1962
    Kyle
    Massachusetts
    2015 double cab
    So one vote for no washer no problem and one for no washer and problems
  9. Sep 16, 2024 at 2:11 PM
    Reddawg1100
    Reddawg1100 New Member
    FL
    21 SR5 Midnight Black DC, AKA: Bat Truck
    Custom rims, front leveling spacers
    Certainly not a suspension guru, but when I was researching moderate lifts and bump stops, I found it's generally recommended to install larger bumpstops or in your case the spacer. I have a mild two-inch lift in front and run Superbumps. So, two votes for the washer!
    KNABORES likes this.
  10. Sep 16, 2024 at 2:23 PM
    I vote washer based on my prior experience shared above
  11. Sep 17, 2024 at 7:41 AM
    Pimpala1962
    Kyle
    Massachusetts
    2015 double cab
    1-no washer no problem
    2- no washer ;problems
    its getting interesting now gentleman
  12. Sep 17, 2024 at 8:27 AM
    They include the washer for a reason. Doesn't mean your truck will explode if you don't use it.
