Bilstein 5100 question
Discussion in '2.5 Gen Tundras (2014-2021)' started by Big_Ed, May 12, 2020.
  1. May 12, 2020 at 7:59 PM
    Big_Ed
    Big_Ed [OP] New Member
    Spring, Tx
    2016 Tundra
    Searched to no avail....
    I have a 2016 Platinum 2WD 85,000 miles. I just got it late last year. Suspension is too squishy for me. I came from a 1997 F250, that thing rode like a truck. The Tundra ride is too luxurious. I have added a TRD rear sway bar and a Sequoia front sway bar.
    Bilstein 5100s are pretty popular. Are they stiffer than my stock 85,000 mile suspension? I wont be going off road. I will periodically be towing a trailer, maybe 3,000 pounds total weight.
    Any other shocks I should consider?
  2. May 13, 2020 at 1:34 AM
    linwozzle
    linwozzle New Member
    Linden
    2014 SW Tundra Platinum 4x4 CM
    Bilstein 5100s are good budget shocks and struts, you can also level the front of the truck with them. Have you considered going from a P to LT tire? That would also make a difference
  3. May 13, 2020 at 1:58 AM
    Bloomjtundra
    Bloomjtundra New Member
    Josh
    2011 Tundra DC 4x4
    I just put on 5100’s on my 2011. The truck only had 29k. I thought it road very trucky compared to my old 1994 F150, which felt bouncy like a bus (it likely should have had new shocks installed).
    I now have LT275/70R18 tires and new 5100. The ride is stiff and you feel the road but very controlled in my opinion. I like it.
    maybe your 85k shocks are just a bit worn.
    Black Wolf likes this.
  4. May 13, 2020 at 6:40 AM
    PeakIT
    PeakIT Old Member
    Utah
    2019 OR Tundra Double cab
    Coachbuilder 3” shackles, King extended travel, SPC upper arms, 5:29 gears, FN FX rims,35"tires, leer shell, grill
    5100 are a little stiffer at stock height and go up incrementally the higher lift setting you set them at because of control arm geometry and preload.
    Bloomjtundra likes this.
  5. May 13, 2020 at 9:07 AM
    Bloomjtundra
    Josh
    2011 Tundra DC 4x4
    I didn’t mean to indicate overly stiff. The ride is firm and truck like but that’s what I want and think it should be. The Bilsteins seem to manage the bumps better with less bounce which feels more control.
  6. May 13, 2020 at 9:15 AM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    The 5100 ride in the Sequoia is pretty close to stock. Not sure you're gonna get the rigid ride you want out of them
  7. May 13, 2020 at 9:19 AM
    sr5shark
    sr5shark Shop smart. Shop S-Mart.
    Alan
    Walnut Creek, CA
    2016 SR5
    Fox & ADS | SCS SR8 | Nitto RG
    Toyota uses 2 different shocks for the Tundra - the black ones are (I've heard) pretty soft and plush. The yellow shocks that come with the TRD package are much more firm than the black ones.
    The 5100s will be an upgrade to both. You will see the greatest difference if upgrading from the black shocks.
  8. May 13, 2020 at 2:43 PM
    Big_Ed
    Spring, Tx
    2016 Tundra
    Thanks for the replies. I will go with the Bilstein 5100s and get LT tires when the current ones wear out.
    SC_TRD likes this.
  9. May 14, 2020 at 11:23 PM
    SuperDuty48
    SuperDuty48 New Member
    DUG
    San Diego Ca
    2007 Gold Pyrite Crew Max Limited
    Pioneer Apple Play Deck with Back Up Camera, Chrome AVS Bug Shield, Tinted Out ALL 6 windows and windshield stripe, LED 40 watt cube fog lights. 2019 18”TRD Sequoia Rims / Michelin AT tires .
    What if I want to lower the front 2” and 4” in the rear. Then what’s my best option for ride and stability, I’m planning on installing a rear sway bar soon.
  10. May 15, 2020 at 12:44 AM
    Bravohook
    Bravohook New Member
    Addame
    NY
    2007 RCSB
    Cool Things
    Sosperformance makes lowering kits for the Tundra that r great quality
  11. May 15, 2020 at 4:19 PM
    SuperDuty48
    DUG
    San Diego Ca
    Ok I’ve measured and my passenger side measured at the top of the fender well to ground was 1” higher? Front and rear. Maybe the previous guy was overweight? The seat is pretty crushed. That’s on “the list”
    Anyways ,what if I did something like the Beltek 4100. Just throwing it out there I know nothing on Lowering. My last F250 was lifted 6” with 33”s
    OH MY!,,, gosh just checked the website for SOSperformance
    Thanks Bro!
  12. May 15, 2020 at 5:44 PM
    TNTundra16
    TNTundra16 YOU BIG DUMMY!
    Cam
    Amish Country, TN
    2016 CM SR5 4x4 SSM
    My 2016 has 90k on it and I just put 5100s on my truck 2 weeks ago. I set the fronts on the middle setting (1.57" lift). The ride is firmer but it takes bumps way better than the stock black ones
  13. May 15, 2020 at 6:51 PM
    Big_Ed
    Spring, Tx
    2016 Tundra
    Do you have P (stock) or LT tires?
  14. May 15, 2020 at 6:54 PM
    TNTundra16
    Cam
    Amish Country, TN
    2016 CM SR5 4x4 SSM
    P rated 275/60R20 Falken Wildpeak AT3W. Love them!
