Bilstein 5100 shocks will help squeeze BFG 35X12.5
Discussion in '2nd Gen Tundras (2007-2013)' started by BreadmanClay, Dec 13, 2017.
  1. Dec 13, 2017 at 10:26 AM
    BreadmanClay
    BreadmanClay [OP] New Member
    Clay
    White House, Tennessee
    2020 Tundra, Black, Platinum, CrewMax, 5.7, 4WD
    If you have an Amazon Prime account then order the Bilstein 5100 shocks from there; it's cheap with free and quick shipping.
    My buddy and I installed them within 4 hours on my 2012 Crew Max Rock Warrior. If you have a coil spring compressor, jack stands and some basic tools then you wont have any problems installin
    g them. We put them on the highest setting so I could squeeze BFG 35X12.5 All Terrain K02.
    Before installing the new tires, I took off the small mud flaps (connected on the back of the front bumper) for more tire clearance. Then bending or pushing the inner fender (connected on the back of the front bumper) to get a little more tire clearance.
    I have always bought BFG All Terrain tires for my trucks in the past and I know that BFG usually round up their tire size numbers. For example, my tires say 35X12.5 but if I measured them with a measuring tape then I will get something like 34X12, give or take. So after installing the 5100 bilstien shocks with the highest setting, removed the front bumper mud flaps, and pushed the inner fenders out, the tires fit perfectly. The only time my tires rub is when I go off roading or hit a big bump while turning sharply. The tires don't touch the fenders, just the front inner fenders.
    Also keep in mind that I used the stock Rock Warrior edition rims during all of this. Your rims might or might not work depending on the off set. That type of stuff is out of my knowledge, I totally gambled on if it would work or not and it did. The ride didn't really change but make sure you take your truck to a shop after installing the new shocks, the camber will be all out of wack and needs to be adjusted. Some shops will not work on it due to insurance reasons but some will work on it with an extra fee.
    dcsleeper408 likes this.
  2. Dec 13, 2017 at 10:50 AM
    soarvet
    soarvet New Member
    2017 Silver Tundra Crewmax 4x4 XSP package
    Useless thread unless you post pics..
