Bilstein 5100 towing
Discussion in 'Suspension' started by Kalashnikov 47, Oct 15, 2021.
  1. Oct 15, 2021 at 8:05 AM
    Kalashnikov 47
    Kalashnikov 47 [OP] New Member
    Minnesota
    2018 Sr5 double cab gang
    Hello people, I'm getting so much mixed reviews about the 5100s sucking at towing. I was planning in doing 5100 all around with the front at top setting then getting cb+1 lift shackles in the rear so I can have a little rake, I don't want a leveled truck. Any thoughts and experiences please it would be greatly appreciated
  2. Oct 15, 2021 at 8:16 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    Where are you getting your info?
    They are firmer than stock, so should help with control towing. Certainly better than the stock black toyota shocks. Add the rear sway bar and your towing and cornering will be even better.
    toyofan87 and Kalashnikov 47[OP] like this.
  3. Oct 15, 2021 at 8:17 AM
    RobertD
    Robert
    DFW, Texas
    Well... like everything its situational. Provide more detail as to what you will be towing (weigh, frequency, terrain) and folks can chime in.
    5100 are a great upgrade to the stock shocks but if you are towing heavy loads most of the year over difficult terrain, there are other options more suited for that. If you are looking for a low cost improvement to the stock set up, hard to beat the 5100's
  4. Oct 15, 2021 at 8:18 AM
    Kalashnikov 47
    Minnesota
    I've read it in other tundra forums, and just over all googling around.
  5. Oct 15, 2021 at 8:41 AM
    1P7R9O4
    1P7R9O4
    AZ
    ‘17 White 1794 Pro
    tows just fine…I’ve pulled an enclosed trailer with 2 quads inside ~3500lbs; regularly towed boat 17.5’ ~2500lbs; 21’ bass boat ~3500lbs…all with 5100s all the way around with no issues at all.
    If you’re regularly towing something like a 30’ 8k+ lb travel trailer (i.e. not just the 1x a year exception), I’d look at doing something different in the rear (leaf pack; RAS; sumo, airbags, etc.)
    as someone above mentioned, the 5100s are better/upgrade than stock, and the stock tow rating on your truck is plenty, unless you’re regularly pulling a large travel trailer/toy hauler.
  6. Oct 15, 2021 at 6:59 PM
    Kalashnikov 47
    Minnesota
    Do you have your set up at top setting if so did you do front diff drop kit? An a for the rear what is your setup?
  7. Oct 15, 2021 at 8:03 PM
    1P7R9O4
    1P7R9O4
    AZ
    ‘17 White 1794 Pro
    No diff drop…had at highest setting in Front and nothing in rear with 5100’s…then switched to TRD Pro Fox with additional lift kit from Westcott Designs…ended up around 3-3.5” up front and 1” in rear. They highly advised against a diff drop, so never added. Both set ups tow the same from my experience
  8. Oct 15, 2021 at 11:21 PM
    AZBoatHauler
    So.Arizona
    I’ve towed with 4600 TRD shocks and 6112. If you have the OEM black shocks it will be firmer but in a good way if your towing considerable weight. If you have the TRD OR suspension it probably won’t feel much different.
    If you’re worried about ride quality and rake consider the middle setting. I went 6112 at 1.9” and CB+2 shackle to not max out my UCAs and maintain some rake.
    ColoradoTJ likes this.
  9. Oct 16, 2021 at 11:26 PM
    Jhon
    Jhon New Member
    On the Oregon Trail
    2021 SR5 TRD OR
    Blue SumoSprings are a nice upgrade for towing and hauling. You won’t notice them them empty but with 500lbs on the ball they make a huge difference.
  10. Oct 17, 2021 at 12:35 AM
    Rockgate
    Rockgate New Member
    Terry
    Middle TN
    2022 CMLB TRD OR Prem. 4X4 and 2002 RCLBV65Spd
    I've got 5100's top setting with 2 & 1 shims, the rear lift is Coach +3 shackles. I tow a 16' enclosed a few times a month. Seems to ride just fine to me.
    Kalashnikov 47[OP] likes this.
  11. Oct 17, 2021 at 5:21 AM
    Kalashnikov 47
    Minnesota
    Do you picture of your truck, does it give the tru k the rake it needs?
