Bilstein 5100 Install Question
Discussion in 'Suspension' started by 1999cutiger, Dec 6, 2018.
  1. Dec 6, 2018 at 2:57 PM
    1999cutiger
    1999cutiger [OP] Top Flow Lifestyle
    2017 Toyota Tundra SR5 4x4
    RBP 67R AK-8 20x9 wheels General Grabber ATX 275/60/20
    I plan on using the middle setting for my Bilstein 5100’s up front.
    Using the middle setting, do I use one or both of these washers?
    I appreciate your help...I can’t find the answer anywhere and I plan on installing these on Saturday.
  2. Dec 6, 2018 at 3:04 PM
    :popcorn:
    One of my future mods. Keep us/me posted.;)
  3. Dec 6, 2018 at 3:11 PM
    MacCTD
    MacCTD New Member
    2010 CM 4x4
    5100s
    I don't think the washers have anything to do with which setting you use, the snap ring on the body of the shock determines the setting/height
  4. Dec 6, 2018 at 3:47 PM
    1999cutiger
    The directions indicate that if the lowest height setting is used, the washers aren’t needed. So it appears there is a correlation between the height setting and the washers.
  5. Dec 6, 2018 at 4:28 PM
    Mikekoot
    Mikekoot New Member
    Canadia
    2018 MGM tundra sr5 DC /2014 SSM Toyota Tacoma sr5 DCLB
    What are the washers for? I'm in the middle setting
  6. Dec 6, 2018 at 4:29 PM
    Mikekoot
    Mikekoot New Member
    Canadia
    I did mine in the middle setting. Have no clue what the washers are for
  7. Dec 6, 2018 at 4:43 PM
    Jengel451
    Jengel451 Misanthropist
    The Bitterroot, MT
    2017 Barcelona TRD Limited CrewMax
    3/1.5 Toytec/Icon AAL, 17" Rebounds, 317-70-70 ST Maxx's
    The washers are for the bump stops. Turn them off, throw the spacer on and reinstall.
    mattyd170, NewImprovedRon and 15whtrd like this.
  8. Dec 6, 2018 at 4:44 PM
    1999cutiger
    Makes sense. Both washers for the middle height setting or just one?
  9. Dec 6, 2018 at 4:48 PM
    Jengel451
    The Bitterroot, MT
    Tundras have two bump stops per side. They have nothing to do with the spring setting and everything to do with shock body length and bottoming.
    Mikekoot and rvrats2 like this.
  10. Dec 6, 2018 at 5:02 PM
    Mikekoot
    Mikekoot New Member
    Canadia
    That's what I figured. Necessary if not constantly bottoming out?
  11. Dec 6, 2018 at 5:13 PM
    Jengel451
    The Bitterroot, MT
    It literally takes 3 minutes per side. They'll be staring you in the face while youre doing the shocks. Easiest part of the job.
  12. Dec 6, 2018 at 5:14 PM
    Mikekoot
    Mikekoot New Member
    Canadia
    I did mine a while ago but didn't install the washers. I'll try find the washers haha
  13. Dec 6, 2018 at 5:23 PM
    MacCTD
    MacCTD New Member
    2010 CM 4x4
    5100s
    Interesting, did mine 8 years ago and they did not come with washers.
    Mikekoot likes this.
  14. Dec 6, 2018 at 5:23 PM
    Mikekoot
    Mikekoot New Member
    Canadia
    No issues?
  15. Dec 6, 2018 at 6:11 PM
    1999cutiger
    Sounds easy enough. Thanks for your help.
    Mikekoot and Jengel451[QUOTED] like this.
  16. Dec 7, 2018 at 3:13 AM
    MacCTD
    MacCTD New Member
    2010 CM 4x4
    5100s
    No issues, I only have 50k miles on it in 8 years but no problems so far.
  17. Dec 7, 2018 at 4:22 AM
    parker44
    parker44 New Member
    2008 Tundra - Desert Sand Mica
    Post some pictures OP when you do the install! When I replaced the shocks on my 08, I'm strongly considering the Bilsteins.
  18. Dec 7, 2018 at 5:18 AM
    rustynail11
    rustynail11 New Member
    Scott
    Mansfield,TX (DFW Area)
    2017 Grey Tundra TRD
    Let us know how the install goes. Want to go this route myself but concerned about doing the installation. Would love to hear about your experience with the install.
  19. Dec 7, 2018 at 7:55 AM
    15whtrd
    15whtrd Mr. Blonde
    I have switched back and forth from the stock bumps and super bumps. You are correct it literally takes only a few minutes per side. Even with the wheels on, I was able to just jack the truck up and swap them out.
    NewImprovedRon likes this.
  20. Dec 9, 2018 at 11:36 AM
    1999cutiger
    Well...the install is complete. Overall it was a huge success. However, there was a substantial learning curve. This project is by no means for everybody. Took me all day to do the front and only about an hour to do the rear.
    I recommend having all the right tools (especially a torque wrench), take your time, and make sure you give yourself plenty of time to complete this project. Also, it’s a huge help if you have a competent person with you to lend a hand.
    The ride on the middle setting of the 5100’s is a very noticable improvement over stock.
    I’m very glad I did it and I’m extremly happy with the finished product.
  21. Jan 11, 2019 at 5:19 PM
    Stuffs
    Stuffs New Member
    Did you need a tool to remove those or you can crank them out by hand?
  22. Jan 11, 2019 at 5:40 PM
    15whtrd
    15whtrd Mr. Blonde
    Channel locks to remove the old ones and the big allen wrench that comes with the superbumps to install. Lube up the threads of the oem bumps from above the A arm. Suggest letting it sit overnight.
  23. Aug 11, 2019 at 8:38 PM
    five09r
    five09r New Member
    2019 TUNDRA TRD Off Road Cement
    None yet...brand new
    Any need to modify (lower) front diff with the 5100 install? Most leveling kits require a diff lowering to keep the angles correct on the axles.