  12. Oct 18, 2021 at 10:25 AM
    Rockgate
    Rockgate New Member
    Terry
    Middle TN
    There's a little bit of rake. My '14 Tundra had same stuff but only +2 shackle. It was fairly flat level.
  13. Oct 18, 2021 at 10:34 AM
    memario1214
    Colton
    Missoula, MT
    '21 Limited MGM CrewMax
    Do you have them on your personal rig? I have had really mixed reviews from customers saying that they make the ride incredibly stiff when unladen. Can you share what other suspension work you have done?
  14. Oct 18, 2021 at 10:36 AM
    Kalashnikov 47
    Minnesota
    Damni should've gotten the +3 shackles I need the back to rake more, thanks buddy
  15. Oct 18, 2021 at 10:52 AM
    Jhon
    Jhon New Member
    On the Oregon Trail
    2021 SR5 TRD OR
    My truck is stock riding on stock Bilstein shocks. I don’t carry a constant load and have about 1/2” between the frame and Sumos when empty. Truck rides like stock with the benefit harsh speed bumps feel less harsh. Loaded for camping I’m at almost 7200lbs and towing a trailer and they perform wonderfully. The ride is firm and controlled, not jarring. I think if someone were just leveled with the stock rear the blue Sumos would be a good match.
    Timbrens are a much harsher system and don’t give as much. I also would not recommend black or yellow Sumos unless someone was running around with a significant constant load.
    I’m planning to install the Toytec Eibach 2.5”/1.5” lift next year and at that time will call Super Springs International and order a custom set of blue Sumos for the lift. Stock height will be trimmed for a bump stop. They are easy to swap back and forth.
  16. Oct 18, 2021 at 10:56 AM
    brain12984
    brain12984 New Member
    south Carolina
    I have Bilstein 5100 on the top setting on the front, 5100 on the back with the TRD sway bar. I don't have any problems with towing a 5k boat. As was stated before, they are stiffer.
    I have the Timbren SES bump stops installed on the back. I had a pallet of sod in the bed last week and it didn't go down very much. The guy at the super sod was impressed for he had a tundra in before me that it sank down very low.
  17. Oct 19, 2021 at 6:33 PM
    kidrman
    kidrman New Member
    2020 Tundra CrewMax
    I have a 2020 Crewmax with 5100’s on all four corners. Fronts are at top setting with 1/4” shim on each side and 1.5” block in the back. Tow a two place enclosed snowmobile trailer and other trailers on a regular basis. Works great!
    I do have airbags in back but don’t air them up unless I am really heavy on the tongue (rare).
  18. Oct 19, 2021 at 8:21 PM
    AzTundraT
    AzTundraT New Member
    2018 Inferno TRD
    2018 TRD 4x4 Off Road. The stock shocks are Bilstein's correct? Are they 5100's?
  19. Oct 19, 2021 at 8:32 PM
    Oey12
    Oey12 New Member
    Joey
    New York
    2020 SR5 TRD OFFROAD
    Yes they are Bilstein’s but they are not 5100’s or 4600’s (as commonly claimed). Those are custom valved, on the soft side, for Toyota applications. Even the diameter is different.
    wakeboarder likes this.
  20. Oct 19, 2021 at 8:40 PM
    AzTundraT
    2018 Inferno TRD
    Thank you for the info. Can they be used with a 2" leveling kit? I am not trying to get too aggressive, just want to level the front. I don't do any off-roading. The worst I have to do is some badly washed out dirt roads. Also never carry much weight in the bed. I have an F350 Dually for heavy loads.
    Oey12 likes this.
  21. Oct 19, 2021 at 9:18 PM
    Oey12
    Oey12 New Member
    Joey
    New York
    You can use the 5100’s to level the front and you would need blocks to longer shackles to raise the rear. Personally I would not install a spacer lift that is thicker than a 1/2 inch (approximately 1 inch lift)…an adjustable shock such as the Bilstein is a better option. The 4600’s are not adjustable and are designed for stock applications whereas the 5100’s are designed for lifted applications.
    One more piece of friendly advice…look at Eibach adjustable shocks. Their valving is better ESPECIALLY as a daily driver based on what you were said in regards to carrying weight. Nothing wrong with the 5100’s per se. Most popular by far but definitely on the stiffer side in the ride department…
    AzTundraT[QUOTED] likes this.
